Question about Whirlpool Duet GHW9150P Front Load Washer
My wife found a huge brass colored clamp in the wash machine (appears to have come from the seal) and water is leaking. Where does this clamp go?
  • 3 Answers
Needs new belt
Posted on Jul 01, 2009
Fisher paykel eco smart dripping water on floor front lower right side of unit?
If your machine sounds louder than normal on spin
it could be bad main seal and bearings.
Or it could be those single wire spring clips,
just remove them bad clips and put
radiator hose clamps on your pump pipes.
That will stop the leaks.
Had to do the same on my wife's machine today.
No more nasty's on the floor.
Aug 08, 2017 | Fisher Washing Machines
Leaking from the bottom
either the hoses are cut or the drum seal is bad
Apr 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Machine is leaking water from bottom of unit
If its not leaking from the filler hoses you will have to remove the front cover to see where it is coming from.
Pay close attention to the inlet valves, they sometimes fail.
On one machine I worked on, I found a broken aluminum bolt on the clamp block that holds the basket assembly to the transmission crank.
This allowed the basket to drop on one side and scrub the plastic tub creating a good sized hole.
I replaced both bolts with brass (both brass bolts cost less than one OEM aluminum bolt) and repaired the hole in the tub from the bottom with plastic filler.
Good Luck
Quentin
Aug 07, 2009 | Frigidaire FEX831CS Top Load Stacked...
My washer is leaking from the bottom as if there is a seal that is worn out. what do I do How do I get the tub out to replace the seal
If this is a front loading machine. The bolts on the drum case have most likely loosened. Remove the rear cover to access the bolts. After tighten the bolts run the machine to make sure this was the problem.
Jul 09, 2009 | Frigidaire FEX831CS Top Load Stacked...
Leaks water when washing from the door
It's because of a hole in the door seal body. The water runs down inside the machine and comes under the front of the washing machine
For this first unplugged and then take the top off the washer and there is usually a nut and bolt to undo which is holding a clamp band round the door seal fixing it to the tub.
many cases where the water runs down from the bottom of the door but has in fact come from the soap dispenser but the leak was coming from the door.A thin line of water trickles from the soap dispenser and runs round the door frame to appear as a door seal leak. Make sure this isn't the case.
Thanks.
Kevin
Jul 04, 2009 | Whirlpool Washing Machines
GE model number WCVH6600HWW with a huge tear
I have the same problem and I'm thinking of trying to replace the boot myself. I found this at ehow.com. The instructions and pictures seeem pretty good.
http://www.ehow.com/how_5651102_replace-front-load-washing-machine.html
Jun 04, 2009 | GE Energy Star WCVH6260F Front Load Washer
Front door leaking during washing cycle
There are only two ways that water can leak out this way. it can be either the door seal or the door lock mech has become misaligned, causing a slight gap that is letting the water escape through.
I recommend inspecting the door lock mech for its integrity. make sure it is aligned correctly to specs. replace this mechanism if found to be faulty or misaligned. i would also inspect the seal for tiny ruptures as well. the slightest rupture or hole can allow small amounts of water to excape.
Inspect these areas thouroughly.
May 31, 2009 | Frigidaire Washing Machines
Water leaking from under washer
Hi
You'll need to open the machine and check for the leaks in the hose connected to the drain pump. Also check if the clamp connecting the drain filter and hose is tight. Also check these things for leaks---
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you'll need to replace it.
Please do rate this solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE Top load washer.
Hello rschneeweis
Welcome,
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Huuum
Please remember to leave a rating
Oct 04, 2008 | GE WBSR3140D Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
54 people viewed this question
Dan Webster
Dan Webster
Sal De
