Question about Whirlpool GU1100XTLB / GU1100XTLQ / GU1100XTLT Built-in Dishwasher
Dishwasher pops the circuit breaker
Whirlpool #GU1100XTLQ1 dishwasher is 5 yrs. old. It started popping the circuit breaker in the electical panel during mid cycle. I replaced the circuit breaker but that didn't help. The dishwasher runs 5-10 minutes after resetting the breaker.
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Posted on Oct 03, 2010
Fisher packed dishwasher dd603
If the panel display on the lower drawer is lit and you can select the program then most likely the water inlet valve is fault and needs replacement. But if the panel is dark and none of the buttons operate then the power to the drawer is cut off. This can be due to a number of reasons including the power board at the base loosing one power circuit or the thermal fuse in the drawer is blown. Please provide model number of dishdrawer unit and also please describe what is actually happening.
Mar 07, 2018 | Fisher Dishwashers
I have a whirlpool dishwasher the normal and sani rinse and cancel lights are blinking. i cannont cancell the cycle and will not run The model # GU1100XTLT1
Shut breaker at circuit breaker panel that feeds the dishwasher for 5 minutes then turn on again and verify dishwasher has cancelled wash itself.
Jun 14, 2016 | Whirlpool Dishwashers
No electric to dishwasher
Not connected/Breaker off in electrical panel/Door not locking to complete the electrical circuit.
Dec 12, 2013 | Whirlpool Dishwashers
Kenmore DW model #665 16023403 will not turn on. There is power to the DW but the panel does not light up. Checked circuit breaker. Door tightly shut and latches. Just 3 yrs old. Would love to fix myself....
The electronic control panel should be replaced and cost about $240. It is easy to remove and replaced --- pull and plug like a standard elect plug, only its flat.
This definitely works.
Sep 04, 2012 | KitchenAid 24 in. KUDP01IL - Multiple...
Miele Advanta G2170 working fine 2 yrs, suddenly starts popping breakers and won't run (on any outlet) Electrical system in home is about 3 yrs old only.
Hi dear.If the washer is tripping circuit breaker,as long as you plug in,there is a Interference filter capacitor inside of the machine.Main power gets connect there first.It should be faulty & needs to be replaced.I hope that helps Thanks.
Aug 31, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Dishwasher tripped our main circuit breaker.
It may be that your water pump is leaking on to the motor...
Dec 09, 2009 | KitchenAid KUDR01TJ Dishwasher
Washer stopped mid-cycle, water in the bottom of the tub. Circuit breaker popped due to over-load. Reset breaker and it immediately popped again. Could this be cause by a jam in the grinder assembly?
My dishwasher just quit mid cycle. (still has water in it) It is a whirlpool partner 1. I checked the breaker and it wasn't tripped... but i reset it anyways. When I tried the dishwasher again it worked for a second and turned off. I have done reading about the thermo fuse but can't find it. Not sure how big of a problem this is.
Dishwasher is 5 years old.
Thanks,
Dale
Jul 02, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher won't start!
I've provided a link to the manual for your dishwasher. You should check for proper wiring and that the water line is connected and turned on.
The washer should start to fill when you press a cycle.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208283509.pdf
May 09, 2009 | Dishwashers
Rating and reviews for a dishwasher
they seem to be a good unit and from the model your looking is just over 5 years old / larry
Nov 29, 2008 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Bosch SHU3306UC dishwasher stopped
Make sure you visit the Bosch dishwasher recall website as this model is under the recall with a faulty controller which may cause a fire! Check your model under http://microsites.boschappliances.com/safetyrecall/dishwasher/
then call 800.856.9226 to setup a recall repair appointment. We just found out about this recall and was never notified by Bosch even though we registered our unit after we purchased it...talk about poor customer service! Hope this helps!
Sep 04, 2007 | Bosch SHU3306UC Built-in Dishwasher
Whirlpool GU1100XTLB / GU1100XTLQ / GU1100XTLT Built-in Dishwasher Logo
1,432 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
