Question about Champion International Champion& Small Engine Spark Plug 8 Pack
I have a 1987 volvo with a 2.3L engine, it cranks but has no spark
    Genius:
  • 1,071 Answers
Crank sensor is on the back in bell housing usually frayed and comin apart
Posted on Jul 24, 2009
1987 Ford Ranger 2.9 crank / no start. Does tachometer function somehow affect the spark timing?
No, but the tach signal may help you determine if coil is getting signal to spark. If tach needle is moving when engine is cranking over, that means the coil primary circuit is being turned on and off, and that means the ignition control module is working.
Oct 24, 2017 | 1987 Ford Ranger
Engine won't start,no spark at spark plugs
you will have to check the crank sensor see if fuel pump is on when cranking engine if it is check the ignighter by checking if coils are getting signal if there is no signal check fuses and cam crank sensors
Jan 14, 2011 | 1994 Volvo 850
Cuzn pulled all spark plug wires out without numbering them.. now i don't know where they go. i have a 91 volvo 740 2.3 4 cylinder.. HELP???
Cousins are fun! Is this a "distant" cousin? lol I feel your pain.
For the 2.3L SOHC AND 2,3L SOHC TURBO:
Cylinders:
(back)
...4
...3
...2
...1
(front)
Distributor:
(back)
o..o..o..o
4..3..1..2
(front)
Let me know if this helped...or if you have additional information of questions. Feel Free to contact me at FixYa.Com!
Mar 16, 2010 | 1991 Volvo 740
Volvo c70 coupe hp turbo 2,3l cuts all power - switch off, wait 30sec, switch on ,all ok till the next time
BATTERY CONNECTIONS ARE CLEAN AND TIGHT?? CABLES ARE TIGHT AT THE ENGINE. AND GROUNDED AT GROUND STRAP???
Aug 17, 2009 | Volvo C70 Cars & Trucks
1991 volvo 240 distributor doesn't turn when engine is cranking.
I believe this a belt driven engine right? Check the timing belt.
Mar 06, 2009 | 1991 Volvo 240
Engine not getting fuel
might look at the spark plug wires and plugs make sure none of the wires are burned or cracked destributer cap could also be a culprit or the rotor or the coil .
Nov 14, 2008 | 1987 Volvo 240
1987 volvo 740 turbo,cranks has fuel and spark but runs backwards when key is in run position ign computer?
Whats going on? Have you replaced your fuel pump relay?Also replace you main fuse,this is an 25amp,on the D/S fool well.
Sep 08, 2008 | 1990 Volvo 740
Champion International Champion& Small Engine Spark Plug 8 Pack  Logo
35 people viewed this question
Top Champion International Garden Experts
JohnPaul Robertson
chuck ringwood
chuck ringwood
Dennis Key
Dennis Key
Are you a Champion International Garden Expert? Answer questions, earn points and help others
