I have a Vizio Plazma 50" tv. When you press the "on" button the green light in th elower right corner of the tv starts flashing yellow and green, this has been normalsince we had the tv, but the picture will not come on. if you turn the tv off, the next time you press the "on" button noting will happen. I have taken the back off the tv, and there is one board that all the boards plug into, this board clicks when you trun the tv on and off - could thi sboard be the problem. I can get a refurbished board on line for $174. What do you think? Dan Reinholtz
  • dreinholtz Jul 01, 2009
    Kevin,
    There is no lamp, this is a plazma tv. The main board looks like a power supply for the whole tv. Is there a way to check this board? Or if the clicking means that the ballast is good, could another circuit board be the problem?
    Dan
    President:
  • 2,923 Answers
Dan,
Here are the possible cause of the problem:
1. Panel - this is the screen you look at
2. Capacitor - a component that's attached into the circuit board.
3. Circuit Board - it's the one that you found after taking off the back cover of the TV.
You need to check first the capacitor, and if found a bad capacitor, you may replace it so that you would not spend too much money.
If the problem is the panel or the circuit board, I would suggest to have a service tech that would test it first before replacing any of the two.
Kindly check the link below and see the if there's an available circuit board that is compatible with your TV:
http://www.rivervalleyelectronics.net/6871QCH034A_p/6871qch034a.htm
Hope these helps and have a great day!
Posted on Jul 01, 2009
    Genius:
  • 1,847 Answers
Usually clicking noise indicates that the ballast is working and is trying to light the lamp. After 3 attempts it will shut the TV down if the lamp does not light. Check to make sure the lamp is correctly and firmly installed. It is not unusual to get a new defective lamp. If you are sure the lamp is installed correctly, you may wish to return the lamp to have it replaced.
Thanks
Kindly rate the answer
Kevin
Resetting without going to the menu for a vizio m220nv
Get into the Vizio TV service mode
There are to options to get into Service mode:
Option 1:
Turn the Vizio TV off.
Press and hold the CH + & CH - buttons on the TV.
Then press and release the POWER button on the TV Vizio.
Release the CH+ & CH- buttons.
Now press the MENU button on the remote.
You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This if for factory reset).
Press and hold the MENU button for few seconds.
The Service Menu will be displayed.
Option 2:
Turn off th Vizio TV.
Press and hold the CH+ & CH- buttons on the TV Vizio.
Then press and hold the POWER button on the TV.
Keep all three buttons pressed for few seconds.
Feb 18, 2013 | Vizio M220nv 22-inch Full Hd 1080p Led Lcd...
Virgin remote control code for volume on my 50" samsung plasma tv
To set up the volume control on your Telewest remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
Samsung 0065, 0584, 0037
Nov 18, 2011 | Samsung 50 in. Plasma TV
Can set up th remote control for this tv with the direct tv cable remote
Here's how to scan for TV codes on your DIRECTV remote
1.Make sure your TV is turned on.
2.Slide the mode switch at top of remote to "TV".
3.Press and hold the MUTE button. This is located above the number 1 button.
4.While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
5.Then enter 991, the green light on remote should flash twice.
5b. Press 1 again (it will flash twice again), then you press the power on button at the very top right.
6.Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
*If you hit channel up very fast, you risk going past the code. Pressing channel down will back it up. I alway hit channel up very fast till the tv turns off, then back it up slowly till it comes back on.
7.When the TV powers off, press and release the SELECT button.
*Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
Mar 05, 2011 | Curtis LCD2425A TV
I have a panasonic viera 50 inch plazma tv and cannot get the volume to work. i hit some button on the remote and now no volume. i do not have manual and the remote is from att uverse
Do you have a little symbol on the screen showing a speaker crossed out? If so you have pressed the 'mute' button. another press of the same button should un-mute it.
Jul 17, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Vizio P50HDM No Picture/No Sound
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Plasma does stay powered on
Your sustainer board is probably bad. You need to get the Y & Z sustainer boards replace then it should be okay.
Feb 08, 2009 | Vizio VP50 10A 50 in. Plasma TV
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
