Question about Canon PowerShot A640 Digital Camera
Camera putting double of each picture on Card
Every picture that I take on my A640 is saved twice on the SD card...so I only end up being able to take 400 pictures instead of 800 (for example) before my card is full. I then have to go thru and manually delete each duplicate image so I can take more pictures if I am away on holidays and can't upload all the images to my computer and completely erase the card. I don't know how to fix this (obviously) and it is getting very frustrating when I am at weddings/events.
Thanks
  • 126 Answers
There is a board in your camera that has the SD card port on it. It is most likely at fault and need to be replaced.
Posted on Jul 02, 2009
I have a Nikon D5300. I can see the photo count number increasing, but I cannot view the images and they are not going on the SD card. Where are they? The SD card is not full.
many small Nikon cameras have memory to store images ON THE CAMERA. If you have a memory card installed that the CAMERA CAN READ it will put images on the card. if the memory card is corrupted the camera will not use it.
First Backup all IMAGES on Memory Card to COMPUTER make sure you saved ALL images. This is IMPORTANT.
After you SAVED all images you PUT Memory card back in camera and FORMAT it (Format is in TOOL Menu that looks like a wrench)
Now if you can take an images and it saves to memory card you are done. To see if they go to MEMORY CARD. Turn off camera and remove MEMORY CARD and Check.
If it STILL does not work you may have a defective memory card.
Feb 23, 2017 | Nikon Cameras
I have saved all my pictures on my computer, but now the camera is saying the card is locked and I can not delete them from the SD card to clear it. The lock is not on on the SD card, I don't want to...
try this remove SD card from camera, put it into a SD USB converter, use this on the PC and Format the SD card FAT16, this should remove all data. return SD card to camera, the camera may then want to format the card itself, if so this is all OK.
Also ensure that the little protection switch, on the SD card if there, not all have one, is set correctly... toggle it if there.
Sep 10, 2011 | Pentax Optio M50 Digital Camera
Just put a new memory card in the camera but the screen keeps showing internal memory is full
How to switch the camera over to saving pictures directly onto the SD card.
    1. Menu
    2. Cam settings
    3. Chose AUTO or SD card option and Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you still experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
    After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    Camera will not read memory card
    Your camera is only supporting SD/MMC Cards (up to 2 GB)
    The card that you currently have might be faulty. Please try another card.
    You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
    Jan 01, 2010 | Kodak EasyShare DX7590 Digital Camera
    I put a new memory card in our Kodak EasyShare
    Your camera is only supporting SD/MMC Cards (up to 1 GB)
    1: Menu 2: Cam settings 3: Chose AUTO or SD card option Press OK
    Dec 25, 2009 | Kodak EasyShare C330 Digital Camera
    I have a new memory card. I cant get pictures
    Oct 27, 2009 | Kodak EasyShare C330 Digital Camera
    Missing pictures
    Lets check the SD card first.
    Take out the SD card and put it in external card reader connected to computer.
    Copy/transfer all the photos from the SD card to computer.
    goto My Computer and right-click the 'Removable Disk' (the SD card drive) and click Properties.
    click Tools and click Error checking - Check now button
    select the option 'automatically fix file-system errors' and click Start button.
    if any errors was found and fixed, you can also Format the SD card. And your SD card should not drop photos again.
    Now put SD card back in the camera.
    Now take 20 test photos and check if something is missing.
    if not take 20 more test photos and check if something is missing.
    if all is ok then you can delete all test photos and start taking normal photos.
    May 31, 2009 | HP Photosmart R817 Digital Camera
    Camera screen said SD card is locked when I installed an SD card
    The SD card has a lever on the side of it. Move it to the other position.That is to prevent accidental erasing.
    May 12, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
    Canon A640 thinks media card is lock
    Inside your camera there is a detector that senses that your card is locked or not it sounds like yours is stuck in, you may be able to free it get yourself a flash light and look inside the socket on the side where the slide is on the memory card use a very small tool or paper clip you have to be really careful when doing this you could break the sensor if your to rough on it.Good luck
    Jul 29, 2008 | Canon PowerShot A640 Digital Camera
    Canon PowerShot A640 Digital Camera Logo
    61 people viewed this question
    Top Canon Cameras Experts
    TC CAMERA REPAIR.Com...
    old marine
    old marine
    Are you a Canon Camera Expert? Answer questions, earn points and help others
