Korg D16xD digital recording CD tray broke
Small chip in the upper left side of tray that holds the medal glider broke.  Part can be view in the D16xD manuel.
Called Korg and then said I had to replace the whole cd writer the problem is that the writer is o.k. it is the CD disk tray of which does not come with the CD writer.
Called there authorized dealer and was told that Japan may not be sending that part to the USA and that they would get back to me.
In the event that the CD Tray cannot be repaired can I use my Tascam Cd/RW 402 to preform the funtions of the Korg CD writer?  It shows the manufacturer of this part as the TEAC Corporation.  When checking there site I somehow got you your site.   Any suggestions would be appreciated.
Daryl
  • 112 Answers
SOURCE: TDK DA 3826 disc tray not functioning
Is the motor spinning to try to open the drawer?Can you hear it? Can you get something under the tray edge to try to 'help' it out when pressing eject?
Posted on Feb 20, 2008
  • 28 Answers
SOURCE: cd dont revolve in player
This sounds like a problem with the CD motor. As CD players get used a lot, the motor gets worn down and eventually stops working. If you get a lot of dust in the player, this can also slow down or stop the motor. If you feel like frankensteining the CD player, you can try and see if there is any dust. If you like this perticular cd player, I would suggest going to a electronics repair shop and have them take a look, but with the prices of portable CD players these days, you might be better of just getting a new one. You may even find one with better features at a lower price.
Posted on Mar 30, 2009
zohail
  • 1223 Answers
SOURCE: Does not recognize CD in try
if it is a cd reciver open up the cover and look for eye like shiny lens it is below the loading mech u may have to get some stuff out first for the access to lens when u see it take a tissue paper and clean it in cicular motions 10 to 12 times and then re fit
if u are not technical just but a cd lens cleaning around 2 $ cheap with brushes installed put the thing in and it will do the job but i think manual procedure is good for that
otherwise ur LENS is finished get a new player u cant find parts so cheap but u may at EBAY
pls rate me WELL !
Posted on May 17, 2009
  • 130 Answers
SOURCE: CD Rom tray stuck
does the case a a faceplate infront of the cd rom drive(i.e. if there is a door that flops down when it opens)? if so you probably need to take off the computers faceplate and then you can get to the little hole.
Posted on Jun 14, 2009
SOURCE: i cant open my cd tray on my tascam dp01
Look on the front of the CD tray for a little hole... push the end of a paper clip in the hole and the tray should open.
Posted on Dec 13, 2009
Broken disc tray
Hello,i have a problem with my Philips CDR 770 CD. .. I purchased lately on the internet 10 CD digital audio VERBATIM,but will not read them ... only reads the Philips digital audio,writable and rewritable,the repurchase ... I hope you can solve my problem ... THANKS
Mar 22, 2014 | Philips CDR770 CD Recorder
Philips cdr778 play side door
remove cover and disassemble the tray carefully, and see if it can be put back together/ reset in the tracks. Hope fully nothing is broke and your back and runnin.
Nov 13, 2007 | Philips CDR778 2-Disc CD Recorder
How do you install RAM?
Installing RAM on the keyboard is just like installing RAM in your typical computer. Unscrew the plates off the bottom of the keyboard and underneath you will find two parellel slots (usually beige colored) for the memory chips to go in. Simply place the memory chip in the slot. The memory chip has to to be a specific type of memory chip, does not take regular computer RAM. You can find specific kinds on sites such as ebay. Just type "Korg triton RAM" in the search bar.
Jul 17, 2012 | Korg TR76 76 Key Synthesizer Workstation
My xbox360 wont read load any games
Take your xbox apart and get into the drive. Order a laser from Ebay for $8.99.Open the tray by using a small screwdriver and spinning the belt in the front to the right. Take the upper left clip holding the left rail out with the tray facing away from you with a phillips screwdriver. Then loosen the screw on the lower right until you can turn it upside down and shake the clip out of the way, you don't need to take this one all the way out. Pull the rail on the right, tray still facing away from you, out far enough to release the right side of the laser, unhook the ribbon cable, pull upwards on the left rail where you took the first clip out and slide the laser off the end. Repeat in reverse with the new laser and there you go. Don't forget to remove the solder ball (anti-static solder joint) from the laser first. Hope this helps.
Apr 19, 2012 | Microsoft Video Game Consoles & Games
Makes noises when dvd is inserted
If it loads normally I would not worry about, keep in mind they use more plastic than metal and noise on loading is more evident.
Apr 02, 2012 | LG RC-197 DVD Recorder/VCR
I have a Harman Kardon CDR2 and the cd drawers will not open. Do you know how to fix this?
hi jlcady
sounds like the belts need to be replaced. for that the units eject mechanic assy has to be disassembled.
feel free to text for further assistance.
regards
Feb 13, 2011 | Harman Kardon CDR2 2-Disc CD Recorder
CAN,T DETECT CD IN BURNER TRAY
laser failure on the recording side is very common on marantz and philips cd recorders.
they're well known for it.
so it's most definately the laser in your case.
hope this helps.
Jun 19, 2009 | Marantz CDR500 2-Disc CD Recorder
Jan 05, 2008 | TDK DA-3826 2-Disc CD Recorder
Help
The best way is to download the manual from www.korg.com and read it. But quite simply:
Using the basic sequencer:
Realtime:
Realtime quantizing is done by selecting the "Reso:" near the upper right side of the screen at the main sequencer screen. Setting it to "Hi" turns it off. Any other selection sets it to that step for quantizing. Record your track as normal.
Previously Recorded Data:
Press "Menu" at the sequencer screen and select "Track Edit". From the pull-down menu in the upper right corner select "Quantize Track". If you don't see this option at first, scroll the the right. It should be the last one or near the last.
Nov 09, 2007 | Korg Legacy Collection
129 people viewed this question
 Grubhead
Grubhead
