Question about Compaq Computers & Internet
When I play streaming video from the net and use full screen mode the ati video driver fails and recovers numerous times sometime 25=30 times during a movie I have tried updating drivers but apparently I have the latest ones for my ati x 1100 onboard video card, have also contacted adobe but no solution as it seems there is a conflict with direct x 10 have also contacted ati but no answer can anyone help or even suggest what video card I could install that would solve the problem
  • 32 Answers
Do you know what an onboard video card is? it is a basic video card that is primarily installed onto the motherboard for basic PC work, not for heavy video files or gaming. seems to me you have a low end graphics card that cannot handle the job.you have to find out whether or not you can upgrade your pc to a fullon mind blowing video card before you even think about getting another. but unfortunately you do. plus you also need to check your net connection speed as this can play a major part also when downloading and playing large files.
Posted on Jul 02, 2009
Samsung laptop screen shows garbage r540
if it's something that occurs with movement, and you had you screen previously replaced i would suspect that the screen cable clip is loose, try re-seating the cable in the back of screen and securing it with some tape to ensure that that it remains clipped in place, i think that this us most likely the issue.
As for the ATI driver i sometimes see that occuring, try updating the drivers.
Oct 15, 2012 | Samsung R540 Laptop
Display driver stopped responding and successfully recovered
try checking for updated drivers for your hd 5730. i have seen this in desktops with both ati and nvidia gpus.
Jun 21, 2010 | Alienware PC Systems Alienware m15x Gaming...
I am running windows visa home, and my display driver is an ATI 3100 graphics, the problem is when i watch things on you tube or i player or something similar and put them on full screen nearly every time...
U should download a latest video driver and install it. If not solved then format it and use windows xp it will run smooth faster give higher performance. Vista uses doubled the ram and graphics than xp....therefore i suggest to use xp.
Nov 24, 2009 | Toshiba Satellite L300D-ST3501 Notebook
C language is not running in full screen mode
Windows Vista takes away a lot of support and convenience for the sheer attractive of flashy user interface. One major feature is the ability of open full screen window for command prompt shell in Windows Vista. When you attempt open or run DOS .com applications, .bat batch scripts or games that relies on command prompt, and including cmd.exe itself, you will encounter the following error message:
This system does not support fullscreen mode. Choose “Close” to terminate the application.
The lack of support for full screen DOS command prompt in Windows Vista is a big annoyance especially for those who still playing games for DOS and Windows 3.1/9x era, use legacy software such as WPDOS or programmers who frequently switch to command prompt to use DOS based programming language such as PASCAL.
There is no simple solution to this no support for full screen window in Windows Vista. In almost all possible workarounds, you are almost guaranteed that your Vista will be broken in some way, at least on the part on Windows Aero. You will lose the nice Aero Glass interface if you attempt any of these trick, plus other unknown side effects.
Workaround to Run or Open Full Screen Window Mode
Workaround 1: Use XDDM driver instead of WDDM driver for video graphics adapter
In another word, install the Windows XP video card driver for use in Vista. If the video graphics card hardware supports Windows XP driver, you can download the Windows XP driver for your video hardware and install it under Vista. However, be warned that using XP driver on display adapter may crash your Vista system randomly, so save your works before proceeding and use with care.
Note: This solution has been recommended by Microsoft in KB926657.
To install a Windows XP video driver under Vista, just follow the procedure listed in the guide below. The steps should work for both NVIDIA and ATI video graphics accelerator card.
Download the Windows XP driver installer for your graphics card from NVIDIA or ATI. Run the installation setup program just downloaded. Confirm any User Account Control permission warning when prompted. The installer will first extract and unpack the files required by installation to proceed to a folder/directory. Note down the path to the folder. For ATI, the folder for these installation files usually located in a directory with a name that resembles C:\ATI\SUPPORT\7-5_xp_dd_46743\Driver or C:\ATI\SUPPORT\7-5_xp_dd_ccc_wdm_46743\Driver, with the only different been the number to indicate the version and build number of the driver
Jul 31, 2009 | Computers & Internet
Streaming Video Freezes sound continues
You have the wrong screen resolution. Lower your resolution and it will work fine.
Mar 30, 2009 | Acer Aspire 5920-6727 Notebook
ATI Rage mobility graphics card update for dualview
Display Driver
http://ati.amd.com/support/drivers/xp/radeonxprevious-xp.html 13.3MB 8.12 12/10/2008 Display Driver Only tooltip.gif try this you might need new update to receive dual view
Resolved Issues for the Windows XP Operating System
This section provides information on resolved issues in this release of the ATI
Catalyst™ Software Suite for Windows XP. These include:
• Using an HDMI cable to connect an ATI All-in-Wonder to a Yamaha receiver
may result in the display resolution being limited to 1280x1024 and audio
failing to function
• Catalyst Control Center, some of the 3D settings are not displayed on ATI
Radeon HD 4870 adapters
• The operating system may fail to start after installing the display driver with
some configurations of "Crosfire" with Radeon X1900 Series devices
• The operating system may intermittently fail when exiting Test Drive Unlimited
after extensive game play
• Dual display, playing multiple video files on each monitor may cause the system
to stop responding
• City of Villains: Attempting to launch the game on a system running Windows
XP and containing either two ATI Radeon HD 38x0 or 46x0 products
may result in the game failing to load and the operating system failing to
respond
• Some OpenGL applications may cause the OS to stop responding on some
ATI Radeon HD 45xx adapters
• On some configurations, the display driver may stop responding when resolution
is set to 2048x1536 with 8X Anti-Alias and Edge Detect filter enabled
• Exiting some games may intermittently cause the following error message
when 8X anti-alias edge detection is enabled: "Display Driver stopped working"
• Hot unplugging a HDMI connection during video playback may cause system
instability
• Catalyst Control Center: Enabling pulldown setting may not work on all video
formats
• Systems configured with Overlay Theater Mode enabled may intermittently
become unresponsive after playing video
• Catalyst Control Center, setting the de-noise slider does not affect the quality
of progressive video content
• Intermittent flickering may be noticed on the TV out display when playing a
DVD using Cyberlink PowerDVD
Jan 22, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Assasin's creed
Try updating your video card driver....
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/gamesite/8-7_xp32_dd_65993.exe
that maybe a driver issue problem... and also check your video cards temperature during the game...
Jul 29, 2008 | ATI RADEON X1650 Graphic Card
ATI RADEON X1650 -- Video degrades during vewing - becomes blotchy and red
welcome to fixya
the video card might not be getting enough power you should have a 500w power supply or higher with that video card if you have this already might want to see if you can download any new drivers for the video card
i hope this helps out have a good day
Jul 18, 2008 | ATI RADEON X1650 Graphic Card
Full Screen Video Mode Problem on the internet
to help you in a better way wot we can do is acess your computer
there are online screensharing tools available but you have to provide me a fix time i can explain how will this gonna work
while i have the control over your system you will be seeing wot i see and at anypoint of time if you think you need the control back you can use the mouse i'll loose control
Jun 08, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
53 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
