Question about Karcher Garden
Have 5.0 karcher, and it will not sray any water or pressure out the gun, WHY??
    President:
  • 2,923 Answers
Make sure that the lance is not blocked and the control valve is ON. Oil coming out of air filter,too much oil in engine,or oil too light should be 30wt, air filter dirty, over speed of engine,these are the only things that can cause this problem.
Hope it helps and have a great day!
Posted on Jul 01, 2009
  • Melvin Ramos
    Melvin Ramos Jul 01, 2009
    It is important that you must have mentioned the model number of your
    Karcher. Just the same I can surely say that your machine's fault lies
    in the "SPILL VALVE"
    When the gun is open and pressure is being produced, the spill valve is
    in a relaxed position. Also it has at the bottom a valve, which when
    pressure is produced it is closed. If this does not close due to dirt
    or corrosion, the pessure goes down. Now when you close the
    gun,pressure forces the spill valve down to close the electrical
    system. Now if the "o" rings of the spill valve are damaged, the
    machine will start going on and off while in stand-by. So if you know
    how to locate the Spill Valve, all one has to do is change it with a
    new one.
    In some Karcher machines there are 2 spill valves. One regulates
    pressure and the other one is for switching off the machine when the
    gun is closed.
    Low pressure could also be due to faulty suction or delivery valves. Most probably the suction valves.
    But when saying that there are short interruptions while in stand by, I stick to the fact that the spill valve needs renewing.
    Thanks,
    Firesnake09
I have a karcher hds 601 have replace pup seals and the water presher is still down to 25psi what els cud it be
It could be that there are faults wit the suction and delivery valves.
Also, there could be a fault with the pressure regulating valve (Spill Valve). Also if it has ( must have in fact),....a safety valve, see that it is not leaking. Other things one can check are, the gun, the nozzle of the gun, the amount of water being fed and any minor leakages.
Regards,
MG.
Oct 06, 2014 | Karcher Garden
My karcher pressure washer 520 M is leaking water from the hand gun
You should watch the video on this blog. This is a very common problem, because the original gun/wand on many pressure washers is the same! However, Prism Teachings observed something that you should know about its design: http://electricreplacementgun.blogspot.com/
May 22, 2012 | Karcher K2.26 Electric Power Washer
Water gushing out of gun handle
Looks like the frost has damaged your gun. A new gun is required.
try this link for spare.
http://www.sparesgiant.com/c-19-pressure-washer.aspx
Mar 28, 2011 | Karcher Garden
Water leaking from spray gun
It depends on were the water is leaking from on the gun. If the water is leaking from were the high pressure hose goes into the gun it could be that on oring as been damaged. If the water is coming from the trigger you may need a new trigger gun.
If you tell me your model number (1.xxx-xxx.0) i can tell you the part number that you will need to give to your Karcher dealer/supplier to replace it.
Jan 02, 2011 | Karcher Garden
Engine runs , not getting any water flow when trigger pressed.
Disconnect hoses.
Look for kink in water hose.
Check incoming water connection for filter washer
Replace filter washer
If you don't have a filter washer, put one in.
Hook up water, and turn on
Water should come out other side of pump.
Turn on machine.
Do you get pressured water out of pump.
If no pressure, then pump is suspect
Hook up washer hose without gun
Does pressure come out of washer hose
Finally, the gun trigger may be bad.
We had to buy guns now and then.
Search for pressure washer guns
Following link shows guns we used:
http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
Oct 25, 2010 | Karcher G2650HHR Gas Pressure Washer
Karcher Model K 2.40, water is leaking from the gun at yellow trigger.
You are going to have to purchase a new trigger gun, they don't offer any parts for replacement on the inside of this trigger gun. See this link to purchase a new one.
Oct 08, 2010 | Karcher FactoryReconditioned K240R 1400...
Faulty
water is pouring out of my 5 year old karcher from the trigger handle WHY???
May 22, 2010 | Karcher PSI Electric Pressure Washer
Hello there.My Karcher pressure washer motor constantly runs with no pressure coming out of trigger gun.I have tried another gun with the same result.The motor should stop/start when you press gun.The...
The valve that admits more water to be compressed is stuck. It is likely the O-Rings on it need replacing. No water to the pump, no pressure!
The motor will stop when pressure is up to the designed pressure.
Oct 03, 2009 | Karcher Garden
Karcher K 3.68 M operation
These units have pressure valves that automatically turn off the pump once the pressure is high enough. The pressure switches do fail and sometimes stick and act as you've described.
May 07, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
Garden Logo
124 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
