Motorcycles Logo
A
Anonymous Posted on Aug 21, 2014
I was riding my 99 Honda shadow vlx. After giving it some throttle to pass a vehicle it died and would not start. Then once I finally got it to start it will idle but dies as soon as I throttle. What could be causing this?
RAYMONDO1953
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Motorcycles Expert 545 Answers
  • Posted on Aug 21, 2014
RAYMONDO1953
Motorcycles Expert
Level 2:
Prodigy:
Answers
545
Questions
Helped
106726
Points
669
Try your spark plugs firstly,then your air filter,if you try these two simple steps first,then let me know.
1 Related Answer
Anonymous
  • 3 Answers
  • Posted on Jun 01, 2009
SOURCE: motorcycle dies while riding,like gas is cut off
Most likely your high speed needle valve seat has dirt in it. Try removeing the bowl and cleaning the Main Jet.
1993 Honda Shadow VLX Deluxe runs well then dies out
If a carburetor, the float may need setting as it may be starving for fuel .
2answers
1996 honda Shadow vlx 600 starts, run for 1 minute and dies
How did you check the petcock? sure its not that.Yeah swap coil packs then ask again.
1993 HONDA SHADOW VLX 600, STARTS RUNS FOR 5 MINUTES AND DIES, I CHECKED EVERYTHING FUEL RELATED,IT'S NOT A FUEL PROBLEM
From your description you can be fairly certain it is an electronic problem.
I had a similar problem once with my Honda CX500. I found the connections to the ignition module had gone green and a good clean up restored normal running.
I was riding my 06 honda shadwo vlx 600 and it started having issues getting gaining speed when I would give it more throttle.
check fuel.check battery.spark plugs will 1/cylinder at the top of head.remove insulated lead by hand and you'll see plug.match plug by noting brand and number written on the plug or take it with you to parts supplier.if cleaning use gauge available at auto/hardware store and be sure to match gap (find specs online).when reinstalling, don't overtighten.
2005 Honda Shadow VLX high idle
This could be two things:
1. A stuck throttle grip. With the bike off and stopped, twist the grip and see if it snaps back into place. If it stops, but you can "push" it back into place - you have a stuck throttle. It's not idling. It's stuck "on".
2. Adjust the Idle. Typically, there is a little daisy wheel next to the throttle grip and you can turn it left / right to adjust the throttle.
2answers
Bike won't start and head light won't come on
Battery probably! did it push start? because if it did,,,, you should continue to ride it for awhile to recharge the battery.... that is if the voltage regulator is working o.k. check battery voltage, if its only 12v the regulator is probably going out.
1993 honda shadow, sometimes off the start it will
use a thin piece of wire and clean the ilde port and transfer port if that doesn't clear it up check idle jet
Motorcycle dies while riding,like gas is cut off
Check fuel pump. You might have a bad diaphragm.
Top Motorcycles Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Motorcycle Expert? Answer questions, earn points and help others
