Question about Kenmore 22422 Top Load Washer
Super Capacity 80 Series dryer with bad timer
  • 370 Answers
If you go sears.com to the parts section and type in your model # you can view diagrams of your dryer and get the part number for the timer. You can even order it right there on line.
Posted on Jul 01, 2009
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
What size is the kenmore model number 11064852400
Maybe Sears can provide dimensional data.
Dec 01, 2013 | Dryers
Dryer runs fine but heating unit will not ignite
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
I have a Kenmore 80 series Heavy Duty Super Capacity Plus that stopped turning on.
If the drum does not turn at all the motor, may be bad, belt may be off, the tensioner may have popped out of it's mount.
If it turns very slowly the belt is slipping. It may be stretched and needing replacement or again the tensioner may have come free from its mounting
Apr 04, 2010 | Dryers
Heavy duty super capacity plus Kenmore 80 series Electric drier the timer is running, but when I push the start button - nothing
the drum belt may be broken. you will have to check this, it goes around the drum and the pulley on the motor. you could also have a bad motor.
Oct 16, 2009 | Kenmore 73952 Gas Dryer
Dryer not working
check your door switch and if that is good then check the fuse located on blower housing,it is white with a black strip down middle and has 2 wires that go to it.you can put 2 wires together and wrap with electrical tape plug dryer in and see if it starts
Mar 09, 2009 | Dryers
Dryer timer is not working and won't heat but runs fine
check the ignitor. That's a very common cause for no heat in a gas dryer. other possibilities are the coils, or it could be that you have a bad fuse in the dryer.
Dec 26, 2008 | Kenmore 73952 Gas Dryer
Kenmore 22422 Top Load Washer Logo
56 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
