Question about Apple iPhone Smartphone
Iphone 2G, 3G and Ipod touch won't sync with Itunes 8.2
Tried deauthorizing and reauthorizing, tried reloading itunes 8.2, iphone 2G and ipod touch on 3.0, iphone 3G on 2.2.1, tried turning off and on computer, tried differenct usb ports, tried shutting off internet, tried different cables. Basically I've tried all the suggestions that I've googled so far and nothing working. All devices do sync on my old powerbook G4 but not on my imac 2.8GHz intel core 2 Duo which they used to sync on before the 8.2 and 3.0 upgrades. Any further suggestions?
    Master:
  • 696 Answers
Not enough g's
Posted on Jun 03, 2017
SOURCE: iPhone 3G Error 0xE8000001
I just had this problem and it turned out to be... It didn't like my iPod cable. Switched to the iPhone cable and it worked.
Seems to be an iPhone 2.0 prob, or 3g prob, since I was using the iPod cable to sync my old iPhone just fine.
Posted on Aug 07, 2008
no_pc-gst
  • 58 Answers
SOURCE: iphone 2g wont sync
Please look here:
iphone Troubleshooting Assistant
http://www.apple.com/support/iphone/troubleshooting/phone/
Reset and Restore iPhone to Original Default Factory Settings with Recovery Mode iPhone display freezing? iPhone doesn’t detect by or appear in iTunes? iPhone cannot sync with iTunes on PC or Mac? Cannot make or receive calls, send or receive text messages, or access email or the web? Or worse, iPhone simply won’t turn on and does not respond to tap or button press? If the problem still persists after you have reseted the iPhone, or tried various iPhone troubleshooting, it may be worthwhile to invoke recovery mode to restore iPhone to default factory settings, the original state as when you first received and unwrapped the phone.
Restoration of iPhone to original factory defaults will likely to fix all problem, with the downside that all data and information stored on your phone will be lost. Normally iTunes will make a backup automatically when you connect and sync the iPhone with the program, however, it’s still a good recommendation to copy out and backup everything that you may need on the phone before proceed to restore the iPhone.
To restore iPhone and reset the phone to default factory settings, follow these steps:
  1. Turn off iPhone - Hold down the Sleep/Wake button for a few seconds until the red slider appears, then slide the red slider. Ignore this step if your iPhone is already off.
  2. Press and hold down the Home button for about 10 seconds until a yellow triangle with a text which says Please Connect to iTunes appears. iphone-recovery-mode.jpg
  3. Plug the iPhone into Mac or Windows PC. Release the button if you haven’t.
  4. Run and open iTunes if it’s not already opened yet.
  5. iTunes will prompt a message that says iTunes has detected an iPhone in recovery mode. Click OK.
  6. You will be taken to the iPhone pane. Then, click on Restore.
  7. Wait for the full restoration process to complete, and the iPhone will be back to the original settings state as when it left the manufacturing factory, typically a working phone again if you face any problem, unless it’s hardware related
http://www.mydigitallife.info/2007/10/04/reset-and-restore-iphone-to-original-default-factory-settings-with-recovery-mode/
Posted on Jan 02, 2009
  • 34 Answers
Where did you purchase your phone? however, you first need to update itunes to 8.0.2, that might solve your problem. Unless you have an unlocked phone then restoring your phone is useless because when you restore an iphone with itunes in the US without an att sim card it will actually lock the phone, but I do not think that is your issue. the two things you are seeing the connect to itunes and the emergency call system means that your phone is not properly activated. which is done by connecting it to itunes.
Posted on Jan 25, 2009
  • 173 Answers
SOURCE: iphone charging problems
I was just anwering another person with the same issue as you. As I was telling him, it is a common issue that I fix 4-5 per week. But it is a very difficult repair. Your main flex cable needs to be inspected and posibily replaced. This cable also has the Microphone, Speaker and bottom charging port copnnected to it. I suggest taking it to a repair shop with iphone specialty. If you are in US you can ship to me if you like. Cellularcpr@aol.com
Posted on Jun 24, 2009
jacko0
  • 159 Answers
SOURCE: IPHONE STUCK ON USB AND ITUNES SCREEN CANNOT CHARGE
It's sounds like your iPhone is stuck in recovery mode
Try this
Posted on Dec 18, 2009
How do i delete all songs on ipod shuffle and then reload? I want to empty it and start over as if new
How to Delete All Music from iPhone / iPad / iPod
  1. Open the "Settings" app and tap on "General"
  2. Select "Usage" and then choose "Manage Storage"
  3. Tap on "Music" to select the song library on the iOS device.
  4. Swipe to the left over "All Songs" then tap on the red "Delete" button when it becomes visible.
Remove All Music from iPhone, iPod touch, iPad - OS X Daily
osxdaily.com/2012/02/18/remove-all-music-from-iphone-ipod-touch-ipad/
delete all songs on ipod Google Search
Feb 08, 2017 | Apple iPod Audio Players & Recorders
Getting message error -40 cant connect to itunes on my ipod 2g a1288
1. First, Open up iTunes, plug in your iPod Touch/iPhone to the CPU's USB port. Turn on your CPU's speaker and make sure it is loud enough that you can hear it.
2. Hold down the Home button (top left for iPod Touch and top right for the iPhone with the screen facing you) and the Power button (located on the front bottom of your iPod Touch/iPhone) simutaneously, until the screen goes black and the device turns off. (past the red slider/slide to power off screen)
3. Now let go of the Power button, but continue to hold the Home button. Your iPod Touch/iPhone should have turned off and the screen should not be on.
4. After around ~10-20 seconds, you will hear a noise (beep/ding) from your CPU as if it had just recognized a new hardware device, now iTunes should recognize it in DFU mode.
5. After iTunes recognizes the iPod Touch/iPhone, let go of the Home button otherwise it will go into recovery mode and you will have to do the entire DFU process over again.
6. You will know when you have put your iPod Touch/iPhone correctly into DFU mode when the display is blank and that you do not have anything on your device.
7. Restore ipod using itunes
Feb 26, 2011 | Apple iPod touch Second Gen (8 GB,...
It says can not sync ipod(-53) What does this mean..how to fix
Hi, message saying "can not sync" means that the connection from the ipod to the computer was not successful..
If you sync your iPod with a different/empty library iTunes will only give you the option to copy your iTunes Store purchases directly from the iPod to the computer and everything else on it will be erased. You'll find details on transferring purchases in this article: iTunes Store: Transferring purchases from your iPhone, iPad, or iPod to a computer
Purchased applications can be downloaded over again, see this article for details: How to redownload purchased applications from the App Store
If you want to recover the music from CDs etc that is on the iPod and transfer it to your new computer there are a few things you can do. music from CDs etc.) there are a number of third party utilities that you can use to retrieve the music files and playlists from your iPod Touch or iPhone. You'll find that they have varying degrees of functionality and some will transfer data (such as playcounts and ratings), movies, videos, photos, podcasts and games as well.
A selection of iPod/iPhone to iTunes utilities:
Senuti Mac Only (iPod Touch & iPhone compatible)
SharePod Windows Only (iPhone and iPod Touch compatible)
TuneJack Windows Only (iPhone and iPod Touch compatible)
iPodRip Mac & Windows (iPhone and iPod Touch compatible)
Music Rescue Mac & Windows (iPhone and iPod Touch compatible)
iPod Music Liberator Mac & Windows (iPhone and iPod Touch compatible)
iGadget Mac & Windows (iPhone and iPod Touch compatible)
iRepo Mac & Windows (iPhone and iPod Touch compatible)
iPod Access Mac & Windows (iPhone and iPod Touch compatible)
TouchCopy Mac & Windows (iPhone and iPod Touch compatible)
I would also advise that you get yourself an external hard drive and back your stuff up, relying on an iPod as your sole backup is not a good idea and external drives are comparatively inexpensive these days, you can get loads of storage for a reasonable outlay: Back up your iTunes library by copying to an external hard drive
One last thing, you need to take care connecting to an empty iTunes. Open iTunes first and go to Edit>Preferences>Devices and check the box "Prevent iPods and iPhones from syncing automatically" and choose Ok before connecting your device.
Once you have recovered everything from the iPod and your iTunes library has been rebuilt it will be safe to sync again.
Feb 18, 2011 | Apple iPod Touch 8GB 32GB 64GB 3rd...
My ipod touch 4th generation says -ipod is disabled connect to itunes- tried that and itunes wouldnt open unless unlocked my ipod and i cant. I tried restoring it and itunes said ipod can not be restored...
"iPod is disabled - Connect to iTunes" . This is because someone(or something?) has tried to crack your password too many times, which causes Iphone/Ipod to automatically disable itself to protect your data.
To restore your iPod, you must connect your iPod to iTunes with your iPod connector table. Make sure it is on and has this message when you connect it to your computer. Once connected, iTunes should detect it as usual.
Once connected, make sure you have all the proper sync settings enabled - for example, applications, music, photos, etc. Change something so that the Sync button in the bottom right appears in the iTunes window. Then sync the data.
When syncing is finished, turn on your iPod / iPhone and you should notice that the message is gone. Type in your password and the disabled message should be gone.
If the message is still there, try holding the sleep and home button at the same time until the iPod turns off, then continue holding the sleep and home button until a screen with the iTunes logo and a picture of the connector cable appears. This will put your iPod in Restore mode. With this option, you must click the Restore button in iTunes, which will delete all your data on the iPod.
Jan 13, 2011 | Apple iPod touch
I have a 2g iphone unactivated and want to turn into ipod
have you tried to load songs to it? you can try loading songs to it by downloading itunes and sync your iphone to itunes to transfer the songs. you will not be able to use the phone capabilities but you can use it as an iPod.
May 10, 2010 | Cell Phones
How to sync .ipa files from comp to iphone thru itunes ?
when you sync the iPhone with the computer, iTunes will only add what is new, it will not delete your apps.
Setting Up Syncing You use iTunes on your computer to set up which items are synced. Make sure you have the most recent version of iTunes (On a PC, open iTunes and choose Help > Check for Updates. On a Mac, open iTunes and choose iTunes > Check for Updates.
Step 1: Connect iPhone or iPod touch
  1. Connect iPhone or iPod touch to your computer using the included cable. You can connect the cable from your computer directly to iPhone or iPod touch, or connect the cable from your computer to the Apple Universal Dock (available separately) and put iPhone or iPod touch in the dock. By default, iTunes opens automatically.
  2. Select iPhone or iPod touch in iTunes under Devices on the left hand side and click the Info tab.
Step 2: Set Up Which Items Are Synced Click the respective tabs in iTunes to specify which media and information you want synced from your computer to iPhone or iPod touch.
For more information about syncing iPhone with your computer see the iPhone User's Guide:
On your computer: click here to download and view "Chapter 1: Getting Started" in iPhone User Guide.
On iPhone: Tap Safari and view http://help.apple.com/iphone/guide/.
For more information about syncing iPod touch with your computer:
On your computer, click here to download and view "Chapter 1: Getting Started" in iPod touch User Guide.
On iPod touch: Tap Safari and view http://help.apple.com/ipodtouch/guide/.
Step 3: Sync iPhone or iPod touch Click Apply in the lower-right corner of the screen. Your computer syncs with iPhone or iPod touch according to your settings.
The first time you sync iPhone or iPod touch, you are asked if you want to merge data, replace data on the service, or replace the data on your computer. After that, anytime you connect iPhone or iPod touch to your computer, iTunes opens and syncs with iPhone or iPod touch according to your settings.
You can adjust sync settings anytime iPhone or iPod touch is connected to your computer. You can only connect and sync with one iPhone or iPod touch at the same time. If you need to sync more than one iPhone or iPod touch, disconnect one before connecting the other.
Note: Syncing won't delete any contact in Yahoo! Address Book that contains a Messenger ID, even if you've deleted the contact from your address book on iPhone or your computer. To delete a contact containing a Messenger ID, log in to your Yahoo! account online and delete the contact using Yahoo! Address Book.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 01, 2009 | Apple iPhone Smartphone
My iphone is dead, i tried charging it for the
What you have to do is hold the power and middle button while plugging in the sync cable, it will then show the connect to itunes screen.
Mar 05, 2009 | Apple iPhone (16 GB) Smartphone
Problem in unlocking iPhone 2G
BOX, PSP, PS2,PS3, IPOD, IPHONE, IMATE, 02, Blackberry, HTC, Palm, HP, Repairs n service HI WE REPAIR ALL OUT OF WARRANTY APPLE IPODS,IPHONES, AND APPLE LAPTOPS PLEASE CONTACT US AT JULIAN JOHN : 9810124668 ZION TECHNOLOGIES 245a,sant nagar,first floor, East Of Kailash New Delhi 65 (since 1997) 41620696//26435057/58//9810124668/41620840/
Jan 08, 2009 | Apple iPod nano
IPhone 3G Error 0xE8000001
Jul 13, 2008 | Apple iPhone 3G
Apple iPhone Smartphone Logo
285 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
