Question about Sony Televison & Video
Kdl 32m3000 we have changed 3 boards on this
Kdl 32m3000 we have changed 3 boards on this tv.
the logic board the LVDS board and the inverter board were changed.
The problem still persists, the unit comes on for a second we see the sony logo and then it disipeares, the sound however is there, we can hear it.
all voltages on the psu are correct.
we are at our wits end could you help?
    Novelist:
  • 65 Answers
That's correct it is the LCD panel. This is actually a common problem with this model, and its surprising that it really does look like a video board (BM board) problem. It is actually a problem with the panel itself.
Here is the fix:
http://www.youtube.com/watch?v=9UrTVEC5LkA&feature=related
This guy was kind enough to post it. I recently did the repair on a KDL-32M3000 and it worked like a charm. Took surprising long, but worked like a charm. I didn't have a 10 Ohm resistor laying around, so I used 2 x 4.7 Ohm resistors in series.
Posted on Dec 09, 2011
  • 197 Answers
Unit as a bad lcd panel sony may have an extennded warranty on panel
Posted on Jul 01, 2009
CAN YOU DIRECT ME TO EITHER THE INVERTER BOARD OR THE MAIN BOARD.
Hello Calvin,
I would suggest to change the input to a video with audio source to eliminate a main board failure.
If the back lights are not working, this could indicate that the inverter board is defective but there could also be a defective CCFL light failure.
You can find service parts in the link provided.
Let me know if you required further assistance. Search results for kdl 40bx450
Jun 08, 2017 | Sony Televison & Video
Sony Bravia KDL-xbr4 Replaced TCON board All worked great for a week Had an issue w/ HDMI cable at the box fixed it and now tv comes and the goes off to 6 blinking red lights
6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter
Have this from a youtube link find BUT
Better is to look first also on bad leaking or bulged capacitors thats better to replace in the bad components to get a repair because active components died on bad capacitors but after a while because on the build-in protection circuit by faults like deformed or leaking capacitors and even several fuse resistors then after replace a complete board again after a while you will may be get the same kind of problems again, take If you find some or much bad capacitors replacements 10 volts dc higher . begin with control on the power supply first of all.
Sony Bravia TV kdl red blinking led light error codes solutions Sony KDL 40XBR4 KDL 40XBR5 KDL 46XBR4 KDL 46XBR5 Service Manual
Jan 05, 2017 | Sony Televison & Video
Sony 32" LCD TV KDL-32M3000. No picture, LED will
What does it do if you unhook the flat cables going from the tcon to the panel, does the blinking go away and do you have sound then?
Dec 10, 2017 | Sony KDL-32M3000 32 in. LCD Television
I have a Sony KDL-32M3000 LCD TV.. When I turn the tv on you can see the screen lite up with no kind of picture, Almost like a lite comes on then goes out the the lite comes on again with no picture but I...
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!!@#
Mar 25, 2011 | Sony KDL-32M3000 32 in. LCD Television
Screen dark but can still see picture
could be a problem with the inverter board which is the power board for the CCFL backlight system. if the tv doesnt actually go into shutdown you may be able to still see the video but it will be very dark no glow to the screen at all. the reasons for shutdown for inverter failure could be a bad inverter transformer or open fuse on the inverter that supplies power to the board or it could even be a bad CCFL lamp. i suggest looking for the fuse that is the most likely suspect it may be yellow if i remember correctly. good luck
Jan 18, 2011 | Sony KDL-32M3000 32 in. LCD Television
I purchased a Sony EX400 from S'pore. Presently using it in India. Of late it stopped working and the red lighting started blinking. 7 times after a small interval. What may be the problem. Approx....
The Blinking red light. suggests logical errors detected b the main board. e.g TMDS/LVDS cable being faulty. Inverter not responding etc. the cable will be the likely culprit.
Sep 26, 2010 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony Bravia KDL-32M3000 Has sound, no picture, back-lights are on, red lines flickering across the screen which seems to prove there is video present. I'm thinking T-Con board. I ask this question because...
There is no way to really check a T con without a lot of test equipment, only thing that is serviceable on that board is the small fuse that is by the LVDS connector...
Dec 19, 2017 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
KDL-32ML130 Sony Bravio 32' LCD HDTV motion blur
Logic board? Are you referring to the Main PCB (BU board I think). This issue is caused by the Timing Control board (T-CON). It’s the board directly on the panel that connects by LVDS cable to the Main PCB. Not sure if it’s a part you can purchase separate from the LCD panel, but give it a whirl… you never know. I hope this was of some assistance.
Mar 25, 2010 | Televison & Video
I have a sony 32m3000 color is dark and red also
@circuitworld: You claim in your profile that you repair plasma and LCD TV's, but you just told someone with an LCD to replace the convergence IC's and linear buffers. First off, convergence IC's are in rear projection TV's not LCD's, and the buffer boards are in plasma's, again, not in LCD's
@gardenwc: Typically what you are experiencing is a bad video controller or an actual faulty panel, the latter of which is not cost effective to replace.
Nov 03, 2009 | Sony KDL-32M3000 32 in. LCD Television
Slow moving image sony bravia KDL32M3000
Hello darwin_gabou, My names Dave! You have a bad A/V input board.
Part #: A-1376-788-A
Link to part: http://www.shopjimmy.com/catalog/product/view/id/169673/s/sony-a-1376-788-a-bm-board-for-kdl-32m3000/
Please feel free to contact me if you have any question. I'll be more then happy to answer any questions you may have!
Dave
503-432-9904
Premium TV Tech
www.pleasefixitdave.com
pleasefixitdave@yahoo.com
Sep 23, 2009 | Sony KDL-32M3000 32 in. LCD Television
Televison & Video Logo
246 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
