Question about Buffalo Tools 4,000 Watt 6.5 Hp Portable Generator #GEN4065
USED IT FOR APPROX 3 HRS DURING POWER OUTAGE.SHUT IT OFF ,CAMA BACK 15 MIN LATER AND GAS WAS OVER FLOWING FROM THE CARB.TOOK CARB OFF CLEANED NEEDLE AND SEAT ,SAME PROBLEM.PURCHASED A NEW CARB AND INSTALLED IT.NOW WHEN I START IT IT GOES TO MAX RPM AND THE ONLY WAY I CAN GET IT SLOWED DOWN IS TO HOLD THE CARB LINKAGE.ONCE I LET THE LINKAGE GO IT RACES BACK UP.
  • 1 more comment
  • jonip Jul 01, 2009
    THE UNIT STARTS AND RUNS FINE.PROBLEM I HAVE IS THAT IT GOES TO MAX SPEED AS SOON AS IT IS STARTED.AS I SAID I PUT ON A BRAND NEW CARB, BUT CAN NOT GET IT TO IDLE DOWN .IT APPEARS THAT THE GOV.IS HOLDING IT WIDE OPEN.I HAVE NOT TOUCHED ANYTHING EXCEPT FOR THE CARB REPLACEMENT.
    RAN THE UNIT FOR THREE HOURS,AFTER I SHUT IT OFF WITHIN 15 MIN.THE CARB WAS LEAKING FUEL. TOOK OFF THE CARB AND CLEANED IT,NEEDLE AND SEAT ETC.REMOUNTED THE CARB STARTED IT AND IT WENT MAX SPEED.ONLY WAY TO SLOW IT DOWN WAS TO HOLD THE LINKAGE BACK.SHUT UNIT OFF AND WITHIN 10 MIN FUEL STARTED LEAKING AGAIN.BOUGHT A NEW CARB AND INSTALLED IT,BUT HAVE THE SANE RESULTS.UNIT RAN FINE DURING THE THREE HOURS IT WAS RUNNING.GOV. SEEMS TO BE HOLDING THE THROTTLE WIDE OPEN,AND I DONT KNOW WHY.
    KEVIN, AS SOON AS I HOOK UP THE LINKAGE IT PUSHES THE CARB THROTTLE TO MAX SPEED,SO THAT WHEN I START IT ITS RACING.I HAVE CHECKED AND RECHECKED AND THE LINKAGE CAN ONLY GO ON ONE WAY.DO I HAVE TO BEND THE LINKAGE ROD TO GET THE PROPER IDLE?
  • 11,896 Answers
The floats in the carb are sticking! That is why it is overflowing. You can adjust the carb idle screw and needle height
Posted on Jul 02, 2009
    Genius:
  • 1,847 Answers
This seem issue with the engine governor which should maintain the voltage at the rated speed. The generator should already have a voltage regulator in the control circuit.
The governor is designed to automatically speed up the generator, or slow it down, depending on load demand. Get the governor checked by a qualified technician and if you know how to do it be careful with the test leads and don't get shocked.
Thanks
Kindly rate the answer
Kevin
Posted on Jul 01, 2009
    President:
  • 392 Answers
Try these: With air filter off see if the carb is loose at all. if it is then it is sucking air. tighten it and it shoild be fine. If it is tight there should be a screw at the bottom of the float bowl. open it and let about a half cup of fuel drain. Try it again. If it is ok then you had water in the fuel. If it still runs rough there are at least one screw on the carbs body (not the idle adjust) turn it all yhe way in and then back it out 1 1/2 turns. Try adjusting the roughness by turning the screw with the engine running. If still no joy then see if there is an in line filter change it. It may be clogged.Also try loosening the fuel tank cap. It may be causing a vacuume that is not letting enough fuel get to the carb. If these fail then remove the carb and kit it. Blow out all passeges with some carb cleaner. Then blow it dry with compressed air prior to reassembly. If this answer satisfies your question rate my answer button. If it does not, please tell me so. You are not expected to accept any answer that you are not happy with. I do expect you to let me know if you are not satisfied, and what I can do to put a smile on your face.
  • M.Jeevan Chaitanya
    M.Jeevan Chaitanya Jul 01, 2009
    baically the unit should be warm, once try cleaning the spark plug.
I just bought a mud blaster 110cc quad for my son, why does it start then 2 min later stop even with feathering the throttle?
#1 sounds like a fuel delivery system issue. Make sure the fuel tank flows freely to the carb. (remove the fuel line from the carb--from the gas tank and turn on the petcock--gas should flow freely) The needle and seat may need to be cleaned or replaced, this controls the flow of gas into the float bowl of the carb.(remove the drain screw from the bottom of the carb (with everything properly assembled- petcock on)..gas should continually flow through the bottom of the carb --10-15 seconds of continual gas flow will make sure its flowing properly! Both of these sound like a solution to your problem.
Jun 22, 2014 | ATVs
2002 artic cat 350
Has this ATV been sitting for a while? actually sounds like a fuel delivery system issue. make sure you have gas freely flowing to the carb.. then have a professional clean and set the carb. You are actually waiting in the carb to fill with gas during this time... the needle and seat need cleaning or replacing
Mar 24, 2014 | ATVs
Still problems
The symptoms would seem to indicate a blocked air filter. Just because the fuel filter is showing fuel, doesn't mean it is getting to the jets. After a complete fuel system clean it could be something as simple as some dirt in the jets of the carb. When you clean something as thoroughly as that you can still miss something.
Jun 19, 2013 | Suzuki Boulevard S40 Motorcycles
23 hp Kawasaki FH680v engine losses power when engaging pto!
We had issues in the UK with issues like this, they would blacken and soot up the plugs and start to run on on cylinder, there was an internally vented carb rather than the externally vented carb to cure this.
Aug 10, 2012 | kawasaki Garden
Wont start i have changed gas and spark plug
kill switch in proper position for run? fuel valve on if applicable?choke on ? sorry i had to ask. pull plug out ,connect plug wire and see if spark by grounding plug on engine, than a sharp pull from recoil- should see spark. good spark? if so- now see if fuel is reaching carb by removing screw on bottom of carb float bowel . this must be done out side - i know there is a blizzard going on. remember where all gaskets go and are properly on when putting back together. If no FRESH fuel FLOWS OUT WITH GAS ON your needle on the float shaft is probably stuck in the seat of the carb.Pull down on float gently to release needle valve.may have to shoot some carb cleaner in there. be prepared to shut off fuel if it starts flowing.If no shutoff ,pinch off fuel line with small vice grips or hemo's. all jets should be cleaned if old gas dried in bowel over time.
Feb 01, 2011 | Craftsman Electrical Supplies
Our troy bilt self propelled lawn mower is about 8 years old and has served well. However it has developed the following problem: requires extra priming to start and then dies....will not remain started....
The float and needle need replacing. Take the carb off soak in a high octane gas or booster for 15 min. The float isn't floating in the gas bowl, which rises the needle to let more fuel in. When you prime the carb, you are directly shooting gas to the carb, this is why it will start and then shut down because the float can't keep gas flowing in. A kit cost about $5-7 and easy to replace.
Apr 19, 2010 | Troy Bilt 5.5hp Self Propelled Mower
XV1100 virago ...sputtering, dying...NOT FZR!!
1 maybe there is a diaghfram tear at your carb only 1 is funtioning and 1 block engine is running but under power
2.check your fuel line from tank to fuel filter then pump then carb
probally there is a debrie stuck in the pipe line or in your tank
May 11, 2009 | 1990 Yamaha FZR 1000
Buffalo Tools 4,000 Watt 6.5 Hp Portable Generator #GEN4065 Logo
89 people viewed this question
Top Buffalo Tools Electrical Supplies Experts
Bill Boyd
Lawrence Oravetz
Are you a Buffalo Tools Electrical Supply Expert? Answer questions, earn points and help others
