Question about Car Audio & Video
Amplifier wont turn on
The amplifier's ground got loose and it sparked. Now the amplifier is not functioning.
  • Anonymous Apr 07, 2008
    i got the same problem, i have a HK-2000D ma amp that wont power on, if you find a way to fix yours plz let me know
  • 28 Answers
if the amp doesn't have a protection circuit you probably blew it.
Posted on Nov 09, 2007
I have a 2000 harley davison sporster custom i have changed the spark plugs i have no spark at all the coil is new and the module is new but someone cut my turn single wires and put in new turn singles now...
Hi Altonbaker81, the CKP sensor needs compression to send correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Battery voltage below 8.7 volts, loose or broken battery cables especially ground cable to frame.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, MAP or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm.
For a prime suspect please visit the website below and good luck.
Harley Davidson Sportster error codes and how to access them
Aug 03, 2011 | 2000 Harley Davidson XL 1200 C Sportster...
I took my stereo out and the battert cable thouch a sertent wire and sparked. i put my stereo back in place turned my car on and now it wont turn green or red and now spark from tne batt to amp cable
electric current and voltage required for a car amplifier is the voltage of B + and ACC, commonly called the primary voltage with a mark of B + = 12Volt-13, 8 Volt and ACC from the Iginition switch, the same voltage = 12 Volt. so make sure both are available in the car audio amps. Possible loose or broken wire as you remove it, or from broken fuse, check the fuse box panel in the car for the ACC (Accecories) fuse, if broken replace with a new one (with the same Ampere)
Aug 28, 2010 | Kenwood KAC-X501F Car Audio Amplifier
Light on remote wont turn on and it is connected to the amplifier
neg terminal to ground, positivew terminal to 12volt and jump a wire from posiitve to remote wire on amp to see if it turns on
Apr 25, 2010 | Polk Audio PA250.2 Car Audio Amplifier
I have a new memphis pr 1000 and when u put power
Sounds like a grounding problem. Possibly internal.
Feb 17, 2010 | Car Audio & Video
Wont power on
Ssometimes the antenna wire is not enough to turn on the amp , some cars use relays in thier power antenna turn on set up which require low 500 ma 's . hit the amps turn on post with 12 volts directly from a jumper wire with alligator clips from main poower wire , if it still wont tunr on the amp the amp may be faulty , also check amps ground , metal its grounded must be free of paint , undercoating rug ect ....
Nov 17, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Amp wont work
open the amp and look for a loose pwer or ground wire
Mar 27, 2009 | Jensen XA4150 Car Audio Amplifier
Protection light wont go off
try checking the ground cable it migth be loose.. this happen to me once and it was a bad contact ground make sure the area is clean and tigth
Mar 12, 2009 | Car Audio & Video
Ground sparking
If the ground on the amplifier is sparking, it is either -
arcing across to the power or remote terminal via a stray wire strand, or loose inside the terminal.
If it is sparking at the chassis ground (car) - the screw is loose.
It is not normal to spark, and needs attention before the spark turns into failure of the amplifier.
Thank you for using FiXya - A FiXYa rating is appreciated!
Jan 22, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Amplifier stays in protect mode
If the positive power cable touched the ground, the fuse inline should have blown. Did it?
Sep 18, 2006 | Kenwood Excelon KAC-X541 88W x 4 Car...
Car Audio & Video Logo
329 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
