Question about Cameras
Some times I got an F0 when I want to take a picture and I dont get any picture even though the it keeps shoting. Why? What I should do? Thanks, Federico
  • fvarona Jul 01, 2009
    Thanks! I have some questions about your answer:
    First, what and where is the the menu?; in my Camara Nikon 300 or in Tamron Lens 18-270mm?
    Second, what and where are capture opitions?
    Thanks!
    Federico
  • 10,515 Answers
This is due to a bad contact caused by improper "registration" of the lens and body contacts when the lens is mounted - there was a fraction "too much rotation" with the lens in question. If the lens electronics is faulty, mounting it on another (fully working) body ought to give the same result.
First thing to check is to see if your Fn button, the lower one on the right side of camera if your looking at the LCD, and make sure you dont have the HDR turned to anything other than 0. If that doesn't work then put the lens on and twist it, or rotate to make sure the contacts are lined up and its properly mounted.
If problem still persists, you need to contact Nikon to get it repaired. Many people are facing this issue on D 300 and D 80, still there is no update from Nikon.
Hope i helped you.
DO RATE THE SOLUTION.
Thanks for using "Fixya".
Posted on Jul 02, 2009
  • 50 Answers
You should go to the menu and go to capture opitions then ajust our focuse and shutter then you problem will be fixed.
Posted on Jul 01, 2009
Double wall oven F0 error code
The F0 error code means that the control board has detected a defect within the control board itself, the F0 code can be cleared by pushing the CANCEL/OFF button and if it goes away and returns all is well,however if a short time later the F0 returns the control board would need to be replaced.
GENE
Oct 04, 2011 | GE Profile 30" Built-In Double Electric...
AUDIO NOT RECODING AT TIME OF VIDEO SHOTING
hi!
Try adjusting the settings of the sound or audio. maybe it had been lowered down. The mic should be on and volume level should be set to max to grasps the video still settings. Dont cover mic when taking videos. It will result to quality of voice.
Jonags
Dec 31, 2009 | Sony Cyber-shot DSC-T77 Digital Camera
Can i use jazz jdc25 as a web cam
I dont think so ...cause this means to keep it in shoting mode and it doesnt accept the cable in this way ...but you can try with some models of mobile phone ...or with a mini dv camera ..or any other camera video.....
Jul 30, 2009 | Jazz JDC25 Digital Camera
Running out of color ink even though we dont use the color
It's probably not running out but drying up. Make a color copy from time to time to keep the ink fluid.
Apr 09, 2009 | Brother Office Equipment & Supplies
Whay my mp3 writes dont error shoting down ?
The Opal has a reset hole on the back of the unit in which a toothpick (non metallic) can be inserted to reboot the player. If this does not work, I suggest that you reformat the player by using the Windows format command on the unit. To reformat the memory:
Right click on the device within the Explorer or My Computer window
Select the format command (full format) to reformat the internal memory of the device.
Reinstall the firmware from http://download.rcaaudiovideo.com/downloads/opal_fwutility_v2.3.0.exe
Dec 03, 2008 | RCA OPAL M4001 MP3 Player
326B1230P001 GE TrueTemp Black Oven Error Code F0
We had the same problem with our GE Tru Temp Oven and the fix worked like a charm! Thank you for posting this fix - you saved our dinner party!
Jun 21, 2008 | GE JKS05 Electric Single Oven
GE Profile Performance Double Oven
I was getting only the F0 error code. The wiring diagram inside the stove said F0 indicated a bad off button on the keypanel. There were instructions to check the ribbon cable on certain lines, with values for the resistance. It seemed to check out, so I ordered a replacement and voila, it worked.
Jun 11, 2008 | GE Profile JTP56 Electric Double Oven
A95 Start Problem
I'd suspect a broken ribbon cable connector latch where the keypad matrix ribbon connects to the main board.
Aug 30, 2007 | Canon PowerShot A95 Digital Camera
Cameras Logo
50 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
