Question about Jenn-Air PRG4810 (NP) Gas Kitchen Range
With the Jenn-Air PRG4810NP (Natural Gas), is there any way this can be converted to LP with a regulator? I'm not sure if I ordered the regulator for the LP range and attached it to the NG model, if this would work or even be safe?
  • crystallewri Jul 03, 2009
    I looked in the manual and it says the oven does not have orifices. Is this possible?
  • Terry koks Oct 03, 2012
    Did the solution work for you?
  • 999 Answers
Conversion is usually accomplished by flipping the regulator cap around. Nat side is hollow and LP is solid to hold the regulator open. The oven orifices are adjustable and the surface burnres can be either adjustable or have LP replacements.
Eric
Posted on Jul 03, 2009
  • Eric Duda
    Eric Duda Jul 05, 2009
    Only if the oven is electric. Gas burners have orifices... eric
Eric - Here's how I did it for converting from LP to Natural Gas, so reverse the instructions:
Hi - I just wanted to let you know that I was successful in converting the LP to the NP stove! Your advice sent me in the right direction, and I was able to engage a trained professional to make it happen.Here's what was necessary:
1) As noted, the parts above needed to be changed. That includes all six valves.
2) While the parts (orifices) are listed as being the same for the ovens and broiler, they are not. You'll need to order the same orifice for the two ovens and broiler that you do for the griddle.
3) Also, the regulator needs to be "flipped", from LP to Natural Gas - it's just a change of the "button" from one side to the other.
A few tricky items:1 - You'll likely need to replace BOTH of the dual burner holders - these are $70 each, but here's the trick - you can't actually change the holders, because the mounting of the LP and NP ones are different - you're just buying the holders for the TWO orifices that are in each. You'll take them out and install them into the existing holders.
2 - The orifice and orifice holders for the other four burners don't actually need to be changed - just the orifice, which can be done from the top fairly easily. The reason that they are sold with the orifice and the holder is that often the holder gets often used to get broken during the orifice change as a part of the replacement process (according to older Jen-Air techs) because the brass nut that you remove to do the orifice change seizes up and breaks when you remove the nut, so they were just sold together to make the technician's life easier.
3 - Why you need to change all six valves is a mystery to me (and to my trained professional tech) as there doesn't seem to be any reason to actually do this. If you don't get a true Jenn-Air valve, there may be an aberration in the front knob area that will cause it to be a quirky fit for the igniter switches. You might actually try NOT changing the valves first - as these were the most expensive part of the change-over. The cheapest valves were $190 each for the two with the switches a part of the valve, and about $80 each for the four that didn't have the switches. On the valves with the igniters a zip-tie actually works to snug it up to the valve.
3) You COULD do all this yourself, but I recommend you get a tech to do it. They are reasonably priced, and you'll want to discern what their hourly rate is, and pay it. It's worth it.
4) When you change the orifice for the broiler, you'll need a 1/2 open-ended box wrench that is at 90 degrees - I didn't have one, so just bent one to make it work in the limited space.
One thing I didn't know, as a lay-person, is that if you fire up an LP stove with Natural Gas (even after changing the regulator), if you have LP orifices in it, the gas that shows will be lit and very low. Conversely, if you have a natural gas stove that you use LP in, you'll get a "flame thrower", but in both cases, things won't blow up - they just need adjusting.If you don't change the broiler orifice, it may not light, and you'll smell gas - so be careful as errant gas smells are a bad thing!
As noted in the manual, if you're turning on the stove for the first time, when you run the ovens, for the first 45 minutes there will be a bad smell as there is an interior lining of some type of oil that needs to burn off.
So, to recap:You'll need the orifices for the four "normal burners" (which means buying the orifice in the holder and then taking out the orifice, the burner/holders for the two dual burners, just to get the orifices out of them (there are two in each), and when you order the new orifice for the griddle, instead of just ordering one, order four, one for the griddle, one for the broiler, and one each for the ovens. I would first swap JUST these parts, and see if the valves work, and if not, then swap out the valves too.
Don't let anyone say you can't do this - I did.
Posted on Aug 11, 2012
How do I convert a Jenn Air PRG 4810 from natural gas to lp?
Many gas stoves anymore have adjustable orifices. and they just need to be adjusted to propane .
Mar 09, 2015 | Jenn-Air PRG4810 (NP) Gas Kitchen Range
I am trying to convert a Jenn-air model # PRD3630NP from LP to NG I assume this model is convertable becouse it has a convertable reg on it. Do thay make a kit to do this or is it just a matter of ins
Jenn Air use to make a kit that had the proper orifices for the burners and the valves. The regulator is adjustable for the conversion by simply reversing the main screw. It was intended to be convertible. However, since the model is discontinued, you can no longer purchase the kit (or the backsplash). Apparently Jenn Air believe that when they stop making a product, no one will ever need a part for it again (cough, cough).
Good luck trying to track down a kit. I've tried everywhere in the country and a few shops in Canada. I have a gas appliance expert who thinks he can accomplish the conversion by getting a few of the parts from the LP model and then modifying the rest. The orifices are basically the same, only the LP diameters are different. Theoretically, the ports could be filled and redrilled, but the hardware store was fresh out of 1.07mm bits, so I'll pass on trying this on my own.
If anyone has a LP model they want to convert to natural gas, I'll gladly swap parts.
Jul 25, 2012 | Jenn-Air Kitchen Ranges
Parts for converting Jenn-air svd48600w frin LP back to NG
try google jenn air have a wed site or a shop that sells that make
Jan 19, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
Grill model 720-0163 need to convert from propane to natural gas
Go to jenn airs web site an order a new natural gas regulator and or-faces.
Good luck and please rate fixya!
Feb 22, 2009 | Jenn-Air JLG7130A
Converting a range from LP to Natural gas
Yes, it is possible.
You have to get the right orifice's for Natural gas. LP gas orifice has twice the size hole as compared to Natural Gas. Using it without the right orifice will put out way too much gas, and you will burn everything, as well as it will be a fire hazard.
Your local gas company or propane company should be able to get you the right orifice
Please rate this solution.
Jul 31, 2008 | Jenn-Air ® 48" Professional Over The...
Conversion
call the dealer and get a converter.
Apr 24, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jdr8895aas
This is the solution to convert from LP back to natural gas that I posted as a comment on this thread:
After much work and little help from Jenn-Air or Whirlpool, I found a satisfactory solution. As many of you may have found out, Whirlpool does not sell the natural gas orifices to the JDR8895AAS separately as they do the LP conversion orifices. Instead, they recommend that you buy all 5 orifice holders that include the individual orifices. This would run about $120-150 depending on where you shop. If you want to take this route, the Whirlpool parts you need are:
1x740079621x740078132x740079611x74007816
Fortunately, because natural gas is denser than LP, the LP orifices can be bored out for a conversion back to natural gas. After a lot of homework I was able to find someone with the natural gas orifices for this stove that let me take them out to measure them. For some crazy reason, Whirlpool does not have this information:
Find a machine shop or a good appliance repair shop that has a wire gauging bit set. The natural gas orifice hole sizes are as follows:
Left front burner (16K BTU): 48Left rear burner (9.2K BTU): 54Center burner (5K BTU): 58Right front burner (12.5K BTU): 52Right rear burnger (5K BTU): 58
It cost me $25 to have these resized after I found the correct hole size.
Finally, to complete the conversion back to natural gas, you must flip the plastic screw-shaped piece by unscrewing the hex nut on the regulator at the back of the stove.
Hope this helps, because it took me a while to figure it out.
Converting aan LP oven to gas
In most cases the pressure regulator has to be changed or adjusted. The orfices on each burner, oven, broiler and surface burner may need to be changed also. Sometimes they can be adjusted. Sometimes the threads on the pipe are different also. This is to prevent accidental connection to the wrong fuel. The big difference is the gas pressure. LP is usually around 10 - 12 lbs and natural gas is usually around 3 lbs. Properly adjusted you will like natural gas much better than LP as it is slightly hotter. The information will be in the instruction book and also on the Jenn air web site. Whirlpool owns both Maytag and Jenn aire so check all sites. The conversion kit is usually less than $50.
Apr 20, 2008 | Equipex PZ-330 Electric Single Oven
Jenn air propane grill conversion
It is inconceivable to me that large manufacturers like Jenn-Air and Nexgrill can jointly make and sell an expensive grill and then completely abandon the consumer. I purchased an Jenn-Air 740-0142 LPG and like so many wanted to convert to nautural gas which requires a larger gas orifice. I spent a month on the internet and phone calling Jenn-Air and finally Nexgrill who actually manufactured the unit in China. The Jenn-Air and Nexgrill serial numbers are the same. the 740 prefix is LPG and the 750 prefix is natural gas. After three calls to Nexgrill I found a manager who actually acknowledged making Jenn-Air but declined selling me parts for it as I believe they have product liability concerns. I call back as a Nexgrill owner and finally ordered natural gas orifices at $10.00 each. The shipment never showed up. Calling back again I was told that they really didnt really have any orifices in stock but could sell me the entire replacement gas valve for $28.00 which I purchased. The valves actually arrived on the shipping receipt was from The Grill Services in City of Industry 909-718-6128 www.grillservices.com . Part number 750-0141/142/593/594.
Forget about pirates in Somalia... we have them right here. Shame on you Jenn-Air and Nextgrill.
Mar 12, 2008 | Grilling
Jenn-Air PRG4810 (NP) Gas Kitchen Range Logo
483 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
