Question about Dell Latitude D505 Notebook
System will not boot properly unless in safe mode. Windows tries to boot, a blue screen with some type of messages comes up for a microsecond and it starts over--I get the black screen with options for startup. If I select start normally, the same thing happens repeatedly.
  • 11,896 Answers
I suggest downloading a free registry fix program called "glary utilities" and run the program. It should fix all your problems. If anything, you can always do a system restore
Posted on Jul 01, 2009
Few minutes after Windows starts the computer screen shows this blue screen with lots of white text and then it shuts itself off, then it restarts itself and then again, the blue screen and it shuts itself...
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Jun 21, 2011 | Toshiba Tecra M2V-S310 Notebook
Hi my pakard bell desktop keeps blue screening and i get following fault message- BCCODE 1000008e BCP1 c0000005 BCP2 B94D9C29 BCP3 BA487204 BCP4 00000000 OSVer 5_1_2600 SP 3_0 PRODUCT 256_1 can you help
Then press any key.
Then type "y"
Aug 07, 2010 | Computers & Internet
I turn on my hp pavilion zd7020us the hp page boots up then goes to safe mode or normal mode page then goes to a very quick blue screen and turns off and starts the whole process over again any ideas
Then press any key.
Then type "y"
Jun 18, 2010 | Computers & Internet
I get a blue screen error message ''c000021a unknown hard error'' after running CHKDSK as a result of receiving an initial blue screen error message ''The Type of file system is NTFS. The volume is...
Hi, Boot into Safe Mode by pressing F8 at bootup and choose
'Safe mode with command prompt'
At the command prompt type
C:\Windows\system32\restore\rstrui.exe
Hopefully System Restore will open so choose a Restore Point a few days ago.
Please rate my response!! Thanks, SF
Jan 28, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Windows xp quit loading blue screen says page-fault-in-nonpaged-area tech info ***stop:0x00000050(oxc9464269,0x00000000,0x870e208c,0x00000000)
Then go to boot menu and set frist boot device as your cd or dvd rom.
Then press any key.
Then type "y"
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windwos " then it repairs old windows then it loads again old windows.
Jan 08, 2010 | Microsoft Windows XP Home Edition
Unable to open windows
try booting into safe mode (hit F8 repeatedly when you reboot until a safe mode option comes up) then if you are able to log in, go to the windows run prompt, type "msconfig" go to startup, disable all, services, disable all. reboot. see if it still does the same, if it doesn't one of those services are causing blue screen. Also try reverting to previous drivers if you did any driver updates, remove any new cards/hardware you might of installed recently.
If you can't get into safe mode, at a copy of any xp disk. boot up from it. (make sure your boot devices are set that cd rom is before hdd in cmos setup) then go to the recovery console "you press 'r' when ou have various option" type 1 for the windows, enter. enter for password unless you previously set an admin password.
Then type "chkdsk /p", let it run also type fixboot, and say yes. reboot and see if this solves your problem.
Jan 05, 2009 | Toshiba Satellite A135 Notebook
Windows xp home edition computer will not start
If the system cannot start on safe mode probably your operating system has gone bad, to check your hard disk you can go use your windows xp disk, to boot from it press f12 choose cd rom keep on tapping enter and dont mind the message that you need to press any key to boot from cd, and then when you are on the welcome to setup page press r for recovery console, once you are there try to type in chkdsk /p and after type in fixboot and press y, and restart your system, if that wont work then your hard drive is bad.
Oct 31, 2008 | Microsoft Windows XP Home Edition
Help
Blue screens causes your system not to boot properly. It could be a corrupted video driver, system registry or could be a problem with a hardware component of' your system. Windows update causes also blue screens and incompatible application installed in the system as well.
You may try to boot your computer to following option.
Last known good configuration
Safe mode with networking.
1. Restart the system. At the moment you are turning on your system. After pressing the power button.. Keep on tapping F8 key (on/off) until you have the message "Advanced boot option"
2. Select the 1st option: Last known good configuration.. Press Enter until you have your login screen. If it doesn't work you may try the second option which is the "safe mode with networking".
If the two option won't work, you may need to try repairing the operating system or reinstall windows.
Keep me posted.
Thanks.
Oct 16, 2008 | Computers & Internet
Dell Latitude D505 Notebook Logo
168 people viewed this question
Alun Cox
