Question about Panasonic Audio Players & Recorders
Panasonic RX ES27 Power supply problems. The machine works with batteries, but the mains supply would be lost after about an hour's playing - then 45 mins then 30 mins until now it will not work at all on the mains. Taking the top off, the fuse in the mains power supply is ok. Where to go from here? Are parts available for this model or can the power supply be repaired?
tom19511
  • 1601 Answers
SOURCE: Compaq Presario Laptop lost power
the battery charger board, is what I would swap first.
Good luck, keep us posted.
Posted on Nov 15, 2007
ctf1800
  • 4402 Answers
SOURCE: INFOCUS LP240 POWER SUPPLY PROBLEM
Caps being burned. caps usually go bad or explode because of to much voltage, was it hit by lighting?
But you say the fuse is ok... I would look for voltage regualtors or resister type fuses that are blown.
you might want to check with ptscorp.com to see if you can send in the power supply.
Posted on Feb 06, 2008
SOURCE: dead set
Im not sure if this will fix your tv, but mine was powering off intermittently. I found a defective
2200uf Capacitor on the power supply board. Take a look at the top of the capacitor cans,
mine was popped up an looked damaged.
Posted on Jan 27, 2009
SOURCE: TV does not appear to be powered. Either fuse or power supply
The fuse is in the power supply. It's a slow blow fuse rated 250V 5A.
Posted on Aug 20, 2009
  • 125 Answers
SOURCE: Steam iron trips the main fuse
It could be your iron drawing too much current but it sounds more likely that you have a weak circuit breaker on that circuit. You might try the iron on a different house circuit to confirm if its actually the iron or the house breaker giving you problems.
Posted on Sep 07, 2009
My RX-V2095 Yamaha receiver won't power up.
Wont power up, or stuck in "protect mode"? Unplug the unit & let it sit for a couple hours, then plug back in & listen for a "click" a turn (power supply relay energizing.) If no lights & no click, the first place to check is the mains fuse. If the unit is under warranty - take to an authorized facility & they will take care of it for you.
Oct 20, 2014 | Yamaha Rx-v2095 7ch Flagship Home Theater...
Have an electric run pellet fire what size car or truck battery to run for 8 hours 520 watts
You'll need a 600W (Minimum) 12 to 240V Inverter as in the link below.
http://www.powerinverter.co.nz/16-10-12v-to-220v-power-inverter-600watts.html
As for the battery you will need 44Amps of Battery Power for every hour you want to run the equipment (this is without any losses from the inverter on inefficiency from the battery). You would therefore need as a minimum 2 x 200Ah 12V Batteries connected in parallel for something like your 8 hour duty. You'll also need them to be this sort of size so that they can supply the high current for a long duration. i.e. a 44Ah Battery would not supply 44Amps for 1 hour.
Hope this is OK and please leave feedback.
Cheers
Andy
Apr 30, 2011 | RaidMax ( RX-520XP) 520-Watt Power...
IT WILL NOT POWER UP
Will the unit run on batteries, if so! the ac power going into the power supply is the problem. The fuse or the power transformer are most likely the issues. Now if the batteries or ac power do not power the radio then we probably are looking at processor ic problem. The cost to repair should be questioned.
Dec 30, 2010 | Panasonic RX-D29 Radio/Cassette/CD Boombox
I have a problem with the pioneer elite pro hd510. it only play for 45 to 50 minutes, than i will have to unplug and plug it back and it does the same thing all time. i love this brand, i just want to know...
I have the same TV and the same problem. Mine would play for a few hours then "pop" and power off. I had to turn main power off, let sit for awhile then it would play again. My local repair place came out and installed new power supply but that wasn't the problem. Had to take set to the shop where they found I had a bad amplifier board. It's on backorder with Pioneer.
Dec 20, 2009 | Pioneer PRO-510HD 53" Rear Projection...
Yamaha RV-V2200 without power loses settings under 24 hours
It could be a battery, a bit like the type you get in watches. But I reckon it's a memory retention capacitor that has failed. These are small looking things that look like electrolytic capacitors that have been squashed from above. They appear to have a working voltage of around 5.5 volts too. I am enclosing a picture of one, though it could vary in style. You might find it near the main display of the unit.
Apr 30, 2017 | Yamaha RX-V2200 Receiver
I left my Compaq 2510p on standby with the battery low a couple of hours ago. I have now connected it to the mains charger and tried to turn the machine back on, but it won't turn on...any ideas what I...
Might be stuck in hibernation. Pull the battery and ac power for about 1 hour. Replace and try to boot. If fails, pull the battery and try to boot just off ac power.
Dec 01, 2008 | HP Computers & Internet
Panasonic dvd recorder model dmr-e55eb/ebl. played dvd,no problem - ejected dvd - green/blue colouring appeared on TV which disappeared when dvd recorder switched off. since then unable to play dvds. ...
This is a problem with either the logic or the power supply. Without seeing the machine and taking measurements inside, I can't state for sure the exact problem. These are decent machines. I would suggest that you bring it to an authorized Panasonic service center for a repair estimate. Post the results here and we'll suggest the next steps.
Dan
Apr 23, 2008 | Televison & Video
Lose time and date stamp on power off
According to the manual, you need to power up your 710 with the AC adapter for 4 hours to recharge the internal battery. If this doesn't work, I suppose you need to replace the internal battery, and that's beyond my knowledge.
Sep 07, 2006 | Panasonic PV-DV710 Camcorder
132 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
