Question about Bernina Activa 130
Re-assemblying the hook-race and bobbin after cleaning
I have a Bernina 1080 and took the bobbin and hook race apart for cleaning and am not sure I have put it back together properly. Does anybody know where I can get an illustration so as I can re-assemble?
I do have the manual, but the pics are not very clear.
  • 6 Answers
SOURCE: Bobbin Carriage clanking noise, yet the machine sews fine??
If your bobbin area is making a noise, then do NOT sew with the machine until a reputable technician looks at it. You may have thrown something just a little off line - not enough to affect sewing NOW, but it could easily cause troubles down the line.
I suggest you call ahead and talk directly to the repair person - not to the sales person. Ask if you can bring in the machine while he/she is in the shop so they can listen while you run it.
You aren't trying to cheat the store out of the repair charge, just ensuring that the problem is diagnosed correctly.
You paid lots of money for this machine - it deserves good care.
Posted on Dec 30, 2007
  • 192 Answers
SOURCE: designer 1 bobbin assembly loose
If the bobbin winder spindle is loose and flopping around in the opening in the front of the machine is has come out of the frame that it should be mounted in. Operating the machine with loose parts inside can be risky for the machine and the operator.
Don't take a chance on causing further damage to the machine. The bobbin winder can be replaced without too much trouble and is relatively inexpensive.
Posted on Jun 12, 2008
  • 155 Answers
SOURCE: Installing the hook and bobbin assembly.
Needle Faces Where?
I Need to Tighten the Tension....
Changing a Needle
Need Help
Basic Questions-
Bobbin Assembly Popped Out!
Do You Think My Machine is Fixable?
How to Change a Broken Needle
Needle Bar Adjustment
Oiling an Elna 3007
Getting the Timing Belt Off?
What Size Needles for My Machine?
How to Oil my Machine?
Where to Oil??
Stitch Length Knob Woes
Can't Seem to Put the Bobbin in Correctly
Timing Belt Tension
Adjustments
Running Very Slow-
Oiling Points on Singer 257
Oiling My Singer Touch & Sew
Singer 457
Featherweight Case Odor
Brother XL2010 Q's
Does My Machine Have More Than One Belt?
Cannot Seem To Adjust the Tension
What to Do About a Gumming Up Needle
How Tighten My Bobbin Tension, Please
Is it Covered Under Warranty?
Proper Threading Instructions?
Just a Foot Pedal?
Simple Threading Instructions for a 1036
Threading a Singer 600
Replacing a Blade on a Johnson Ruffler
Changing the Needle
Lubricating a Singer 1036
Thread Balling Underneath
Warranty Info
Machine Covered in Hardened Oil
Spindle Stuck?
Do Motors Die?
Singer 457
Brother Sewing Machine
Servicing My Machine-
Belt Replacement
Lubricating My Sewing Machine
check out this  good luck  thanks.
Posted on Oct 26, 2008
kent581
  • 87 Answers
SOURCE: Bernina 1090 Needle assembly stopped moving down
There is a spring loaded catch on the needle bar assembly. It is designed to keep the needle bar from going up and down on command for basting. That way it can take fewer stitches while basting. Anyway, over time, with lint build up, use and not enough oiling, the needle bar clamp release can stick. It is located in the machine cover and hard to get at. It is located right at the point where the needle bar clamp (middle of needle bar) is. It looks pointed on top and about 3/8" tall and SHOULD be able to move front to back (as you are sitting at the machine. If you want to fix it your self, lay the machine on it's back to see up into the needle bar area, you can also see through the threading slot as well.to oil it with SEWING MACHINE oil (read not 3 n1 oil) and try to work it front to back until it breaks free and play with it until it springs back every time you push it. I hope this helps.
Kent
Posted on Mar 21, 2009
Dear kent581-- Thank you so much for posting this information about the catch on the needle bar assembly. The catch released on my wife's Bernina, and it would have been impossible to fix without your tips. I found that I could reach the mechanism with a small screwdriver through the threading slot, and could manipulate it until it moved freely again and locked the needle bar to the reciprocating mechanism. I could never have figured this out without your help.
Posted on May 29, 2010
I removed the bobbin holder of the Bernina 540-2. Want to reassemble. How do I set this properly on the shaft
Not difficult once you've done it. Some pretty good videos on how to clean and oil, removing the bobbin case & hook. FWIW, there are lots of videos showing how to remove and reinstall the bobbin case, hook, etc.
How to Clean and Oil Your Bernina Sewing Machine
How and where to oil your Bernina
I have a 440 that I clean and oil frequently. My machine also has a retaining ring behind the race cover that is removable to be cleaned. There is only one way that it will fit. Just remember what order you took things apart. The hook is probably the most difficult to replace. You just have to be patient and not force it. Turn it around until it sets. It's like the two pieces are in the shape of the letter C and they have to face each other to fit together to form a complete circle.
Feb 28, 2018 | Bernina Sewing Machines
I have a Bernina 770QE. The bobbin (black) is stuck in the bobbin casing (chrome). How do I get it to release?
Take the bobbin assembly loose and turn your hand crank and move it until the hook is at the top. Pull assembly apart and clean the assembly with qtip and sewing machine oil. It will likely be dirty that is causing parts to stick. If the bobbin spring feels weak it may be a good idea to replace it.
Aug 06, 2017 | Bernina Sewing Machines
Bernina 1080 Solution for "back spin"? Top thread suddenly becomes very loose. Top thread forms loops under cloth being sewn.
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case
& make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Make sure the top thread tension is on the correct setting for the fabric being sewed.
9.Also could be a timing problem, and the machine would need to be checked.
Jun 05, 2014 | White Sewing 915
My mother has a bernina 1008 and now that we have taken the bobbin casing out to clean it won't catch when threaded. Any ideas?
Are you threading the bobbin case correctly - the bobbin should rotate clockwise when pulling the thread out under the tension spring. Are you ensuring that the bobbin case is firmly clicked back into position when replacing it. Check your needle is OK. Did you remove the hook from the hook race when cleaning out - have you oiled the hook race ?
Jan 22, 2012 | Bernina Sewing Machines
Bernina Virtuoso 150 - all of a sudden my machine is dropping stitches and the bobbin thread is bunching up. It also most feels like my machine is trying to do a gather stitch. I changed the needle and...
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
Mar 17, 2011 | Bernina Virtuosa 150
I have two maintenance questions: 1) Is it okay to clean it using canned air? 2) Should I oil it periodically and if so where? I have a Virtuosa 160. Thanks for your assistance. Becky
I'd advise against using canned air, because unless you aim it very carefully, you'll most-likely blow the fluff and lint into the machine rather than out, which will lead to long-term poor performance. Use the provided brush to brush out fluff and lint and always make sure you brush it towards you so that it comes-out through the open bobbin door ... never brush away from you otherwise you'll just brush it into the machine. To oil, remove the hook/shuttle, clean the hook race thoroughly and preferably with a cotton bud, making sure that the groove that runs around the inside of the hook race is clean and not full of debris. Put a single drop of the correct Bernina oil into the hook race so that the oil runs around in that groove, replace the hook/shuttle and give the handwheel a turn to distribute the oil. Replace the bobbin case and job done. Now, remember this ... dont wait until your machine comes-up with the 'oil' symbol before you do it again ... you should be cleaning and oiling the hook race every 3-5 bobbins-worth of thread - if you do that, your machine will sound quieter, will produce much better quality stitch formation and will last a great deal longer between services (you do have it serviced dont you ???!!!).
Mar 05, 2011 | Bernina Virtuosa 160
Where is the shuttle race on a Bernina Artista 180? I'd like to be exact as to where to put the drop of oil.
Just to the left of the bobbin case you will see a small lever. Remove the bobbin case and push the lever and that will release the latch which holds the race cover and shuttle (hook).
Clean well with a toothbrush and place one small drop of oil on the edge of the hook where it makes contact with the raceway. Place the hook back and snap the race cover back on.
Oct 01, 2009 | Bernina Artista 180
White thread stitches appear dirty grey
Is this the top thread or your bobbin thread? The technician should have pulled out the tension disk assembly and cleaned it, not just spray more lubricant/cleaner on it. Is this a Bernina certified shop?! Take it back and get him to do it again right, it sounds like carbon/dirt build up in the disks. Have him pull the assembly apart and make sure it's not something else wrong with the disks themselves like oxidization etc.
If it's your bobbin thread.. your bobbin case is just dirty and the spring needs to be cleaned.
The thread doesn't really touch any other parts of the machine, hopefully your technician isn't using grease as this just causes more headaches for attracting more lint and then dirt.
Apr 17, 2009 | Bernina Virtuosa 160
Can't reassemble shuttle hook and shuttle race
the hook driver (still in machine) is 1/2 moon shape. The hook is also 1/2 moon shape. If you set the machine on its back, it's easier. Set the hook 1/2 into the other 1/2 of the hook driver to make a circle. Then put the hook cover on (machine still on its back) with the tabs for the twist locks pointed out. Needle gaurd to the top of the machine. Snap the twist locks in place and viola!
Kent
Mar 16, 2009 | Baby Lock BL1556
Sewing Machines Logo
211 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
