Question about Baby Gear
Missing side rails Generation 2 Worldwide Toddler Bed
I have a Generation 2 Worldwide Toddler Bed 81-8602, the side rails were lost in a move (thanks to the moving company), how can I get replacement rails?
4 Suggested Answers
SOURCE: Toddler Bed Side rail for Delta Luv 5-in-1 crib
Try calling the customer service number (212)-645-9033. I have not called them yet to get the conversion rails for our Delta Luv 5 in 1, but I'm hoping that they will know more than Babies R Us!!
Posted on Sep 29, 2008
SOURCE: generation 2 worldwide toddler bed lost all hardware (screws, etc
You should not attempt to buy hardware to reassemble the crib. Gen 2 has had recall problems with their products. One of the ways a recall is performed is to have the customer send the hardware to the company instead of the whole assembly, rendering it useless. If you received one without hardware, it was probably recalled.
Posted on Feb 09, 2010
tunde007
  • 2382 Answers
SOURCE: Iam looking for replacement screws
Hi, we had a similar problem. Here's what we found out: Generation 2 is no longer in business. If all you are needing is the screws to put it together (meaning you have all the plastic slide pieces for the side that goes down then you are in luck. All of the screws and nuts can be found at your local hardware store (we got our at Ace Hardware in the nuts and bolts section in a drawer for furniture stuff). The exact nuts and bolts should be listed under the solid base for the mattress. Just copy those down and head to the hardware store. If you cannot find them there, then call Products America at 1-800-205-9642. They have all the hardware but it will cost you around $40 ($30 more than at the hardware store). If you are missing any of the plastic slide pieces for the side that moves (as I am), you are out of luck. Gen 2 patented those and took the patent with them (they will not alloy anyone to make their patented pieces).
Posted on Sep 16, 2010
I need an instruction manual for a toddler bed model # 31-8601 made by Generation 2 Worldwide, Llc. Where can I find this?
You need to contact the manufacturer and ask for technical support. You should also ask if the manual is available for download. If yes, ask for a link.
Jul 17, 2017 | Generation Baby Gear
I have a vickie crib .I want to convert to toddler bed. If I take the front rail off there is'nt anything to hold the bed up in the front. It unscewss from the side. Help! Bed was purchaced 9/2008 ...
Is this a 4-in1 convertible crib? The Toddler bed will need the bottom railing and a half rail to convert from a crib to a toddler bed. The half rail can also be removed to make the 4th conversion to a toddler bed with out railing. But to convert this specific bed you DO have to add the bottom rail that came with the bed at purchase.
Mar 10, 2011 | Sorelle Vicki
I lost the instructions and my son is ready to be in a toddler bed. I was wondering how do i covert the Graco - Lauren 4-in-1 Convertible Fixed Side Classic Crib into the toddler bed? and also do i need to...
You just take off the rail and Tada! it's a Toddler bed.
Then you can change from elmo sheets to Pokemon sheets and Tada! it's a Day/Bed. I don't know how they get away with advertising it as a 4-in-1 since there is no material difference between the daybed and the toddler bed.
Aug 15, 2010 | Graco Lauren Crib
Graco 3-in-1 crib instructions
Check this CPSC link.
Most if not all of the simplicity brand cribs have been recalled reguardless of whether they had wood or metal mattress supports.
There were 2 different recalls on the wood version but both were recalled for the drop-side issues.
This link specifically includes the Aspen 3 in 1 cribs and model #: 8740
We took ours to our local walmart last summer (we purchased it in a different state almost 8 years ago). I brought to cpsc report with me. They had not issue with the recalled information we has matching it to our crib. It did take the clerk a bit to find our crib in their system because it was older, but once she did we recieved a full refund, without a receipt.
As far as changing them to a toddler bed. When we converted ours to a toddler bed we simply removed the drop-side from the crib. The drop-side parts can be unscrewed from the side rails. Then we screwed the toddler rails to the bottom of the crib. Ours had screw holds for the toddler rails on the mattress support. If you do not have the holes for it, then you may have put the mattress support on backwards ie with the side that has the holes for the toddler bed rails on the backside of the crib.
Dec 04, 2009 | Graco Apsen 3-in-1 8740 Crib
Generation 2 worldwide toddler bed lost all hardware (screws, etc
Jan 17, 2009 | Baby Gear
Aug 02, 2008 | Delta Luv Delta - Baby Products 5-in-1...
Instructions for toddler bed
I am looking for it too.
Jul 27, 2008 | Baby Gear
Transfer
All you have to do is remove the plastic slider rails on the top and bottom of the front rail and take off the rail. This bed still has 3 rails like a daybed when it is changed into a toddler bed.
Jun 04, 2008 | Cosco 2-in-1 Sleigh 10121 Crib
Convert crib to toddler bed
I finally found my instructions!! It's actually really easy to convert to a toddler bed:
Step one: Take out four screws (two on each side) of the front railing and top bar. They are the screws holding the front railing and the top bar to the side of the crib and the dresser.
Step two: Lower the mattress to the lowest setting.
Step three: Place the toddler bed railing in place. It can go either way depending on which side of the crib your toddler sleeps. We put the taller part of the toddler railing closest to the dresser because that is where our son's head usually is.
Step four: You'll need 4 1.5 inch hexagonal screws to screw in the toddler railing. After 2.5 years, I could only find two of them, so I used two 1.5 inch regular screws that came with the crib. On the taller part of the toddler railing -- the screws go into the 1st and the fifth holes. On the shorter side of the railing, the screws go into the 3rd and the 5th holes.
That's it.. You've now got a toddler bed!
Apr 26, 2008 | JCPenney All-in-One Nursery Crib
Changing from a crib to a toddler bed
1-Lower drop side to lower position. Then on the opposite side of the crib, remove stationary side. To remove stationary side, press the small tab on the end hardware(brown plastic piece that connects the rail to the frame) and then pull rail up.
2-Before reinstalling the conversion safety rail(csr), remove the mattress support bolt that is on the side the the csr opening will be(the foot of the bed). A new bolt will be used to reattach the mattress support in the next step.
3-Slide csr hardware onto the hardware on the crib ends. Insert two 1/4-20x2" bolts into each end. One bolt will replace the mattress support removed in step 2. Be sure to put the bolt back through the mattress support bracket before screwing into the end.
I have the instruction page with pictures if you would like a copy emailed.
jmsmith2003@msn.com
Sep 15, 2007 | Childesigns Carrollton Crib
Baby Gear Logo
97 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
