Question about Mitsubishi WT-42413 42" Rear Projection HDTV-Ready Television
Red convergence will not adjust.
I noticed red ghosting, it was actually off to the right by 2" to 3". I tried the convergence screen, but the red + will not move. I tried the advanced convergence, but the red grid is all curled up on the left side of the screen, pretty close in the middle, and off vertically on the right side. Any attempted adjustments would not work. Help please.
  • suemooey Jul 01, 2008
    All steps described in the manual - red advanced convergence will not budge. Picture appears to have a "hammock" appearance of red at the top.
    Thank you
    Forgot to mention - mine is a model WS-55711.
Had the same problem. Tech came out and immediately knew it was cracked solder connection on one of the controllers on the back or lowe panel. He took the rear cover off, then used a soldering pencil to remelt each of the joints where the controller was soldered to the board. Problem solved.
Posted on Dec 18, 2008
    Genius:
  • 1,694 Answers
Replace STK393-570 convergence amp IC = common repair
for qualified Mits tech............................T.
Posted on Nov 22, 2007
Color is distorted. Green, red, and blue ghosts
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jul 15, 2009 | RCA P52950 52" Rear Projection Television
Red and blue ghosting,
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
Red ghosting
You need to replace the convergence amplifiers. Mitsubishi part # 267P155010 and generic part # stk393-110. If there are 2 of them in your set, replace both.
Jun 09, 2009 | Mitsubishi WS-65611 65" Rear Projection...
Ghosting
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 20, 2009 | Philips 60PP9352 60" Rear Projection...
RED GHOSTING - tried convergence adjustment with no luck in moving the red ghost
*Screen Looks 3-D
*Colors wont align
Problem #2
Jan 29, 2009 | Samsung HCN436W 43" Rear Projection...
Panasonic projection tv
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 08, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Red line convergence problem on KP-57WS510
Yes replacing the ic's should solve it. It worth a try if you want to spend the money
Jun 02, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Convergence
Did you remove 1 leg of each resistor out of circuit when you checked the resistors? sounds like thier is still one resistor open or maybe one of the new IC pins need abit more solder.
Apr 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Convergence
Typical convergence IC falure. Need to replace both at once as if ones down now, a few months down the road another one will be down. This is not a consumer or end user replacable part. As its all soldered into place and your going to need to do a master convergence alighnment when they bare replaced.
Sep 02, 2006 | Philips 60P8342 60" Rear Projection...
Mitsubishi WT-42413 42" Rear Projection HDTV-Ready Television Logo
216 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
