Question about Toshiba 57H82 57" Rear Projection Television
About two months ago when we first turned on the TV there were wavy lines across the whole picture. When it warmed up they would go away. Now, the lines are there almost all the time and it's getting harder and harder to see the picture. It is blurred in some spots (acros the top of the TV is the worst) and flickers or flashes a lot. A local repairman is not available until July 22nd to even look at it will cost us $100. If there is something else we can try, we can do it ourselves as it is out of warranty!
    Sergeant:
  • 296 Answers
Hi
You are experiencing a lack of vertical deflection or vertical collapse. Since it will come back the first thing I would suspect is “ring cracks” in the solder joint in the vertical circuit, mainly the vertical IC. These suspect solder joint can be re-soldered and the television set repaired.
I would suggest that you contact a local servicer. If you are repairing the set yourself, be careful, there is always a risk of shock when dealing with electronics.
OR
Check your equipment connections. Disconnect your equipment (VCR, DVD or set-top box) from the TV and reconnect, making sure each connection is in tight.
OR
chek this site,i blieve u will b helpfull
http://www.dshosu.com/how-to-fix-toshiba-rear-projection-hdtv-wavy-lines/
regards
Posted on Jul 01, 2009
Horizontal wavy lines on picture
Sounds like the convergence has failed. This video gives more details
Apr 12, 2012 | Mitsubishi WS-55513 55" Rear Projection...
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Hello..Toshiba 51HC85, 2005 model. Turn on TV and verticle wavy lines appear until TV is warmed up completely. After warm up the picture is great again. Any ideas?
I've had the same problem for about the last 6 months. My workaround which was to leave the tv on 24 7 and just turn off the TWC service box. But now the symptoms are vertical dark lines going all the way across screen. My guess is that it will cost more to fix than worth it. I paid @$2000 for it new in 2004. Technology has gotten better so I may just go out and get a Samsumg for considerably less and be way better off. None of Toshiba's products had done well for me. 2 laptops, 3 tvs, etc. have taught me this.
Sep 20, 2010 | Toshiba 51H83 51" Rear Projection...
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
Colored wavy lines on screen
This is a Logic board problem, not so easy to replace in Hitachi but well worth the repair if I had your zip code I could recommend a person or three. But the problem is a problem in the logic board and will beed replacement, Thanks for using Fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 14, 2009 | Hitachi P42H401 42 in. Plasma HDTV
Long power up time, wavy "static" lines, and red/orange problems
part of it sounds like your coax cable is not connecting properly. pull it out and make sure the pin at both ends of the coax cable is straight if bent replace coax cable.
Dec 28, 2007 | Hitachi 32UDX10S 32" TV
Toshiba 42H83 42 in unstable video
Probable PIP sister board.Moderate skill & some tools needed.Advise==get a senior tech near you.
Sep 10, 2007 | Toshiba 42H83 42" Rear Projection...
57"H82 Toshiba-- wavy picture
you got somes capacitor bothering you, and nop, there are nothing you can do, but call a tech, the problem could be in the video card or in the power supply but is a tech job....good luck
Aug 08, 2006 | Toshiba 65H82 65" Rear Projection...
Wavy picture
this is caused by a bad convergence module, and there are probably some dried out electrolytic caps in the circuit as well. i have one in the shop right now that came in with the same problem. if you have it serviced, make sure they replace all of the convergence modules (there are usually 2, but sometimes 3 of them), because if one went bad the other(s) is likely to go out soon as well.
Jun 28, 2006 | Toshiba 65H82 65" Rear Projection...
Toshiba 57H82 57" Rear Projection Television Logo
241 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
