Question about Garden
It probably cannot be the first time: All installed. Floor and bassins installed with marble and the water does not stay in the bassins. During a 24 hours period the bassins are allmost empty. All pipes and connections made in PVC. Any material you can use to fix the holes?
    Brigadier General:
  • 4,088 Answers
What does this have to do with chainsaws?
Posted on Jul 04, 2009
I have an ventless , or condensation, dryer. This is my second unit in 5 weeks. They both leaked over a cup of water on the floor during the cycle. Also they both stop within the cycle (about 4x) and...
I am not completely familiar with that unit, but if I had already 2 units supposedly fail with the exact same symptoms, I would in a different direction for resolve. Installation? There is not a likely probability that 2 machines are defective with the exact failure. Check instructions on install and make sure the exact instructions are being followed.
Dec 29, 2014 | LG DLEC855W 24" Compact Ventless Electric...
Why the most of the folks prefer the marble polishing?
The polish can perform wonders and boost the look of marbled floors. Because it is extremely porous, these people get scratched very easily by white vinegar, fruit, tomato juice or some kind of other activities which contain acids. As well as certain kinds of marble that will get etched by drinking water.
Therefore marble polishing should be completed with the best materials.
Nov 06, 2014 | Clarke MP-1800 Marble Polisher
I've got water coming in through the bottom of my door at work. It's coming in a steady stream through a crack in the marble. Can someone please give me a pointer or two?
If you have water pipes/ heating pipes in the concrete floor then from the crack I would suggest that the floor movement has broken a pipe allowing the water to flow out the crack under the door. To test this turn the water off at the mains and if the water stops flowing after a short period of time then that will indicate the fault. Allow enough time for the water in the pipes up to taps to drain back out
Jul 01, 2014 | Building Materials
Remove hard water and soap **** from marble
Make a paste of 1/3 baking soda to 2/3 water and let this sit on the marble for about 24 hours. Test a small area if it's not clean spray vinager right over top of the paste. This will start a chemical reaction that will foam up and take those hard water stains right off.
Apr 07, 2014 | Crafts & Hobbies
My h2o steam mop does not produce steam.I have only used it 6 times. I have tried using 1 part vinegar and 2 parts water to clean the system but no joy.
The H2O Mop X5 is designed to thoroughly clean floor surfaces, such as marble, ceramic, carpet, stone, linoleum, and sealed hardwood floors and parquet. Not all floor types are suitable for steam cleaning. For more details about h2o mop please visit ADS TUTORIAL
Oct 28, 2012 | Vacuums
What are the steps in solving for probability on C?
If you have nine marbles in a bag, four of which are blue, then the probability of reaching in and pulling out a blue marble is four out of nine, or 4 divided by 9.
Stay in the normal computational mode and press 4 / 9 =
If you want to know the probability of pulling out three (for example) marbles and getting at least one blue marble, then you get into combinatorics. The answer depends on whether or not you replace each marble after pulling it out (Sampling with/without replacement).
Probability is a rich and varied field of mathematics. People have spent lifetimes studying it.
Nov 06, 2011 | Casio FX-115ES Scientific Calculator
Refrigerator leaks
If you look on the freezer floor you will probably find it iced over. There is a drain trough at the rear wall, bottom of the evaporator that has a drain hole in it. That hole is probably clogged. You need to DEICE IT AND BLOW IT OUT with hot water.
Apr 08, 2009 | Refrigerators
THE DISHWASHER STAYS IN THE WASH CYCLE
Check to see if the water is getting hot during this time, if not then the heater is probably not working, could be bad heater, bad door switch or bad heater relay on the control board.
Dec 14, 2008 | Whirlpool 24 in. GU3200XTP Built-in...
Flood protection is activating
Had the same problem on a Miele mashing. In my case trying to clear a drain blockage in a kitchen sink had probably forced water back into the washing machine and caused an internal leakage. Rather than remove the whole machine and tip it over, I opened the small panel at the front bottom (behind the skirting panel) (needs 'special' screwdriver for the 2 screws) and removed the water that was lying on the base of the machine. Not much (less than 5mm) but enough to lift the white polystyrene float (a round disc about 10cm diameter) which was activating the micro-switch and causing the F70 message.
Oct 29, 2006 | Zanussi 24 in. DE6850 Free-standing...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
