I have a maxima 1996 and when I lock doors with fob control, and sun roof is open, it will close along with doors. Try this way. Also check fuses under dash and sunroof relay.
check the track to make sure nothing is lodged in there thats keeping the sunroof from closing. if nothing there check to see if the motor is alligned properly to the track.
My '91 does the same thing. There is a thin metal wind deflector (about one inch wide with holes in it across the front edge of the sunroof opening. It should flip down to allow the glass to close all the way but sometimes it doesn't flip down all the way. Use something flat and thin like a credit card to hold it down while you close the roof. Works for me.
Had this problem all you have to do is actually open sunroof with tilt button all the way and then close it with tilt button to reset, then it should work with open switch. If you disconnect battery this happens and you have to reset it this way
It sounds like the motor has gone on the sunroof mechanism, also try and get a tester to see if there is any power going through it, before you spend money on a new sunroof switch, not sure of the technical term. I hope this helped.
Sounds like the sunroof motor is out of time. Needs to be re-timed. There is a retime procedure, (that I would try first) but I don't remember the whole procedure. if you still have the problem, let me know and i will get the whole thing , from the service manual.
