Question about Nikon Coolpix 885 Digital Camera
Warning Lense Cap On
The lense cap is off but the warning is not. Is there a solution to this problem? I cannot use the camera at all currently.
  • slosee Nov 10, 2007
    Same problem. My lens cap is off, but the warning is on and the camera is unusable. Please advise.
This will sound crazy, but I just read the section under "Tips and Tricks" entitled, "Freezing". Users there recommend dropping the camera (gently) about an inch down onto your mousepad, or squeezing the casing of the camera, expecially around the battery. I squeezed the camera around the lens and Viola!, no more problem.
Posted on Nov 10, 2007
I also cannot use my camera.  It is broken as far as I am concerned. HELP?
Posted on Apr 02, 2008
Will not work
Try to find out if there is something else obstructing the free movement of the lens barrel. And then try to find out if your battery (yes) are still ok. If they can't give enough power, the motor to drive the lens, can't work and the camera also "thinks" the lens got stuck.
Sometimes, a gear that is involved with moving the lens became broke. If that happens, only a repair shop can help.
Nov 24, 2013 | Kodak EasyShare C142 Digital Camera
In the middle of taking pictures, all of a sudden my Nikon P100 will become blurry and then the Lense Error message will come up saying, "Lense Error: if the lense cap is on the camera, turn the...
Could be sand particles getting into the seams around the lens barrel, binding it up. Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 08, 2011 | Nikon COOLPIX P100 Digital Camera
Lense Cap
the technology has malfunctioned
May 23, 2009 | Video Cameras
No subject in LCD
You have a CCD image sensor defect, it can be repaired for free. Go th link http://www.jvcservice.com/service/custnoticecamcoder.asp?Type=CCD Select your modle then click on Repair Repuest Link. Fill out the form and print two copies, ship your unit with a copy of the form to the nearest jvc repair center near you.
Mar 22, 2009 | JVC GR-D33US Camcorder
LENSE CAP WARNING STAYS ON EVEN WHEN IT IS REMOVED?
Mine went back to JVC because it was a design problem. They fixed it for free.
Sep 20, 2008 | JVC Everio GZ-MG130 Camcorder
Hp photosmart r725 6.2 megapixels.
If you're getting the 18-4489-957-000 error code, then give it a good tap on the corner where the lens cap is. A little tapping and the lens cover should pop closed. When you turn the camera on again it will probably work just fine.
I was just about to junk my camera when I googled the error code and found this very tip in another thread. It worked like a charm.
May 29, 2008 | HP Photosmart R725 Digital Camera
FZ18 Lens Cap error message with telephoto converter
I have the same camera, and had the same problem. Make sure the camera is switched off. Then take 2 hard pieces of plastic with sharp ends. Carefully try & jam the outer ring with one, and try turning the converter with the other. I used a mini screwdriver, and left some marks on my camera. Thats why I recomend using plastic of some kind.
When you use the converter, switch off the battery saver in the camera. That way the converter won't jam again, as the camera won't switch off automatically. There is also a programme in the menu that is used for converters and external lenses. It also prevents the lens from retracting completely.
Hope I have helped you.
DaveSA
Mar 21, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
JVC Camcorder GR DX95EK Lense cap problem
Contacted JVC, they fix this fault free,irrespective of the age of the camera
Mar 19, 2008 | JVC GR-DX95E Mini DV Digital Camcorder
Panasonic DMC-FZ7 digital camera.
I believe the FZ7 determines that the lense cap is still on when it can't extend the zoom lense because the lense cap is in the way. I would check to see if your zoom lense housing is somehow stuck (could be sand or dirt in it) which is creating enough resistance to make the camera think the lense cap is impeding the zoom lense from extending.
Jan 03, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Nikon Coolpix 885 Digital Camera Logo
97 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
