Question about Marconi Systems TNX 210
Sinalling channel is not comming up in marconi TNX-210
Hi ,The Physical layer is ok and it is up with out any problem , but the Signalling channel does come up for some secs and goes down and this happens every 15 -20 secs , during this period the Port will be up.
  • 32 Answers
Kindly reinstall your physical layer & reinstall drivers
Posted on Sep 19, 2009
Chanel lock
The Kenwood TK-3312e is a EU version of that handheld If you truly have that model# 3312e and not a TK-2312e.
Then you don't have VHF here the specs for the posted model# you gave.
Frequency Range: 400-470 MHz 5 Watt RF Output 128 Channels/128 Zones Built-In Voice Scrambler QT, DQT, DTMF and 5-Tone Signalling FleetSync Digital Signalling, PTT ID and SelCall MDC-1200 Signalling PC Programming
Jul 01, 2014 | Kenwood Tk-2312e / Tk-3312e vhf / Uhf...
Stuck lens
Hi, 210 wide camera lens stuck is cause the spoil gear. This is commonly happen to physical damage camera.
Dec 26, 2013 | FUJIFILM Instax 210 Film Camera
Hi, I've lost sidebar on right w/ layers, channels, paths on my CS3 photoshop. How do I retrieve it?
just click on window in your menubar and then set a checkmark behind the panels that you closed. (layers, channels, etc.)
Jul 13, 2011 | Adobe Computers & Internet
How does a router and a splitter looks like and how as well they differ?
A router is a more sophisticated network device than either a switch or a hub. Like hubs and switches, network routers are typically small, box-like pieces of equipment that multiple computers can connect to. Each features a number of "ports" the front or back that provide the connection points for these computers, a connection for electric power, and a number of LED lights to display device status. While routers, hubs and switches all share similiar physical appearance, routers differ substantially in their inner workings.
Splitter is nothing but a Switch.
Switches may operate at one or more OSI layers, including physical, data link, network, or transport (i.e., end-to-end). A device that operates simultaneously at more than one of these layers is known as a multilayer switch.
In switches intended for commercial use, built-in or modular interfaces make it possible to connect different types of networks, including Ethernet, Fibre Channel, ATM, ITU-T G.hn and 802.11. This connectivity can be at any of the layers mentioned. While Layer 2 functionality is adequate for bandwidth-shifting within one technology, interconnecting technologies such as Ethernet and token ring are easier at Layer 3.
Interconnection of different Layer 3 networks is done by routers. If there are any features that characterize "Layer-3 switches" as opposed to general-purpose routers, it tends to be that they are optimized, in larger switches, for high-density Ethernet connectivity.
Feb 07, 2011 | D-Link AirPlus DI-524 Wireless Router
Layer3
Which model are you talking about ? I have included both
Here is the OSI model
Layer 1 = physical medium & signal on the wire (physical)
Layer 2 = MAC Address and SNAP (ATM) (data link)
Layer 3 = IP Addressing V4 V6 (network)
Layer 4 = TCP/UDP (RTP, RTSP) (transport)
Layer 5 = Duplexing Half or full (Session)
Layer 6 = HTTP, FTP, SNMP (presentation)
Layer 7 = Web browser, FTP Client, (application)
TCP Model:
Layer 1 = physical medium & signal on the wire (physical) (Hub and reapeter)
Layer 2 = MAC Address and SNAP (ATM) (data) (Switches and bridges)
Layer 3 = IP Addressing V4 V6,
Layer 4 = TCP/UDP (RTP, RTSP) (Internetwork) (Firewall, IPSEC) Routers
(This function is split between 4&5) Duplexing Half or full
Layer 5 = , HTTP, FTP, SNMP, Web browser, FTP Client, (application) (programs)
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 11, 2009 | IBM Nways 8277 Model 524 Networking Switch
What is osi model
The 7 Layers of the OSI Model
Last updated: March 03, 2008
The OSI, or Open System Interconnection, model defines a networking framework for implementing protocols in seven layers. Control is passed from one layer to the next, starting at the application layer in one station, proceeding to the bottom layer, over the channel to the next station and back up the hierarchy.
Application
(Layer 7)
This layer supports application and end-user processes. Communication partners are identified, quality of service is identified, user authentication and privacy are considered, and any constraints on data syntax are identified. Everything at this layer is application-specific. This layer provides application services for file transfers, e-mail, and other network software services. Telnet and FTP are applications that exist entirely in the application level. Tiered application architectures are part of this layer.
Presentation
(Layer 6)
This layer provides independence from differences in data representation (e.g., encryption) by translating from application to network format, and vice versa. The presentation layer works to transform data into the form that the application layer can accept. This layer formats and encrypts data to be sent across a network, providing freedom from compatibility problems. It is sometimes called the syntax layer.
Session
(Layer 5)
This layer establishes, manages and terminates connections between applications. The session layer sets up, coordinates, and terminates conversations, exchanges, and dialogues between the applications at each end. It deals with session and connection coordination.
Transport
(Layer 4)
This layer provides transparent transfer of data between end systems, or hosts, and is responsible for end-to-end error recovery and flow control. It ensures complete data transfer.
Network
(Layer 3)
This layer provides switching and routing technologies, creating logical paths, known as virtual circuits, for transmitting data from node to node. Routing and forwarding are functions of this layer, as well as addressing, internetworking, error handling, congestion control and packet sequencing.
Data Link
(Layer 2)
At this layer, data packets are encoded and decoded into bits. It furnishes transmission protocol knowledge and management and handles errors in the physical layer, flow control and frame synchronization. The data link layer is divided into two sub layers: The Media Access Control (MAC) layer and the Logical Link Control (LLC) layer. The MAC sub layer controls how a computer on the network gains access to the data and permission to transmit it. The LLC layer controls frame synchronization, flow control and error checking.
Physical
(Layer 1)
This layer conveys the bit stream - electrical impulse, light or radio signal -- through the network at the electrical and mechanical level. It provides the hardware means of sending and receiving data on a carrier, including defining cables, cards and physical aspects. Fast Ethernet, RS232, and ATM are protocols with physical layer components.
For further details go to:
http://en.wikipedia.org/wiki/OSI_model
Jan 13, 2009 | Computers & Internet
BLACK SCREEN, OLYMPUS FE210
You must go to a camera technician. There are some parts inside that already been loosen. That's what happened to my camera before.
Feb 16, 2008 | Olympus FE-210 Digital Camera
Login into console
user/user system/system super/super http://tactics.marconi.com/kms/detail_controller.cgi?contentId=2587&productId=47 http://tactics.marconi.com/kms/detail_controller.cgi?contentId=3558&productId=47
Aug 23, 2007 | Marconi Systems Marconi Service Edge...
Problem with a Gateway 210 DLP projector
The color wheel may not be turning. Remove the lamp and see if it will turn manually.
Aug 08, 2007 | Gateway Projector 210 Multimedia Projector
Marconi Systems TNX 210 Logo
231 people viewed this question
Top Marconi Systems Computers & Internet Experts
David Payne
David Payne
Are you a Marconi Systems Computer and Internet Expert? Answer questions, earn points and help others
