Question about Black & Decker Lawn Hog 18-Inch 12 Amp Electric Mulching Mower
We have a black & decker series 200 lawn mower and cannot figure out how to adjust the height of the wheels...we can't seem to find an owners manual...please help!
SOURCE: Saw your post about Black and Decker MM525 Lawn Mower
With the Black and deckers, I think you just take the blade off and turn it over. That wil direct the grass clippings down into the ground.
Posted on May 10, 2008
SOURCE: black and decker mm675 lawn hog
Wedge a short piece of 2x4 between the blade and the housing,
turn clockwise to tighten !
Posted on May 23, 2008
  • 313 Answers
SOURCE: Can't start my mm525 black and decker electric mower
checked out dewaltservicenet for further info.
maybe a broken switch our possible broken armature comm
Posted on May 29, 2008
  • 313 Answers
SOURCE: WIRING DIAGRAM? FOR BLACK AND DECKER ELECTRIC LAWN MOWER
the pic says the connection are not right.all left side connection are for brake which is the red & white wire. all right side connection are two black wire.
Posted on May 31, 2008
frcs68
  • 1605 Answers
SOURCE: electric mower won't cut well
change a new blade. when was the last time the blade gotten changed?
Posted on May 22, 2009
I have an old Black and Decker Electric Lawnmower Series 2000 Model M2140 and would like to know how to adjust the cutting height.
Not sure about this one but most mowers whether electric or gasoline has several holes ( usually three ] where the wheels fasten on.
If you want to cut high then make sure all four wheels are fastened on the bottom holes. I set most of my mowers in the middle holes. You have to make sure all four wheels are all the same holes. Usually if they are set in the top holes you are cutting your grass too short and will burn your lawn in hot weather.
Aug 05, 2017 | Electric Garden
Have an old Black and Decker Electric Lawnmower Series 2000 Model M2140 and would like to know how to adjust the cutting height.
How do I engage back the height adjust on my black and decker lawn hog
if there are no adjustments at the rear wheels install new wheels to accommodate mowing hieght
Dec 05, 2014 | Black & Decker Black and Decker Mm575 18"...
How to adjust the height of the mower
If you mower does not have adjusters on the wheels then there should be three holes where the wheels are bolted onto the base. to adjust these you have to take each wheel off and bolt them in the same hole for each wheel. The top holes are the lowest the mower can be set the middle ones bring it up part way and the bottom hole is the highest setting. You should set the mower to cut at least two and a half inches above the ground. The center holes should be good.
May 12, 2014 | Black & Decker 19" Electric Lawnhog...
Black and decker 18 inch flip over handle electric lawn mower cat #8019 don't know how to adjust height it is cutting way too low
There is no height lever on this simple mower. To change the height of cut, the wheels themselves must be moved up or down. First, unplug the mower. Turn it over on its side. You'll see that the wheels attach to the frame with simple bolts, and that there are two open holes at each wheel (three holes at different heights altogether, but one of the holes is occupied by the current mounting height of the wheels). Undo each bolt for all four wheels and move them to a new position. Note that the wheel-mounting holes are drilled 5/8-inch apart from each other. If you want to add another hole there is room on the sheet metal to make a new hole for each wheel, and this would put the mower body and blade very high off the ground, if used. You can make that new hole for each wheel with your electric drill. But I think your mower is probably set to the lowest of the three holes, so see first if moving the wheels 5/8-inch higher is better for your lawn, and, if not, then use the 1 1/4-inch higher set of holes on all four wheels. Make sure to move each wheel to the same height hole! Good luck, be safe. --Joe, Tucson, AZ
Apr 30, 2011 | Garden
My 18" 12 amp B&D mower has become loud and vibrates so much that the wheel height adjustment pops out. Any suggestions?
Most likely bent shaft or blade. Worst case motor is on the way out maybe bad bearing or something along those lines.
Sep 18, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Black&Decker MM675 lawn mower height lever would not stay
I would look in my owners manual and get the part number for the height lever and order a new one. You could also try and wire the height lever so it can not move. I am not sure how it engages but you could may be try and bend the lever so it is tight and won't move. Just a couple of ideas.
Good luck
Aug 31, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Electric mower won't cut well
May 22, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Adjusting the wheel height
its in the left side at the back end. a plastic orange color lever that you have to press up while pushing the mower up or down
May 25, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker Lawn Hog 18-Inch 12 Amp Electric Mulching Mower Logo
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
