Question about Pool & Spa
I have a bestway 10 ft pool, filter making loud noise, doesn't seem to be working. Its only been in use for the last 2 days, tried releasing air, makes no difference.
  • julie_66 Jul 01, 2009
    the pump is a Flowclear 58145, I've cleaned the filter
    it seems like theres air trapped in water inlet/outlet
    tubes. I've used the air release and taken it all off the pool and started again. Its better than it was but still noisy. Thank-you for your help.
  • 83 Answers
Normally, the filter does not make any noises! The noise is generally from the pump. Since I am not sure what you have on the pool, to be able to find the issue, we will need a bit more information.
Do you have a seperate pool pump and filter? The pump will have a motor and some have a debris basket in front of the motor. If this is where the noise is coming from, you may want to return/exchange the pump if it is only two days old!! When you turn on the system, do you see water moving to the pump, air in the basket, or is the motor getting hot to the touch?
If you have a seperate filter from the pump, what is the pressure gauge reading on the top? If you have one, check it when the noise starts. If it is higher than it was when working properly, you have a blockage somewhere from the filter to the return line. If lower, then you may a small leak, generally o-rings, and will need to replace what is bad.
If the motor on the pump is making the noise, then it can either have debris in the Impeller area, or it is going bad. Hope this helps! If you can let us know what pump and flter you have, we may be able to find out what is going on.
Posted on Jul 01, 2009
My pump is the same as yours. It has also developed the loud noise. I opened it and found that the impeller is worn. Its hole is too big and not concentric with the magnet. This causes it to rattle on the pin which sounds a bit like it is sucking air. I am struggling to find a replacement impeller. Does anyone know where we can get one? I am in New Zealand
Posted on Feb 24, 2013
Filter working but making noise
This is an inexpensive product put out by China Manufacturing. So sorry to say, but you probably knew this as well, it is not of high quality and was not made to last. It actually is considered a Toy.
It sounds like you need to either live with the noise or replace the pump. I would recommend that if you can find it in the budget, upgrade to a real Pool Pump. Ask your local service provider or retail pool supply store about such an upgrade. But your pump is failing.
Good Luck.
Apr 29, 2015 | Intex Krystal Clear Model 635 Pool Filter...
Pool pump makes a loud noise
bad bearings change pump and motor
May 14, 2014 | Waterway Impeller Pump 2HP SD WW
Error after short prime cycle
AIR LEAK IN SUCTION LINE. PUT A GARDEN HOSE WITH A RAG AROUND IT TO BACKFEED FROM INTAKE IN POOL. WITH PUMP "OFF" TO LOCATE BREECH IN LINE.
Apr 21, 2014 | Pentair IntelliFlo VF High Performance 3HP...
Loud noise on occassions like a hoot very loud
Could be a slipping fan belt . The sound wears off after a minute or two.
Jul 31, 2017 | 2000 Ford Crown Victoria
Make loud noises on spin cycle and smoke when we open door
The loud noises seem to be a feature of newer front loading machines. We bought a Maytag and have had similar issues since day 1. We were told the bearings are the problem. They don't last and make major noise as they wear.
Oct 28, 2013 | Samsung WF316BAC 3.79 cu.ft High...
Timer on chlorinator will not go on after 24 hours
The 24 hour timer is probably faulty and needs to be replaced.
Jun 04, 2012 | Bestway Usa Type 2 or II Bestway...
What is the best time of day to run the Salt Water System...Morning, Afternoon or Evening?.....and how long? Manual says run for about three hours but that doesn't seem enough...we have been having...
I have an 18 X 33 oval and temparatures here range from 80 to 102 in the summer. I run my cycles at 10 to 12 hrs pump with 8 to 10 hrs chlorinator. Water stays crystal clear, no cloudy.. Now...if you don't keep the electrolytic cell clean and maintain the proper salt levels, you will struggle with making free chlorine...
Hope I helped??? AND... I HAVE NOT ADDED ANY CHEMICALS TO MY POOL IN THE 2 YEARS I'VE HAD MY INTEX SYSTEM...
Jul 18, 2011 | Intex Automatic Salt Water System for ...
We have a hayward xstream pool pump for our 18' above ground pool that my daughter got through make a wish last august. we cleaned the cartridge yesterday and when we replaced the cartridge it started...
Try taking the pool filters cartridge out and following these steps to make sure that it is installed properly.
1. Clean debris from bottom of filter tank.
2. Replace element evenly on the collector hub in bottom of the filter body.
3. Place lid evenly on filter body and turn Easy-Lok™ ring clockwise until the safety latches engage securely.
4. Close and secure drain plug (located at the base of filter body).
5. Open air relief valve (Turn lever to left).
6. Open valves (Optional suction & return valves).
7. Prime and start the pump.
8. Once air has escaped the filter and a steady stream of water is flowing from the air relief valve, close the air relief valve and note the pressure gauge reading.
Jul 15, 2010 | Hayward Pool Products Hayward Xstream...
I have a Sta-Rite pool filter. In the start up procedure, you are supposed to bleed the air until a steady stream of water flows from the air release valve. Although I have confirmed that everything is...
Hi sstanl, Is your pump output or flow normal back to pool? if there is no water flowing through system you will get no expulsion of air or pressure reading on gauge. If pump is working then you probably have a clogged air release valve and maybe a clogged gauge. Just remove air relief assembly from filter top, remove gauge and clear any obstructions in parts. You should easily be able to blow air thru assy with gauge removed. Teflon tape the components and snug them back in their places. restart your pump and voila! air will come out when prime is established.
Apr 23, 2009 | Sta Rite Sta - Rite Mod Media 450 Sq Ft...
Pool & Spa Logo
980 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
