Question about Kenmore 20.6 cu. ft. Upright Freezer 24092
Kenmore upright freezer. left and right outside box sides are fairly warm. Is this common?
  • 370 Answers
Yes. This is the way freezers work. Every freezer will do this. If the freezer doesnt do this it generally does not work properly. So to answer your question... its nothing to worry about.
Posted on Jul 01, 2009
Freezer works fine but sides get really warm
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
May be overworking itself to stay cold
Sep 05, 2014 | Kenmore Freezers
Kenmore upright freezer hot on the sides, stop freezing
Without the model number I'm not sure how to answer your question. Does your model have fans that blow warm air on the outside bottom or a front kick plate? What is your model number? Kenmore has model numbers like this example=> 123.3214567 If the fan has a restriction that causes a lack of airflow it can cause the hot Freon liquid that normally flows around the Yoder Loop inside edges of the freezer door to prevent frost buildup to become very hot because the condenser fan is defective or coils are dirty with dust restricting airflow. If the outside is hot you may have a defective condenser fan motor. That will cause the freezer to ger hot. I am here should you want my assistance....Sea Breeze
Kenmore Freezer Parts
Aug 31, 2013 | Kenmore 14.1 cu. ft. / 399 liter Upright...
My Kenmore 9 upright freezer feels warm on the outside, what could be the cause. I have defrosted and cleaned it already and seems to work fine. however i am concerned with the outside temperature. Please...
This is normal. The condenser coils on freezers are typically located in the walls.
The refrigerator in your kitchen has condenser coils that are hot either under the frig or on the back. Freezers do not need as much heat transfer on the coils with the air so they put them in the walls, it is called a warm wall condenser. It may even feel hot to the touch if you happen to feel it near the end of a cooling cycle. It will be the warmest close to the compressor and cool off at it makes it around the cabinet down to the other side.
Apr 25, 2010 | Kenmore Freezers
Freezer @ +28 deg/appears common problem B 1st 2 answer right....
Model numbers of Kenmore , starting with 253. are made by Frigidare . The compressor probably has a valve out , either the high-side , or low-side . Probably the low-side valve is bad , therefore , the high-side will pump but not get the freezer as cold as it should be . Both sides have to work . Low-side helps pull the refrigerant thru the system , while the high-side pumps pressure thru the system .
Aug 26, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Taking out trays for cleaning
Usually the holes are deeper than they appear in the side walls. Lift the shelves just a hair and then push them left...the right side should now be outside the hole and able to be moved upward until left side clears.
Reverse this process to reinsert. Good Luck.
Aug 21, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Kenmore Upright freezer needs cleaning under bottom shelf
most of the sears freezers . lift up on the shelf that will unlock it then slide it left or right ( it may move a little hard ) that will unlock the other side , lift and remove ( one side at a time ) ... you will see its not that hard , its just hard to put it in words .....Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 04, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Mar 02, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Leakage and warm sides
The outsides should will be warm.  This is normal because the condensor lines run thru the cabinet from about half way up the sides and over the top.  Which is why the you shouldn't have anything stacked on top of the freezer and enough room on the sides of it for air flow.  As far as the water leak, tell me exactly where you see the water and does the bottom of the freezer (inside) have a sheet of ice on it.  If there is ice there then the drain behind the bottom panel in the freezer is frozen over and will have to be thawed out.  Let me know what you find.  If you have further questions I may need the entire model # on the sticker inside the freezer.
Oct 21, 2007 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Freezer problem
if you don't hear it running for extended periods of time (more than 15 minutes) without stopping, and if it does not immediately re-start once it does stop, and if it is extremely hot climate outside (85 F and above), then yes, this is acceptable.
Jun 08, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore 20.6 cu. ft. Upright Freezer 24092 Logo
271 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
