Question about Black & Decker 19" Electric Lawnhog Mulching Mower
Ok so the cord at the bottem of my electric lawn mower had somehow got a slice n it so i took of the lil case thats starts it and cant remember how it goes bak together help me please
  • 22 Answers
SOURCE: I have Black and decker electric lawn mower does not start
one of the problems i found with electric detectors was that they do not tell you if there is a break in the neutral cable so you could have a break there,another problem is that the levers can break inside the cover giving the impression that it should work but is not making contact with the switch ,hope this helps
Posted on Mar 30, 2009
  • 18 Answers
SOURCE: Black and Decker 18 inch electric lawn mower turned off
Try the link at the bottom of this page : "Find Manuals".
Posted on Jun 11, 2009
lindsay836
  • 677 Answers
SOURCE: my corded 18
There should be what is called a "thermal breaker" on this. It should either re-set itself or you may have to push a little button down by the motor.
Please let me know, we repair this kind of equipment.
Posted on Feb 10, 2010
  • 52 Answers
SOURCE: Stopped. Black and Decker Lawn Hog 18-Inch Electric Lawn mowe
you could check the brush connection on the motor or your switch mat not be making contact
Posted on Apr 15, 2010
SOURCE: elect mower blade replacement
mower, then blade, then plastic part, then metal square washer, then nut
Posted on May 08, 2010
My MM1800 started to smoke?
Return it to the retailer for service. it presumably has a warranty that the supplier is obliged to honour. As long as they do not argue that you were somehow not using the device in the manner it was intended you should have no problems. The retailer should, in any case, contact the manufacturer for authorisation to repair or replace.
Jun 03, 2015 | Black and Decker USA Black & Decker MM1800...
Lawnmower starting problems
you wrapped the rope backwards
Aug 16, 2014 | Garden
Neighbor mowed the extension cord and mower won't start
Check the cord has been properly replaced. Check circuit with a meter (NOT connected to mains) The live pin on plug should connect to live pin on motor switch etc. (need to take off cover on switch unit)
Cutting through the cord should not have damaged the mower.
Jul 13, 2013 | Electric Lawn Mower
Electric Mower electrocuted?
wire disconnect in lawn mower.
SmengesI have a briggs statton 6.75 series Craftman lawn mower 21" cut ,that I cant start. Recently serviced with spark plug, oil and air filter replacement. Brought it home and it the same problem....
I can only go by what you say was done. If you took mower to repairman then it should run. If you took to a buddy who thought he knew, WELL.
Try this first. The primer button is a round button usually BLACK, CLEAR, or RED. Look around your mower and you will find it at the end of the carburator. Carburator is opposite the muffler on your mower. With new gas in your mower ,press the primer button three or four times. Try to start. With all you have done it should start. If it doesn't start, think back and try to remember if you hit something while mowing, if you did then your problem is your timing. With the hit you sheared your timing key. This key keeps your fuel ,compression, and spark happily together to keep your engine running.
Check the other things first and please get back to me, I will be more than happy to help you further. GOOD LUCK.
Sep 01, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Lawnboy model 10640 walk-behind mower pull cord will not retract. I've removed the plastic engine covering, removed the top bolts of the gas tank and rotated the tank back. With the flywheel cover being...
I have the exact same problem. I read on another site that the blowout hole in the back of the mower where the grass goes into the catcher must be cleared of any grass or dirt. I don't use the grass catcher and indeed the hole was full of dirt and grass. I cleared out what I could with my hands and a screwdriver, and magically somehow the cord retracted about a foot. Enough to start the mower with. It still doesn't retract all the way, but it was an improvement. I may have worn out the spring pulling and tugging on it trying to get it to retract, but ok for now.
Please share if you find a more permanent solution. Mower is barely a year old.
Apr 21, 2011 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Electric Lawn Mower Doesn't start - Pwr supply ok - No burnt Moto
this mower has a dc motor and the brush on the black wire to the motor usally wears down
Mar 03, 2010 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower Logo
62 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
