Question about Troy-Bilt Garden
Bought a new part to hold the starter cord for my tiller
Bought a new part to hold the starter cord for my troy bilt gardenway tiller. put it on but the cord just keeps coming out when i pull it and it won't start. what am i doing wrong
  • 376 Answers
I don't know exactly what you have there, but starters in general work pretty much the same. What you have to do with any starter when you replace the rope is to first wind the spring with the pulley. Turn the pulley in the direction it would be turning if you were pulling the rope. When it's wound tight, back off to align the rope hole in the cover and the pulley. Stick the rope through from the outside through the cover and pulley and tie a knot. Then let the spring tension pull the rope into the starter. Hope that helps. Dwain
Posted on Jul 01, 2009
This is a Troy Bilt Big Red Horse Tiller. Wont crank. new battery. ignition switch good. starter relay clicks when ignition switch turned. jumpering the relay makes the starter spin.
The starter solenoid/relay clicking can mean a bad starter solenoid/relay or bad grounding. Not knowing what engine you have as they have used Kohler, Tecumseh and Briggs and Stratton over the years. hope this helps
Mar 06, 2015 | Troy-Bilt Garden
How do i replace drive belt on a gardenway lawn tractor 16.5 hp 42 inch cut hydrostatic drive troy bilt gardenway
how do you install a drive belt on a 46 inch garden way troy bilt riding mower
Jul 26, 2010 | Garden
I have a troybilt pony tiller made on 1/22/79. On the transmission there is this number P35944...at least it looks like a P, not sure on that digit. Farther back on transmission near the tines, there is...
One is a serial number and the other is a part number ... This tiller was built in Troy, New York by Gardenway Manufacturing. Unfortunately, that family owned company is out of business. Whether there is still manufacturing in Troy New York, I am not sure but it is not the same company today as it was in 1979.
The assets, including the name, were purchased (and some sold) by several manufacturers, notably, MTD. The Troy products sold today are similar to the Troy products of the Gardenway Manufacturing. In my experience, there is no better customer service than that I received from GardenWay. The 6.5 was a big Pony ... I purchased a Horse about the same time and it is a 6.0 hp Techumsa. I am on my second engine and I wouldn't take twice the $ for it.
This tiller probably cost in the vicinity of $800.00 delivered.
There is a company in Canada that has specs on most Troy Models ... and access to lots of Troy parts, though thre are lots of other places that sell parts and have diagrams as well.
At one point Briggs was making 'flails' for the Troy Chipper Shredder ...
I hope this helps you with your tiller ... It is a teriffic machine.
Here is an interesting discussion board ... if you are interested: http://forums2.gardenweb.com/forums/load/tools/msg1108413014912.html
Thanks for your interest in fixYa.com
Jun 29, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Broken pull cord on my manual start Troy-bilt Pony tiller - is this an easy do-it-yourself project?
It's definitely do-it-yourself in that no special tools or skills are required, but it can be a little tricky. You can see that the the recoil starter is in an assembly which is spot welded onto a metal cover. You have to remove the entire metal cover that includes the recoil starter. There may be 6 to 10 screws to remove to do that. When you get it off you will see a plastic spool that holds the cord. This spool is probably held in place by a couple of metal tabs that are bent down. Bend those tabs up with pliers. Underneath the spool is a spiral spring that provides the recoil. Take careful note of how this all goes together. Buy a new cord (available by the foot at a hardware store) and wrap it around the plastic spool. Use a piece of tape to hold the end of the new cord above the spool so you can thread it through the hole in the metal housing later. Put the spring and the spool in place, then wind the spool to put tension on the spring - about 5 turns in the direction that would push the string out through the hole. Once you have the spring "wound up" remove the tape and thread the end of the cord through the hole. Now bend those metal tabs back down. Put the handle on the cord end (or tie a knot) to keep the spring from pulling the end of the cord back through the hole. Reassemble the rest and you are in business.
Jun 15, 2010 | Troy-Bilt Pony Garden Tiller
Troy bilt hasn't been used in 2yrs.; has oil and gas in it but will not electric or pull cord start...
1st I would drain the gas and put new in. It loses octane over time. Then try new spark plug. Also you may need a new diaphram in the carburetor. They are cheap and sell them at most hardware stores.
Dec 20, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I have a old troybilt tiller Gardenway Model and need to change the drive belt. How?
Get your model and serial number handy and go here to download a free manual:
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
Sep 18, 2009 | Troy-Bilt Garden
I have an older Troy-Bilt Pony Garden Tiller witha
From what I read you need a new rewind clutch and the spring and cord go into the housing. Briggs is easy to fix. contact me at kerryjonjon@yahoo.com and I can send you what you need or you can send it to me and I will repair it very cheap!! Parts are available at almost any small engine parts place.
Jul 17, 2009 | Troy-Bilt Pony Garden Tiller
Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
May 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I just purchased a troy bilt bronco crt tiller. Put oil and gasoline in. Pulled the cord. It started. Ran maybe 15 or 20 seconds and stopped. When I tried to start it again, the cord would not...
remove the spark plug.  And pull the cord again.  if the carb float is stuck down or you overfilled the oil you could be hydro-locking the engine.  Check.
Mar 29, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Garden Logo
349 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
