Question about Sony KP-53V90 53" Rear Projection Television
Color not working on 53" rear projection sony tv made in 2000 looks like color is all green is it a tube because of the year
  • 261 Answers
There's a slight possibility it might be your video board, i recommend disocuntdashmerchantdotcom for free troubleshooting :)
Posted on Jul 01, 2009
How do I fix my Panasonic PT-53WX53 53 in. Rear Projection HDTV the power light blinks when I press the power button and it will not turn on.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 29, 2011 | Panasonic PT-53WX53 53" Rear Projection...
I am having trouble adjusting my colors for my kp 53s25 there seems to be a lot of yellow how can i solve this?
This TV has had a long life. Your picture is looking more yellow these days because the Blue picture tube is wearing out. Not saying the Green and Red tub are much better, but Blue tube is a major player in the picture brightness and white balance (the color of white which the TV reproduces). The cost involved wouldn't be justified. You should enjoy the balance of the TVs life; when it's time comes... have the new TV delivered and ask them recycle this one. Best wishes.
Apr 26, 2010 | Sony KP-53S25 53" Rear Projection...
The screen looks out of focus and the top and botton bend inward.
Remove front bottom panel behind it is a small black control box top controls are focus controls for R/G/B and Bottom 3 controls are your screen drives adjust one at a time turn off G/B adjust red first,then Do Green and Blue fter adjusting focu to each tube leave them set then adjust screen drive turn color off adjust RGB for a Black and white picture get as close as you can then turn color back If after doing this you still have blurry looking picture look down into Tubes you should be able to see picture clearly in each one if you cannot see picture then projection Fluid need to be changed out. Call Mats 1-800-628-1118.
Sep 26, 2009 | Sony KP-53S65 53" Rear Projection...
53" sony projection -picture washed out w/ green horizontal lines
It sounds like your Green CRT ( picture tube ) is shorted. That's the one in the middle. Sony had issues with there tubes in those years. Sorry for the bad news. Even if you could locate the tube, it will be a matter of time before the Red or Blue does the same.
May 03, 2009 | Sony KP-53S65 53" Rear Projection...
Double picture & color problem
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 22, 2009 | Sony KP-53XBR45 53" Rear Projection...
see if the mirror in side is broke or cracked
I have a 53 in. sony projection tv,. bowed picture tubes?!?
Replace Both STK convergence ICs will have part number on them STK392-560 use same part number on your STKs. Also around ICs ck pico fuses 5/6amps they are green or yellow.
Jan 07, 2009 | RCA P56930BL 56" Rear Projection...
2 separate colors on screen
sounds like your convergence IC's have finally gone bad.. they seem to last 5 years on average.. have a look here: http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 19, 2008 | Sony KP-53V75 53" Rear Projection...
Color problem with Phillips 53" projection tv
Bet the fluid is bad. You can take the back off and look into the green and blue lens. See if the picture is clear. If cloudy the fluid is bad. Be careful when doing this. Changing the fluid should be done by a tech.
Sep 09, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Sony KP-53V90 53" Rear Projection Television Logo
154 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
