Question about Sony VPL HS10 Multimedia Projector
Sony HS10 error lights
I have a Sony HS10 projector. When I turn the projector on the lamp turns on with the warmup white screen with green LED on the projector on.
After about 5-10 seconds the Lamp tuns off, the status LED flaches green and the 'Lamp/Cover' led also turns on solid orange. The projector then powers down immediately.
Is this something I can fix or do I need to take the projector in for a service?
Regards,
Tim.
  • boozman14 Dec 17, 2007
    Same problem here, with 698 lamp hours on it, the projector switches off after about 30 sec, lamp/cover light is orange. It seems a new lamp is needed, but after only 700 hours ? Sony says it works about 2000 !
  • 82 Answers
You could try a new lamp, some lamps fire, but do not stay on
Posted on Jul 26, 2009
  • 36 Answers
It appears your bulb has reached its end, replace the bulb.
Posted on Jul 10, 2009
4 Suggested Answers
SOURCE: Projector turns off after 30 seconds.
I had the same problem I replaced the motor/lense cover unit at the cost of $AU140.00 and that fixed it.
Leckie
Posted on Mar 01, 2008
Marrie
  • 563 Answers
SOURCE: SOny VPL-EX1 turns on for a few minutes and then the Lamp /Cover LED and Power ON/Standby LED flashes.
Hi David
I think you should replace the lamp.
Posted on Mar 26, 2008
AJIN G
  • 6694 Answers
SOURCE: Sony VPL-CX61 lamp/cover blink. Power on, it
hi,
your projectors lamp cover may be open. or there is some thing happened (may be contact problem) with the lamp cover open sensing switch. just open the door and close it. and then try again.
ok
Posted on Dec 20, 2010
Testimonial: "Thanks! And please tell me where is the lamp cover located."
Sanyo pro xtrax projector
Lamp LED should be lit when the projector is in Standby. However, the problem you are describing sounds like one of two issues. Either the lamp is bad and needs replaced, or there is a power supply fault. If you have tried replacing the lamp already, make sure you reset the lamp counter or the projector may still not function properly.
does the temp warning light come on when the projector shuts off? if so you may also try cleaning the air vent filters and ensure there is proper air flow around the projector. if that checks out then have the projector serviced as the power supply is likely suspect.
Dec 09, 2013 | Sanyo Office Equipment & Supplies
Hi I have a Sanyo PLC-XP18 projector and it has recently developed a problem. I was watching a film the other night and the projector just cut out. Now when i try and turn the projector on the the fans...
READY light is green when the projector is ready to be switched on
LAMP is dim when the projector is ON, but goes bright when it reverts to STANDBY.
Check that the lamp cover is fully down and the cover switch is activated
Feb 28, 2011 | Sanyo PLC XP18 Multimedia Projector
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
Optoma Projector power LED is blinking green,funs are not working, lamp not function, how can i solve this problem
i'd say power supply issue, but the led is blinking green. this means that it thinks it's in warmup/standby mode. but if nothing's running, the main board might be bad and needs to be replaced.
Dec 02, 2009 | Optoma HD65 DLP Projector
I replaces my bulb in the sony vpl-hs10 and it still will not turn on after I reset it what do I do now? the lamp light is still lite it turns on but the lamp does not project anything
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS3.
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
Nov 19, 2009 | Sony Cineza VPL HS2 Multimedia Projector
When I power up the projector the center of the image is GreenThe projector has a new lamp. Is it the power supply?
This problem is more likely to be the Green LCD gone. The green LCD's job is to filter out the green on the picture where it isn't necessary so If the green LCD starts to fail, it will let through too much green light. I think its more in the middle because of the heat from the bulb over time.
Oct 23, 2009 | Sony VPL HS10 Multimedia Projector
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
Unit turns on but no lamp
Sent to V3 SYSTEMS & SERVICES PTE LTD 64522679,
they are Projector Service Center in Singapore,
Nov 25, 2008 | Sony Office Equipment & Supplies
Sony VPL HS10 Multimedia Projector Logo
232 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
