Question about Insignia IS-PDVD10 Portable DVD Player
Trying to watch DVD played on portable Insignia player on the TV
I connected the AV cable to the Insignia output and Red and White plugs to the front inputs on the VCR connected to TV. Set the front input for the VCR. Sound works on TV but picture still stays on portable unit and does not show on the TV.
If you hear a noise, when triying to read DVD, I am shure I´ts teh engine malfunktion.
you must get the mechanisiam or take this to a service.
I´ts very difficult for lenses to get brocken.
Posted on Jul 02, 2009
The player does play the dvd's and everything but the picture wont show up in my television. I already connected the RCA connectors into the television and the player but still no picture. Please Help.
Assuming you used the standard YELLOW-WHITE-RED RCA cable, between the unit and the TV, the colours of each of the plugs should match both the outputs on the rear of the unit and the respective inputs at the rear of the TV. The TV must also be on an AV input 'channel' to receive the connected unit. (for example, AV1 or VIDEO 1)
Try changing the RCA cables - just in case the ones you currently have are defective in some way.
Being a combo unit, there should be a DVD-VCR common output on the rear - using RCA cable, the YELLOW is video, the WHITE is left channel, the RED is right - these MUST match the input on the TV, and the TV AV input must be selected in order to view the pictures and audio from the unit. To enjoy both VCR and DVD, using the RCA connection, the common output on the rear of the combo unit is recommended.
Better quality video is possible using S-Video cable (available from electronics stores such as Radio Shack etc. but this does not provide audio; you would still require RCA RED-WHITE cable for that, and your TV may not have S-Video input). Your TV may have a TV/AV button on the front - select the correct AV 'channel' with that if necessary.
It makes sense to check everything twice before assuming anything is broken.
Jun 28, 2011 | RCA DRC8300N DVD Recorder/VCR
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
HOW TO PLAY MY DVDS, AND CONNECT A WII AND PLAYSTATION 2
If you have the Insignia NS-42L550A11 (inputs shown here - http://www.bestbuy.com/site/olspage.jsp?id=cat13506&type=page&h=387&skuId=9595066&productId=1218131141674&navigation=prev&count=3&chk=true - or something like it), you might have a hard time plugging all of your devices into the TV.
Your DVD player might have a Component Out - if so, plug it (all 5 plugs) into the "Component" section of the TV. If you don't have a Component video cable, you can simply use a couple of Red, White, and Yellow cables instead - just be sure you connect the proper ends so the colors from the DVD match the colors to the TV.
As for your Wii and Playstation - I believe they both have the simple Red, White, and Yellow output plugs (labeled "AV IN" on the back of your Insignia). Because your TV only has 1 input for "AV IN," you might need to purchase a switch of some kind that you can plug your Wii and Playstation into and the switch will have 1 set of Red, White, and Yellow plugs to hook into the TV. The other option is to simply plug and unplug your Wii or Playstation directly to/from the TV depending on what you're playing... not an ideal scenario (particularly if you don't have easy access to the back of your TV.
The following link is for a 2-way switch that would do what you're looking to do. You could even get a 3-way switch and plug all 3 devices into it if your DVD player doesn't have a Component Out.
http://www.amazon.com/RCA-DT902AV-2-Way-V-Switcher/dp/tech-data/B0014KOAD8
Feb 08, 2011 | Insignia 42" LCD Flat-Panel HDTV
Dvd play works but vcr playing does not
For this unit the component output (green, blue, and red cables) only work for the DVD player portion of it. You will need to connect either the av input on the back or the front with composite (yellow, red, and white cables) to your television in addition to the component cables I assume you have connected already. Once you have done so you will need to switch this unit over to the right av output in order to access the vcr and also switch your television over to the right av input in order to pick up the signal from the vcr.
May 05, 2010 | Toshiba SDV395 DVD Player/VCR
What type of cord I need to connect my TF-DVD7005 Portable DVD Player to a tv?
Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. ColoredYellow, (Video) Red, & White. (Audio) AV. OR If you have SCARTConnection Sockets, it's a big Black Socket at rear of unit(s), you get aSCART Cable.& It's all inside. Now some units, use a standard calledComponent Video, that uses, a Green, Red, & Blue Plugs. Now, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
Mar 04, 2010 | Coby TF-DVD7005 Portable DVD Player
How can i hook my dvd player to my flat screen to watch a movie that we all can see
Mar 02, 2010 | Insignia NS-PDVD10 Portable DVD Player
My sony portable dvd player stopped working. The
If the DVD is connected to the TV properly using the yellow, white & red AV cable and the TV is switched to AV and there is still no picture, plug the yellow lead from the back of the DVD player into the green socket. If you see a black and white picture now the DVD output is on Progressive Scan mode. See user manual to turn off Progressive Scan mode.
Aug 31, 2009 | Sony DVP-FX810 Portable DVD Player
How do you connect the portable dvd player to your big screen tv?
Look on the side of the dvd player you should see a connector that says AV Out or Video Out, you will need a wire that plugs into that which depeding on the model of dvd player can be either the Red / White/ Yellow Phono Plug Leads or a Lead which has the Red / White/ Yellow Phono Plugs and at the other end what appears to be a headphone jack connector with 3 black bands on it indicating that its a 4 Pole Video output cable, then you plug the Phono Plugs into the Phono Sockets on your tv, using your Tv remote you will need to select which input you got the dvd player plugged into this will either be called
Source Or Input Or AV 1-2-3 ect.
jon
Aug 11, 2009 | Initial Televison & Video
Insignia pd-1020
Go to Radio Shack.  You're going to need an IPod dock that has video playback capability, an av cable with the three av outputs.  Then you will need a mini jack cable that plugs into the video and another mini jack stereo cable for the sound.  You made need a coupler as well.
They only make home cables for Ipod systems.  The other wires will convert the home cables for portable DVD use.
Sep 17, 2008 | Insignia I-PD1020
Want to watch thru tv
Hi
Check and see if you have A/V out jacks on the unit. If you do, they will be yellow, red, and white.
They are called RCA jacks, and if you have them, and the TV has the same type of jacks, then you just need the cable that goes in between. The DVD player normally comes with them, but if not, you can purchase them at any Circuit City, or even Walmart.
Jan 14, 2008 | Mintek MDP-1815 Portable DVD Player
Insignia IS-PDVD10 Portable DVD Player Logo
198 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
