Question about ViewSonic VX910 19" LCD Monitor
ViewSonic VX910 monitor appears to have power supply issue. The power light comes on for less than 1/2 sec, then goes off for about 1 sec, then just flashes green. If you play with the switch and the A/C plug sometimes you can get it to operate correctly.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 194 Answers
Try running the self test on the monitor
Self Test:
turn off the system disconnect the data cable from the tower and connect only the power cable to the monitor and trun on the monitor if you see colour full bars then the monitor is ok then try to go BIOS and see if the monitor is working
Posted on Jul 01, 2009
I have a ViewSonic VX910 LCD monitor. I turn it on and it comes on for a second then goes black. I did replaced all five capacitors in the power supply board, but it didn't help, still the same problem....
AllI can think of is that a tripler or inverter could be breaking down, causing the unit to go into auto
shutdown mode. Some devise is breaking down, and causing the unit to shut down.
Not an easy problem to troubleshoot unless you've got a schematic and tech skills.
Hope this helps
Mar 26, 2011 | ViewSonic VX910 19" LCD Monitor
I turn it on and it comes on for a second then the goes black
You need to open it up and inspect the capacitors (look for bulging top/seal), burnt inverter transformers, resistors, etc. in the power supply/Inverter board first, post back what you find so we can guide you further. See example of failed Viewsonic monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 16, 2010 | ViewSonic VX910 19" LCD Monitor
Monitor turns black after 2 seconds, Viewsonic VX910
Check the power supply first for bad caps, then check to see if you do have 12vdc feeding the the inverter circuits, worst case will be the lamps, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 21, 2010 | ViewSonic VX910 19" LCD Monitor
My screen turned black and began flashing.
Kim, The LCD display requires WHITE light so you can see all the colors on the screen. Most BLACK screen problems will be a power supply problem internal to the monitor. I monitor is still under warranty, have Viewsonic repair it. Here are a few more options that could be available if unit is out of warranty. 1. Trade in for new widescreen display. Please note that the electronics technician at the store will evaluate your monitor and try to repair it for less than $10 in parts! He or she will keep it as a spare unit or sell your monitor for $40 - $60 to a buddy that needs a spare or second monitor. 2. Check to see if Viewsonic has a CASH+old unit swap-out program. They ship you a REFURBISHED same model unit w/ 30day warranty. Yes! They will REFURBISH your old monitor and ship it to another customer. But that's only if a swap program is in effect! 3. Check with a local TV/LCD monitor repair shop, to see if they refurbish LCD monitors with new or rebuilt "switch-mode-power-supply" / "inverter supply" / "cold-cathode-fluoiescent-lamps" . 4. Most costly option. Buy new display AND have your VX910 repaired and kept as spare unit! Before you do any of the above mentioned options visit (FYI) YOUTUBE and search for and view the longer (8-12 minute) video clips of "LCD monitor repair" and "LCD monitor disassembly" to learn what the most common causes of LCD BLACK SCREEN failure are and what parts are used to fix them. Also visit www.ccl-la.com/badcaps.htm and www.lcdparts.com , www.badcaps.net for more information. If your VX910 falls into the FAILED CCFL backlight catagory get back here to fixya and let us know what option you will persue. If this was helpful to you or someone else, rate this response on fixya. 12fixlouie by for now.
Nov 04, 2009 | ViewSonic VX910 19" LCD Monitor
Looking for a 715L1075-1-v Ver B power supply
>> 715L1075-1-V1 PC MONITOR - POWER SUPPLY FOR VIEWSONIC N/A TV
Once you have the _correct_ part-number, you can buy it online:
http://www.discount-merchant.com/We-provide-factory-original-parts-worldwide-p/1049626-viewsonic.htm
Sep 19, 2009 | ViewSonic VX910 19" LCD Monitor
ViewSonic VX910 monitor has a power supply issue.
Your monitor have a bad condensator in the PSU.
The only thing to do is to replace the Power Supply Unit (very expensive, more than a new monitor) or if you have electronic tools, found and replace that condensator.(cheaper way...)
or
Have you connected your monitor with a new power cord ?
Best Regards!
Jun 29, 2009 | ViewSonic VX910 19" LCD Monitor
Power light blinking on and off
You will need to replace the below failed caps.
2 - 1000uF @ 10V
3 - 470uF @ 25V
1 - 470uF @ 10V
May 18, 2009 | ViewSonic VX910 19" LCD Monitor
No power to monitor despite being plugged in
Check your video card. Is your computer booting up?
May 25, 2008 | ViewSonic VX910 19" LCD Monitor
ViewSonic VX910 19" LCD...
I had the same exact problem. I pulled the power supply/inverter board out and found what alot of people have seen. The T1 transformer has blown. Replacement board link here.
Apr 22, 2008 | ViewSonic VX910 19" LCD Monitor
ViewSonic VX910 19" LCD Monitor Logo
362 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
