Purchased on 7-2-2014 it worked perfectly for 30 days on 31st day it quit. On 8-2-2014 I purchased a second unit and it is working perfectly like the first unit. What kind of Life Expectancy can I expect from the Channel Master?
1-866-942-5362
Pacific Standard Time: 8:30 a.m.- 4:30 p.m., Monday -Friday
Or visit our web site 24 hours a day, 7 days a week for product assistance at
www.whalenfurniture.com
Or e-mail your request to [email protected]
LOT NUMBER:
DATE PURCHASED:
it may have taken a surge of power and fried one of the amps inside nothing to do but replace it. make sure that your main cable line to your house is grounded very good to a good earth ground source like a ground rod or gas line or cold water line.
Exercise your warranty IMMEDIATELY since you just bought it! If you bought this used, you LIKELY bought someone else's problem. The problem is likely in the digital effects area... probably a bad cable contact... but if under warranty DO NOT mess with it... return it for replacement or repair.
You have to adjust the date every February (28 or 29 days), April, June, September and November (each 30 days). Self adjusting calendars are called Perpetual Calendars and this feature is quite expensive, especially in mechanical watches. Your watch has calendar ring with 31 days printed on and the simple calendar mechanism which is changing dates from 1 to 31 inclusive,day after day, so, when the 30-day month is ending and there is no 31st date to follow, your calendar is showing 31st anyway,instead of 1st of the next month. This is when you have to adjust date. Now about the date adjusting. If you pull out crown gently, you will notice there are two clicks (positions), not just one. So the first click, when crown is not pulled out fully, is exactly for day/date adjustment. If you pull the crown further out, watch is in hand adjustment mode. Try it carefully and you will find out the right position.
Rate me, please.
