I have a phonic powerpod 7. the speaker connections are A & B main 1 & the same main 2 in the middle there is 1 1/4 jack socket that says bridge. it says dont connect any speakers to a or b when switch is in BRIDGE MODE. Well i did not see this notice & with the speakers pluged into A & B I turned of the amp switched to bridge mode but got no sound. when put back to main 1 & 2 I get no sound at all. what has this caused to go wrong. sometimes when you switch amp on you hear a click & the display registering music being played from cd player these lights are moving up & down as normal. But most of the time it wont make that click & so its dead. apart from the red power light. I have checked all fuses & non are blown? can anyone help please
  • 4,234 Answers
In bridge mode, the left and right amplifiers are in essence connected together. Typically, the speaker connections are to the positive connectors for each channel for this mode. WIth the speakers still connected, you essentially shorted the outputs to ground and smoked the output section. The unit will detect this now and not turn on the output section. Your unit is in what is usually called "protect" mode. This unit will require repair. Expect to have the output transistors replaced at the very least. I would estimate around $16-$40 for parts.
Dan
Posted on Jul 03, 2009
Phonic mm1002
You need a 3.5mm stereo jack to twin 1/4" jack plugs. That will get audio from your laptop to the mixer. Then, being Peavey, probably a pair or jack to jack 1/4" screened leads for signal from mixer to amp. Then loudspeaker leads to suit your amp and speakers.
Jan 02, 2014 | Computers & Internet
Can a pc be connected/used with a k12 power mixer
As long as your mixer has a line output jack ( L & R or MONO ), yes.
Oct 19, 2013 | Phonic Powerpod K12 Plus 1000W 8...
I tried hooking up a laptop to powerpod mixer it shows music is playing but nothing comes out of the speakers
Which inputs are you using? If you are using the 2T RTN, you will need to engage the 2T RTN button under CONTROL ROOM SOURCE and engage ASSIGN TO MAIN.
Sep 27, 2011 | Phonic Powerpod 820 / S712 PA Package
Why do i have echo when i play music on my phonic powerpod 820 mixer
Visit this link to download the manual if you don't have it already. https://phonic.box.net/shared/crqxhlhmmz
This mixer has a multi-effects processor onboard, but the key is understanding the audio signal chain. There is a chance that you have your input audio going through an undesired effect, but without knowing your setup (input source, connections, mixer settings), it would be difficult to pinpoint the problem.
Apr 04, 2011 | Phonic Powerpod 820 Mixer
I have the Phonic powerpod 820. I ordered a Kuston powered floor monitor to add too the system. I know not to hook it up too the speaker outputs on the back of the mixer. So where do I hook up the powered...
You will plug an UNBALANCED 1/4 inplug cable into the MONI jack on the front of the unit. The other end will probably need to be an XLR plug to connect to the Kustom POWERED monitor. Please note that the UNBALANCED output of the Phonic is NOT good engineering practice. The Phonic stuff is normally low-end and they don't do everything correctely, although for a small system it should work. IF you get excessive hum from using a long cable to the Kustom with a "Kludged" unbalanced to balanced cable, you MAY need to use a DI box at the Phonic end to convert the unbalanced Phonic MONI output to a balanced line (XLR to XLR) for a longer run to the Kustom monitor. You might get a 1/4 inch TS to XLR balanced plug that has a transformer in it and use an XLR to XLR cable to the Kustom. Please note that having this plug in the Phonic hangs out and is easily bent over so I would recommend using a right angle connector at the Phonic and plug the 1/4 inch TS to XLR adaoter into that so the yanking of the XLR cable won't break the 1/4 inch adapter off in the Phonic.
Feb 23, 2011 | Phonic Powerpod 820 / S712 PA Package
I have speakers plugged into my phonic powerpod 820 right now but I want also to have the output of the mixer to go through an instrument amp, is this possible? If so, where do I connect the instrument amp...
Yes it's possible. I'm assuming you'd like to use the keyboard amp as a "monitor". In which case, take a 1/4inch TS (instrument cable) jack out of "Aux Send" into the input of your keyboard amp. Make sure the keyboard amp is turned up to a good level and that the Master SEND is turned up on the Desk.
Now you can make your own "monitor mix" for on stage use without effecting the F.O.H mix by turning up the aux pot (knob) on each channel you use.
You can use the CTRL ROOM output also, but make sure it's not giving a "Powered Output" from the internal amplifier in the mixer as you will damage the keyboard amp.
Jan 16, 2011 | Phonic Powerpod 820 / S712 PA Package
Connecting a guitar amp to a mixer amp
Hi cliff
Connect either of the XLR DI output of the Behringer directly to a MIC IN channel on the Powerpod using a standard Microphone cable. If you wish to push a stereo sound then connect both(L + R) of the XLR DI outputs from the amp... that's about all you need to do. The only reason you need to use stereo(both XLR Outs) from the Behringer is if you want a full stereo FX output from the amp, otherwise you can get away with 1 connected. You may need to back the gain off for those channels on the power pod. You can get a manual for the Powerpod from here
and user manual for the acx900 here
Hope this has helped you, If not, feel free to ask any questions. Cheers.
regards
robotek
Aug 08, 2008 | Phonic Audio Players & Recorders
575 people viewed this question
 Grubhead
Grubhead
