Question about Sony DSR-25 Mini DV VCR
Firewire will not work - Sony DSR-25 Mini DV VCR
    Champion:
  • 221 Answers
Most common problem associated with failure of firewire on the DSR-25 involves replacement of a circuit board which costs about $500.00.
Posted on Aug 05, 2009
Firewire not working.
Seems likely. FireWire connectors use dip switches to signal to the computer what inputs and outputs it needs
Nov 13, 2017 | Panasonic AJ-D230H DV/Mini DV VCR
Step by step instructions to transfer recorded videos from jvc gr-d370u to Pc, please.
First, you need a Firewire connection (also called IEEE 1394). Most of PC computers don't have it, including mine. I bought a cheap Firewire card and installed it into an empty PCI slot, costed about $15.
I hope you don't have the USB cable and the firewire cable plugged into your computer at the same time. That can break things.
With the firewire cable plugged into the DV port of the camcorder and the firewire port of the computer and the camcorder is in Play mode (and plugged into the wall AC power with the power adapter), are you saying that when you launch MovieMaker and "Capture", the video camera is not recognized?
There are only two conditions that can cause this:
1) The firewire400 port on the computer is not working properly (how do you know it is working?). If you are using Vista Home Basic, chances are good that the IEEE1394a firewire port drivers were never loaded... so, that will be your first step. Get that port working and you'll be ready to go.
2) The DV port on the camcorder is not working properly. This could be for several reasons, but lets hope the DV port was not fried if you ever had the USB and firewire connections to your computer at the same time... Reset the camcorder to factory defaults by disconnecting all cables, removing the rechargeable battery and removing the little date/time button battery inside the camcorder. Wait for about 20 minutes. Put the button battery back in, then put the rechargeable battery back on. Set the date and time. Connect the firewire cable to the DV port, connect the AC power adapter to the wall, connect the other side of the firewire cable to the firewire port on the computer, launch MovieMaker - will it "Capture" from the video tape?
Anyone you know nearby with an Apple Macintosh and iMovieHD? You will need a 4-pin to 6-pin firewire cable and the AC power adapter. If it works with the Mac, we know it is not the camcorder's DV port. If it does not work, chances are good the camcorder's firewire port is bad.
Hope this was helpful?
Jan 30, 2011 | JVC GR D370US camcorder Mini DV
Hi, The firewire connection on my tascam fw-1804 has suddenly stopped working. I have tried replacing the cable and re-installing the drivers and still haver the problem. Can anyone help please? I'm...
First thing I would look into is the machine that has the other firewire port. Many machines use firewire ports that do not work well at all with professional audio interfaces. I had to replace my firewire card with a better one on a brand new machine to get my software to work correctly.
You might try rebooting the host machine and checking its firewire ports.
Hope this helps.
Oct 11, 2009 | Tascam FW-1804 External Sound System
How do i get my FA-66 to work via firewire?? please help!!!!!!!
u're probably trying to connect it with a 4 to 6 pins firewire cable to your laptop right?
if so, the laptop firewire connection is usually the small type (4 pins). this kind
of connection does not give Power to the firewire device.
u can buy a pcmcia card with 6pin firewire connections and usa a 6 to 6 firewire cable
and that will work. i hope. :)
Oct 06, 2008 | Edirol FA-66 Sound Card
Firewire
firewire is a lot like usb in the power area if the drive is not getting power i would suspect the firewire port. firewire did not become very popular because of problems like these. You need to go down to a computer parts store and by a firewire card and that should provide enough power and bypass the on-board ports. Try to hook another device up to the firewire ports and see if they work if not install the daughterboard with firewire ports
Jul 10, 2008 | HP Pavilion a1240n (EG136AA) PC Desktop
Firewire
Yes, you can capture camcorder video from a miniDV camcorder using a FireWire cable and video capture software. Your computer came pre-installed with Windows Movie Maker, or iMovie (if you are on a Mac).
FireWire, IEEE 1394 and iLink are all the same thing. There are 4 and 6 pin FireWire cords. My guess is that you need a 4pin to connect to your camcorder and a 6 pin to connect to your computer. But it all depends on what ports you have available.
You can get a FireWire cord for less than $10 at most computer electronics stores
Check out this FireWire guide for more information:
http://www.stashspace.com/video-editing/firewire-guide.stm
Mar 14, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Two units conflict when connected thru Firewire 400
Windows XP and most pcs running it does not natively support firewire,as it was developed by Apple computers. Most Firewire ports on PCs are 4 pin. Your PCI card ( and I take it, its a desktop youre referring to ) should have a 6 pin connection. Firewire connections also have a 7 watt supply via the bus. You may need to open the computer and see if the molex jack on the card is being powered by your computers power supply. Two firewire drives, especially the power hungry Lacie quadras, may be to much consumption for the card. Hope this helps.
Sep 23, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Sony DSR-25 Mini DV VCR Logo
218 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
