Whirlpool WTW4800XQ 3.4 cu. ft. Top Load Washer Logo
A
Anonymous Posted on Aug 20, 2014
Why is my Load Size button stuck on extra small?
The load size button is stuck on Extra small and won't move. Any advice is really appreciated . Thank you.
Imran Farid
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 49 Answers
  • Posted on Aug 21, 2014
Imran Farid
Contributor
Level 1:
New Friend:
Night Owl:
Answers
49
Questions
Helped
9764
Points
60
You need to replace the Load switch
5 Related Answers
Anonymous
  • 1073 Answers
  • Posted on Apr 23, 2008
SOURCE: Washer goes through extra rinse every time
it showes that the machine has a second rinse switch on the console set it to no second rinse
Anonymous
  • 1543 Answers
  • Posted on Nov 13, 2008
SOURCE: washed clothes while on the 'clean washer' setting
I'm sure that the exact make up of clean washer or tub clean cycles vary from brand to brand, but basically that cycle fills to a higher water level, hottest water, and highest spin, turning off load sensors / out of balance sensors so the machine can spin with water in the tub (allowing tub cleaning agents to contact all tub surfaces). (all other cycles pump the water out before spinning) Having a load of clothes in the machine at this time could result in overloading machine (gererally causing an error code), damage to suspension components, damage to hoses or connections resulting in water leaks, etc. Due to the large water level, your clothes would be agitated more ****, but the hot water might damage some fabrics. A FixYa rating would be appreciated for this info. Thanks.
Anonymous
  • 234 Answers
  • Posted on Sep 20, 2009
SOURCE: washing machiene agitator can only handle small loads
The dogs are not the problem. Assuming you have the series that uses dogs, the problem would be either: a broken motor coupling that barely grabs and can move the agitation with a small load but not with anything substantial (of which it will soon slip 100% of the time and nothing will move), or the clutch is worn and slipping---- just like a bad transmission in a car; when you go on level ground, the car has no problem, but start to go up an incline and the trans cannot do the job because it slips too much. Replacing the clutch/transmission assembly of the washer is no easy task. In either case, you need to remove the motor & pump assembly; this will give you a chance to see the coupling (if it has broken fingers). If the problem is not the coupling, you need to go to the center of the machine; the trans/clutch/shaft assembly and have good tools to handle it. A big word of advise: replace the coupling even if it does not look too bad because they go bad easily and are cheap to replace while you have it all apart. Good Luck. Macgivor.
Anonymous
  • 10 Answers
  • Posted on Jul 23, 2010
SOURCE: load size select nob is stuck in small load
the selector knob has finally taken a dump and needs to be replaced the part number you need is gonna be located on the back of the selector without a model number i have no way of looking it up for you
richroth
Richard Roth
  • 9472 Answers
  • Posted on Aug 25, 2011
SOURCE: Whirlpool Washer for RV Model LHW0050PQ4 We
You can try a pin to try and pry the button out. There is a membrane that should have returned the button to it's position. If you cannot get it to pop back out, you will need to remove the top of the washer, then the interface board to get access to the button membrane. Since the washer is mounted under the cabinet, you may need to take it to a RV shop if your not comfortable with making the repair. Here is a link to all the parts for your unit.
Dymo 210D one month old. Stuck on extra small font size. Tried taking batteries out and turning on and off 15 times. Still stuck?
Its probably not stuck-it looks like extra small is the only font available for 1/4 inch tape. I put 1/2 inch tape in and was able to access the other fonts. If you print out the 1/4 inch with extra small font there is hardly any clear border space
No water is coming on at the start of the cycle
check hot & cold hose , take off hose from washer . Put in bucket open water coming or not .
Broken load size knob. stuck on small load
Thanks for the helpful tips, got my stuck washer knob fixed , all by myself woohoo!!
6helpful
2answers
How do you increase/change font size on labeler?
To set the font size
1. Press Format
2. Select Font Size and press }.OK
3. Select the desired font size and press }.OK
The font size indicator on the display changes as you select font sizes.
1helpful
Out of balance condition
check the drain pump in the bottom of the unit and verify its not clogged, verify unit is level, also check the support struts/springs for the tub.
Could you tell me what is the colour of illumination
This unit has a multi- colored display that you can load your own custom backgrounds in the following formats:
jpl: for large size still images
jpm: for small size still images
jpa: for large size animations
jpb: for small size animations
jpw: for ImageLink
You can display two sizes of pictures and
animations .
– Large: <jpl> for the still pictures and <jpa>
for the animations;
The image can be shown as the display
background.
– Small: <jpm> for the still pictures and
<jpb> for the animations;
The image is displayed like a CD jacket (in
the same proportion of CD jacket).
The buttons light up Blue and are not changeable.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
2answers
Sheets wind together in a damp ball
I have a different model Bosch dryer, but I have the same problem.
I've found that the flat sheets dry okay if you have them in with other things (like pillowcases and t-shirts). I learned long ago though that you can't put those things in with deep fitted sheets; the little stuff winds up caught in the corners in damp wrinkly wads.
So I dry the fitted sheet separately, and throw in a couple of clean tennis balls. They're noisy, but harmless, and they keep the sheet from balling up.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
