This is an intermitant problem. doesn't happen all the time
To recharge the current taken out of the battery during start up requires at least 10 -15 miles driving. Driving less than that, progressively drains the battery available power until it has not enough power for another start. Such a battery "resting" for more than 10 minute might regain enough power for a start but is inherently flat. Put it on a battery charger for at least 12 hours or go on a 2 hour or more drive. It should be OK for quite a number of starts even when doing short distance driving. If it is showing the same symptoms directly after to 12 hour charge/drive get the battery tested at a garage or battery dealer who will be able to tell if the battery needs replacement. If the battery test OK there might be bigger problems like a blown top gasket or problems with the starter motor.
SOURCE: Intermitant temperature
Check to make sure your thermostat works right by monitoring the warming up of your engine. With a completely cold engine, start and run the engine for a few minutes, then put your hand on the top radiator hose to monitor if and when it gets warm as the thermostat opens more and more and note the gauge reading( if it works) the top radiator hose should be unbearably hot within 5-8 minutes. If the therm. opens right it should close right aswell, staying open a little while eventhough the radiator may have cooled may be what you are experiencing causing the rapid cooling and is nothing to worry about. The Hose should not get warm very soon after starting the engine. Regarding you gauge, lets take one step at a time, verify proper op. or the therm.
SOURCE: 1994 Toyota Tercel Starter Problems
sounds to me that you have an igniton problem not a starter problem and or if you have or had an alarm system could be cause if u do give me feedback and i will explain but seems that your starter is fine from what u say but if you think in terms of the elemts to start a vehicle batery gives pwoer to ignition which sends to starter which gives spark etc i would check you ignition system something is causeing a short and not alowing starter to function
SOURCE: 2006 Toyota Rav 4-My battery went from fine to dead in :45. Help.
Answering your questions in order:
In summary, most should get more than 3 years out of their battery. You've already determined that the acid levels in the battery are good (most don't even check for fluid levels). Constant charging and discharging will kill a battery and this isn't apparent in your case.
If a battery charger isn't handy, try hooking up the jumper cables and leave the other car running for at least 15 minutes. I hope this answers your questions. Best of luck.
Greg
SOURCE: i hqve a 1995 toyota camry with intermitent start
Sounds like the wiring plug (key/ignition) The toyota manual pictures the plug and its connections but gives no clue where it's located.
Your radio is a good clue to this glitch. It's losing it's constant (unswitched) elec. power. This means either your car is having a dead elec.system,, or a relay is loose or going bad. Check the security of all your relays under the hood.
Take it to a good shop, but not a Toyota shop.
Finally, try starting in neutral nextime it won't start. Hold the key in start and reach over with your left hand and slide the lever into neutral.. clumbsy but thats the way to do it.
SOURCE: 1991 Toyota Camry Won't crank, dash dead, no lights
I HAD SAME PROBLEM SOLVER OF MY MOMS 1996 CAMRY ABOUT HORN GOING OFF AND CAR WOULDN'T CRANK. JUMPED IT OFF AFTER A FEWW FRANTIC MOMENTS OF HORN HONKING-- FOUND OU IT WAS AN ALARM THING AND YOU CAN SHUT IT OFF BY TURNING IGNITION KEY TO ON POSITION AND MOVING TOGGLE SWITCH AT DRIVER KICK PANEL TO OVERIDE THE HONKING HORN PROBLEM--STILL NOT SURE WHAT CAUSED IT TO DO THIS AT BEGINNING. BATTERY WAS FULLY CHARGED AND HEADLIGHTS REAL BRIGHT TOO. COULD HAVE BEEN A DOORLOCK MANUAL MALFUNCTION--BEEN OK FOR A WEEK NOW.
