Question about GE Advantium SCA1001HSS Convection Microwave Oven
I have an advantium 120 oven - sca1001hss02 oven. Whether using the microwave or the oven, the same things happens. After about 4 seconds the advantium stops working and a message pops up that reads, ''Check food - Power Failed While Cooking.'' I could not find anything similar in any postings I read, or at the GE site. Thank you, Monamay
  • 4 Answers
SOURCE: ge advantium 120 microwave
It's pretty simple as long as you have an offset phillips screwdriver...
Of course, be sure to disconnect power to microwave and be sure not to touch the new halogen bulb with fingers.
STEP-BY-STEP:
First, remove upper vent panel and remove inner filter (same directions for just replacing inner carbon filter):
Then, remove inner plastic grille (2 screws) and final screw on left side of metal "air duct" - here's where you'll need the offset screw driver (and a little patience!):
Then, you can gently lift the sheet metal panel, find the light housing, squeeze and remove/replace :)
That's it...just replace bulb and reverse for reassembly. Be sure to keep track of screw locations there are various sizes/lengths used.
Doug
Posted on Dec 26, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Broken Bottom Latch Pawl GE Advantium 120 Microwave
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 25, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Advantium 120 thermostat/schematics
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing some components for testing and possible replacement (such as the oven cavity thermostat / TCO) will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Jan 31, 2009
SOURCE: control panel "locked" on ge advantium 120
You might have set the child lock. Look in the manual. It is on P.36 in my manual.
Posted on May 16, 2009
jsrock516
  • 5911 Answers
SOURCE: Handle broke off my GE Advantium 120 microwave
You are correct. The handle screws can be accessed by simply removing the interior facing of the door, and can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: You can view some excellent exploded view diagrams of your oven at pcappliancerepair.com as reference to see how the parts are assembled.
Posted on Sep 16, 2009
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
Advantium 120 model # SCA1001HSS03 has died and working. The circuit breakers is fine. The dedicated electrical line is working fine. There are no lights, no sign of life. The oven was working and at the...
Many microwave ovens have an internal fuse , but I was recently told by a dealer that any unit costing under 200.00 was not worth fixing .my fuse cost 3.15 from local home improvement store
Oct 19, 2017 | GE Advantium 120 Convection/Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
How do I unlock the control panel
If this is a GE Advantium series microwave, the control panel can be locked to prevent children from manipulating the controls. To lock or unlock, press and hold the CLEAR/OFF button for 5 seconds. These instructions are included on page 36 of the owner's manual listed here:
http://www.managemylife.com/mmh/owner_manuals/14895/GE-Built-In-Microwave-Oven-L0902200?brand_name_search=+GE+Advantium+120
If you have questions, please post back and let me know. Please include your MODEL NUMBER if diffrent form the model you posted this question under. I hope this helps you.
May 20, 2010 | GE Advantium 120 Convection/Microwave Oven
How to replace light inside of Advantium 120 oven
I am looking for the same... How to replace the light inside the Advantium 120 oven. Any answers out there?
Jan 04, 2010 | GE Advantium 120 Convection/Microwave Oven
How do I replace the fuse in a GE Advantium SCA1001KSS?
under the outer cover on a fuse clip its a special fuse avail at hardware stores
Oct 08, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave power seems to have died
My advantium 120 died and it has power to the oven but it does not work! does the oven have a fuse that i can change?
Sep 29, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Opinion
I have had an Advantium for about 3 or 4 yrs and would use nothing else! When this one wears out I will buy another one! I hardly ever use my regular oven any more! Hope this helps.
Feb 02, 2009 | GE Advantium 120 Convection/Microwave Oven
How do you replace the handle on my advantium 120 oven
If it's just the bottom one and you don't want to disassemble things to reconnect things right, drill a pilot hole in at an angle through handle and door to permit screwing in a wood screw to fix it up.  Brutish, yet sexy.
Dec 13, 2008 | GE Advantium 120 Convection/Microwave Oven
Advantium Microwave Oven
it is automatic, you can not turn it off. it is placed there so that the food you are heating is heated evenly. not on one side only.
tnx 4 using fixya.
drcool
Aug 26, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Advantium SCA1001HSS Convection Microwave Oven Logo
302 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
