Question about Canon PIXMA MP170 All-In-One InkJet Printer
The waste ink collector is full how do I empty it?
    President:
  • 2,306 Answers
The absorber is under the print assembly, it is a pad and can't be emptied. It is a shop repair since you have to use Canon diagnostics to reset the count and clear the error.
Posted on Jul 01, 2009
Epson C2600N waste toner collector full warning, after replacing the collector
Victor_Ott:
You have emptied the waste toner bottle, now you have to tell the printer that you have done so. The waste toner collection system has a "latch" (electrical signal) that is tripped when the bottle is full. it may be a pressure sensitive switch under the bottle or a photo-sensor that senses the toner level when full. I don't know the sequence of events to "switch" that latch. Usually on the larger machines it is a series of keystrokes on the printer's keypad, starting with turning the machine off and holding down a series of keys while turning the machine on (known as the "maintenance mode". Once you are in the maintenance mode, you can "trip" that "latch" to let the copier know that the toner collection bottle has been emptied.
Sep 22, 2012 | Epson AcuLaser C2600N Printer
I get a message waste ink abrorber full
Check your manual for the location of the waste toner collector, remove and empty or replace it.
Mar 19, 2010 | Canon Office Equipment & Supplies
Empty the waste ink
Take the printer to a qualified technician.
He/she can "empty" or "replace" the waste ink collector
*AND* "reset" the printer's internal software, to say that it has been serviced.
Nov 27, 2009 | Canon PIXMA MP780 All-In-One InkJet...
What is the wasted ink collector? A sentence appears when I try to print out a page. It tells me that the collector for the wasted ink is nearly full.
there is a waste ink tank that stores excess ink from the printing process.
it is almost full and would need to be cleaned or replaced. and then the printer needs to be reset. Recommend Canon service for that problem, there are instructions for it posted online if you care to look around.
Jul 13, 2009 | Canon PIXMA MP170 All-In-One InkJet...
How do I find waste ink collector
there no any waste ink collector, this printer have only a pad for waste ink, (you don't need to replace first time indication) only take the printer to service center to reset this indication.
or
for immidiate printing -
just switch off printer from main (power) swtich then push and hold the on key and paper key then switch on from power. (it's work some time in some pixma)
Jun 27, 2009 | Canon PIXMA MP170 All-In-One InkJet...
The waste ink collector/tank is nearly full
The ink collector should be found underneath where the cartridges normally rests. Put some tissue paper on the ink padand let it absorb the ink. You might have to repeat the procedure a few times to get rid of all the ink.
May 18, 2009 | Canon PIXMA MP170 All-In-One InkJet...
How do you find the waste ink collector on a printer/scanner ?
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
The waste ink absorption pads are inside the printer, in the very bottom. They are usually soaked with ink when full and are very messy.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
Ink waste absorber
Waste absorber is full. Where is the waste ink absorber and how do I empty it?
Apr 08, 2009 | Canon PIXMA iP1600 Printer
What does Waste ink near full mean
When the printer cleans the print heads it draws ink and disposes it to a foam collector in the base of the printer. Frequent cleaning via software causes this to to become saturated. To my knowledge it cannot be emptied or replaced easily and it is essentially the end of the printers life when full because the excess ink has nowhere to go and cakes on the print head. You can confirm with Canon or check the manual for replacement instructions.
Dec 08, 2008 | Canon Office Equipment & Supplies
Ink collector almost full
100% agreed with rrrdddrrrddd. In addition:
Go to Menu->System->INK CU Replace. You will get a warning that overflow may occur(and it's really a messy job), reset the counter and everything should be OK.
Oct 06, 2008 | Ricoh Aficio GX3050 GelSprinter
Canon PIXMA MP170 All-In-One InkJet Printer Logo
309 people viewed this question
old marine
old marine
