Question about Standard (CRT) Televisions
2 Suggested Answers
SOURCE: Looking for Universal remote code for Prima 27"??
238 seems to be the right code for the Prima tv but also doesnt seem to work for many pople. I am at a lost with my Prima
Posted on Jan 31, 2009
SOURCE: sansui tv remote code ALLFORONE Universal Remote URC2020B02
i have a one for all remote how do i program it to a sansui tv
Posted on Dec 19, 2009
0 characters
1 Points
How to program a universal remote for the Sansui
It may mean that the code you entered is incorrect. Try these: 0135, 0310 and 0394.
Jul 12, 2010 | Sansui DTV3200 32" TV
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? ( has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
How do you change the chanel to AV without remote, dont give the option on the tv buttons
check the website for the remote you have bought and enter the codes for newer models of your make of tv keep trying 1 of them should work but might not give you all functions like teletext
Jun 03, 2009 | Standard (CRT) Televisions
Sanyo ds 27510 tv no remote want to setup my tv with an antennea,wont switch from video 2
If it has a MENU button, press it and use the volume up and down to manipulate the choices, press menu again when you get to channel setup. you want AIR if using off air or Cable for cable. Next screen should say start and press menu again, the channels will start to cycle. If htat doesnt do it, you have a new model than the one I just did tonight. OneForall remotes will probably not have the setup button you need to autoprogram. Best bet is to find a Sanyo made universal remote or other Sanyo remote on Ebay as alot of the buttons are proprietary to manufacturer. Some TV's are useless without their own remote if not on a external tuner (cable SAT or digital)
May 13, 2009 | Sanyo DS27510 27" TV
Change the input on a sansui tvm1916 to front composite
you can't. You'll need to purchase a new (programmable) remote and program it for your tv.
Cost ? $5-$10
Mar 14, 2009 | Sansui TVM1916 19" TV
You can try codes for Orion, Emerson and RCA.
Aug 02, 2008 | Sansui COM3101 13" TV/VCR
Sansui tv remote code ALLFORONE Universal Remote URC2020B02
Jan 14, 2008 | Sansui DTV2760 27" TV
When i hook up dvd/ps2 i cant get it to show up on the screen
You have to have a remote control to set the chanel to 00. You cannot set the chanel to 00 with the chanel buttons on the front of the tv.
Jan 02, 2008 | RCA F20352SF TV
27" Sansui
you might not be able to use a universal remote to access specific functions on the TV.  The universal remote was designed for basic use, and has slightly evolved, but still lacks in some areas.  I suggest finding a Sansui remote, specifically for that TV model.
Oct 19, 2007 | Sansui DTV2760 27" TV
Using an RCA universal remote
WIKIPEDIA has this link for your situation: How to Program an RCA Universal Remote Without a "Code Search" Button I think that should help with your situation. Let me know if it does not.
Aug 23, 2007 | Sansui COM3101 13" TV/VCR
Standard (CRT) Televisions Logo
80 people viewed this question
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
