Question about Ingersoll Rand Stationary Air Cooled Rotary Screw Compressor 10 Hp, 35 Cfm At 125 Psi, Model# Ep
40 hp rotary screw IR compressor
Uses or comsumes a lot of ultra coolant. I changed sparator element. Changed orifices..Had other techs tell me that the sparator element had a slight design change and scavage tube was not hitting the bottom of the element filter. The oil does not seem to be going down stream. I do have lots of coolant collection inside the cabinet insulation at the top . this is puzzeling .I don't see any leaks/any blow off.
  • jaap schildmeijer May 11, 2010
    is your airfilterelement dry or wet of oil.
    goes machine unload before stop.
    is scavenge line open( getting hot while running loaded
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
Check if your compressor running in low pressure. If your discharge pressure drop @65psi the result is oil carry over.
Posted on Aug 23, 2010
Compressor oil capacity
Ingersoll Rand ultra coolant oil for rotary compressor.
Jun 03, 2013 | Ingersoll Rand Compressors 5-HP,...
HIGH AIR END TEMPRETURE. MODEL M-40
low oil or your fins on your air/oil cooler are restricted (dirty) or poor ventilation .wrong oil .I believe these units run on gyclo based coolants not oil ultra coolant which is i/r brand
Jun 13, 2011 | Ingersoll Rand Rotary Screw Compressor ...
Hi, whats the oil capacity for an ingersoll rand compressor? serial: G9874V02140 model: SSR-EP50SE 215 CFM nominal drive motor 50HP we are about to make an oil change[thank you]
Below is the procedure for COOLANT change including amount needed.
SSR Ultra Coolant (Standard Factory Fill)
SSR Ultra Coolant is a polyglycol base coolant. Change
Ultra Coolant after every 8000 hours or every two years,
whichever comes first.
In addition to the tools normally found in any reasonably
equipped serviceman's toolbox, the following items
should be available at the work site:
1) Suitable drain pan and container to hold lubricant
drained from unit.
2) A quantity of proper lubricant sufficient to refill the
compressor.
3) A minimum of one replacement coolant filter element
of the proper type for the unit to be worked on.
There is a coolant drain valve on each compressor. It is
located on the bottom of the separator tank.
The coolant should be drained soon after the compressor
has been shut down. When the coolant is hot, the
drainage will be more complete and any particles in
suspension in the coolant will be carried out with the
coolant.
Hot coolant can cause severe injury. Use care when
draining separator tank.
To drain the unit, place drain pan under drain valve. Open
drain valve to start drainage. After draining is complete,
close drain valve.
After the unit is drained and a new coolant filter element
is installed, refill the system with fresh coolant through
the filler cap on the side of the separator tank. Bring the
receiver level of coolant up to the top of the sight glass.
Replace the fill cap. Start the compressor and allow it to
run unloaded for a short time. The correct coolant level is
at the midpoint of the sight glass with the unit running in
the "UNLOADED" mode. If the level is not near the
midpoint, stop the compressor and allow all pressure to
relieve from the system. Open the fill cap and add more
coolant.
50 hp (37 kw).....................3.4 gallons (12.9 liters)
Coolant fill quantity
! WARNING
Use care when near this area.
Use only recommended
coolant.
Read instruction book
before servicing.
39543921
run unloaded. The coolant level should now be near the
midpoint of the sightglass.
DO NOT OVERFILL THE MACHINE. Over filling will
affect separation and carryover down stream.
Sep 06, 2010 | Ingersoll Rand Compressors 5-HP,...
Why coolant coming through air filter element?
Hi dear,
There problem is loan/unload pneumatic valve not work properly. Please change this pneumatic valve.
Jun 20, 2010 | Ingersoll Rand Stationary Air Cooled...
My ingersoll ssr2000 rotary screw compressor trips &restart on it
Check defective HATS or Airend is defective. HATS means High Airend Temperature Switch.
Mar 03, 2010 | Ingersoll Rand Stationary Air Cooled...
Compressor spits out oil when unit is stopped
MIGHT CAN HELP. NOT AN I.R. EXPERT BUT KNOW A GOOD BIT ABOUT SCREW COMP. ARE YOU SHUTTING UNIT DOWN SUDDENLY WITH EMERGENCY STOP OR SOMETHING. SOME UNITS DO THIS MORE THAN OTHERS BECAUSE THE WAY THE VALVE CLOSES. BURPING OIL THROUGH THE INTAKE IS ALSO CAUSED BY SUDDEN STOP INSTEAD OF THE UNIT SLOWLY SHUTTING DOWN AND THE OIL IS RUNNING BACK SLOWLY. THE UNIT ACTUALLY TURNS BACKWARDS A LITTLE BIT. YOUR OIL SHOULD NOT COST THAT MUCH. YOU CAN CONTACT ME FOR PARTS AND PRICING ON THE OIL. YOU CAN SAVE ALOT OF MONEY WITH AFTERMARKET SERVICE PARTS AND OIL -THEYRE JUST AS GOOD AS OEM.I WOULDNT USE 30W OIL ! YOUR POOR AIR DELIVERY MAY BE AFFECTED BY WORN PARTS DUE TO LUBRICATION. HOW OLD IS UNIT? MODEL # ? CONTACT ME JBRIDGERS@CA-EQUIP.COM FOR INFO & PRICING. ME AND 1 TECH WOULD PROBABLY COME DOWN AND FIX IT FOR YOU FOR AN ALL EXPENSE TRIP FOR FREE. WE ARE IN NC AND DONT GET OUT ENOUGH.
Jan 20, 2009 | Ingersoll Air Tools & Compressors
40 hp ingersoll rand rotary screw air compressor keep shutting
I have a ingersoll compreesor that keeps shuting down on high discharg air temp
Nov 12, 2008 | Ingersoll Rand Stationary Air Cooled...
Ingersoll Rand Stationary Air Cooled Rotary Screw Compressor 10 Hp, 35 Cfm At 125 Psi, Model# Ep Logo
341 people viewed this question
Top Ingersoll Rand Tools & Hardware - Others Experts
elunsford
Phil Walker
Phil Walker
Are you an Ingersoll Rand Tool and Hardware - Other Expert? Answer questions, earn points and help others
