Question about Garden
Right this mower as points and a field coil and a condencer i need to try a condencer but dont know were to get them can you help Modle 92902 Type 0126-01 Code 3601312
  • 155 Answers
Hi if its a briggs and stratton most dealers should be able to help
Posted on Jul 27, 2009
Coke stays on lawn mower engine
Your throttle cable may need adjusting or you choke arm is sticking
Jul 27, 2014 | Garden
I have a 16.5 hp onan engine in a 1979 gravely tractor -with engine running why are my ignition points sparking
Ignition points open to collapse magnetic field in ignition coil to make spark. They have a condenser across the points to reduce the spark which comes because the current collapse also generates a back feed current in the now open circut in the primary windings. This is the spark that damages and wears out the points. Check with a competent Auto Electrician that the condenser (also called a Capacitator) is the right capacity for the coil being used.
Jul 20, 2014 | Garden
SPORTSTER WITH POINTS
make sure the points are very clean and gap is set correctly ! is the timing dwell set ? remove one coil and try it on other cyl and see if it now sparks , if yes then replace other coil , are the 2 sets of points or one ? have you checked condencers ok ?
Dec 09, 2013 | 2004 Yamaha V Star Classic
No spark
do you have 12volts going to the coil?double check the gap on the points
Apr 05, 2012 | Garden
1986 Harley Davidson/Columbia Gas Par Car- Switched ignition to a points system. I got it running but need schrematic for wiring system. Can anyone point me in the right direction?
A points system wiring is simple. All you need is a switched hot wire. Connect that to a coil that has a primary resistance of 5 to 6 ohms, (a early points ignition Sportster coil will work) on one side with the points connected to the other side of the coil. The points grounds the circuit causing the magnetic field to build up. When the points open, the field collapses creating the spark in the secondary side of the coil going to the plug. If it's a single cylinder engine, simply buy a coil for an early points type automobile engine. You want a primary resistance of 5-6 ohms to keep the system from drawing too much current.
Good Luck
Steve
May 21, 2011 | Harley Davidson XL 1200 C Sportster Custom...
Hi ive just got a cb900f2 boldor. It has been in a shed for 5 years, previous history unknown. The seller has put new plugs and carbs on it. It will whind over but no spark at plugs. I dont know alot...
pick ups work similar to points
The coil needs power, when the points open the coil field collapses and it sparks
With pickups they trigger the electric igniton box to do the same job as points.
if you have power to the coils, when you touch a pick up with a screw driver it should trigger a spark.
You dont often get two coils fail or two pick ups fail simutanously, but a faulty ignitor box will stop all spark.
PS (not ignition related)Check the rivets in the wheels if it has them
May 09, 2011 | Honda CB 750F2 Seven Fifty Motorcycles
No spark at plug
Well, the next step is to access the points, you need a puller to remove the flywheel, and then replace the points and condencer, adjust them and lube the rubing block, reassemble and try again.
THIS presumes that you already inspected shut off grounding system....
Oct 04, 2010 | Briggs & Stratton Garden
1977 suzuki a50p no spark new points condencer prime coil ignition coil and plug help
Try reinstalling the points . It is real easy to have them short. Some times it takes two or three tries to get points in correctly (so they don't ground out).
Sep 03, 2010 | Suzuki AX 100 Motorcycles
Its a sigma 81 im not getting power to the distributor,the wires that go to it are dead
What is it a 2003 or a 1981 as 2003 dont have a distributor,,and a distributor on a 81 has but the wires are only live when the battery power is turned on and that is power to 1 side of coil (pos)side only and when contact points are open then power is on both sides of coil,, and condencer and point will spark when points are opened also check,HT leads
condencer,,Points gap of 12thou, (Let me know how you go) Ron
Sep 29, 2009 | 2003 Mitsubishi Galant
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
