Question about Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite cycle button keeps beeping and switching from on to off
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!
Posted on Sep 15, 2010
How do I stop my washing machine door alarm beeping?
do this and fix it. God bless you
However read the instr. manual section troubleshooting /
if doesnot have download from www.fitness.manualsonline.com
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Sep 28, 2012 | Hotpoint WMA74 Front Load Washer
My Kenmore Elite Oasis washing machine has error code "UL" while in rising cycle and stop. Can you tell me what is the problem and how to solve it.
My Kenmore Elite Oasis washing machine will drain but not spin and it keeps jumping back and forth to different time cycles. It continually reads "UL" and I keep trying to adjust and balance the load but it does not help.
Jun 25, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore Elite washer, Model 110.20096993, it starts beeping with about 10 mins left in the cycle and shuts off. Any thoughts?
I have the same model - it displays 10 minutes and keeps beeping in series of 3 (beep beep beep...... beep beep beep... etc..) ran through a cycle successfully but kept beeping like that the whole time. I unplugged it for 10 minutes but had the same symptoms after plugging it back in. I unplugged it for 24 hours, and that seems to have cleared the problem up.
Jun 12, 2010 | Kenmore Washing Machines
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
Cycle Signal keeps beeping loud-soft every 15 seconds while dryin
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
peter
Apr 21, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
My kenmore elite he4 dryer-model#110.95087401 keep beeping and the end of cycle lights are going on from off to high and back to off right through the drying cycle.
I had the same problem and eventually none of the cycle buttons light up or the cycle time display. So it would not run at all. After taking it apart once and fiddling with the cycle push buttons, it worked for one load then would not work again. I could see 3 of the led faintly illuminated and unplugging and plugging back in the power changed nothing. Then I removed the plastic ring of cycle buttons that is between the panel circuit board and the outer plastic. (There a several layers to get to the ring.) Now I use a long allen wrench to push on the switch on the circuit board. I left the middle start button in place. That does not seem to cause a problem. Several loads now and still working. So it looks like the ring on plastic buttons don't release from the circuit board buttons causing a problem.
Feb 21, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite washer cycle signal keeps going off an on turing cy
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Jan 04, 2009 | Kenmore Washing Machines
Kenmore Elite Oasis 110.6703 is BEEPING!!! ARGH!
repl./// user interface board stuck button common problem
Oct 13, 2008 | Kenmore Elite HE4 Electric Dryer
Cycle Signal Beeping
The user interface button panel has failed and will need to be replaced.
Apr 19, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Oasis 27052 Top Load Washer Logo
89 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
