Question about Maytag Dishwashers
Dishwasher control panel not responsive to touch, electricity is
Control panel not responsive
    Brigadier General:
  • 3,006 Answers
Replace the panel.
Posted on Jul 01, 2009
Lights are blinking when trying to start frigidaire dishwasher
First, confirm that the display is working. If the display is still working, try pressing some of the touch-pad buttons. If some of the buttons respond correctly but others don't, it is likely that the touch-pad is at fault. (Some manufacturers sell the touch-pad separately from the control panel. Other manufacturers require that you purchase the touch-pad and control panel together. If you cannot replace the touch-pad individually, replace the touch-pad and control panel.) Frigidaire Dishwasher Lights Flashing or Blinking
Oct 28, 2017 | Frigidaire Dishwashers
Dishwasher won't run
It is the touchpad that is faulty.. coz if the control board is faulty the unit may not respond to any button at all.. So just get a new touch pad.. If you want to buy it online.. then let me knnow i will get you the link..
Mar 13, 2008 | Kenmore 16372 / 16374 / 16379 Built-in...
Power to Front Control Panel
YOU DEFINITLY HAVE POWER COMING TO THE UNIT?IS THERE A TRANSFORMER?IF YOU HAVE THE CORRECT VOLTAGE AND THE KEYSWITCH (TOUCH PAD)PLUGS INTO THE BOARD YOU REPLACED THE KEYSWITCH IS BAD.HOW DID THE PROBLEM START?
Aug 28, 2007 | Kenmore 16879 Built-in Dishwasher
Start button replacement
Amber, Google search your make and model #, parts. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.repairclinic.com/Shop-For-Parts/a9/Dishwasher-Parts
Dishwasher Parts Dishwasher Repair Parts
http://www.appliancepartspros.com/dishwasher-parts.html
Jul 22, 2016 | Dishwashers
I have a whirlpool DU1145 dishwasher that seems to be stuck on the same cycle. It shows it as sensing and washing at the same time and never shuts off. HELP! WHat could becausing this??
Sounds like your Touch Pad on the Control Panel is defective.
You can try and remove the 120 Volt AC power from the Dishwasher by turning it off at your Main Electrical Power Panel with the Circuit Breaker (15 or 20 amp) labeled: Dishwasher .
Leave the Dishwasher turned "Off" for 10 minutes. This will allow the control circuits on the Dishwasher to reset. Turn on the Dishwasher and press Cancel and attempt to Drain the Dishwasher. If this works...then try to enter a Rinse Only cycle and if that works... then attempt to enter a Wash Cycle.
If you still have your original problems then you probably have a defective:
(1) Touch Pad Assembly (or possibly a defective)
(2) Electronic Control Module (ECM)
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Mar 24, 2011 | Whirlpool Dishwashers
My dishwasher has no power not even on the touch panel leds lights. I checked the connections.. Is there a reset button or a fuse i can replace or reset?
Check the appropriate breaker in your house electrical panel--push off, then on. If still nothing, look for a removable panel at the bottom under the door. Any internal fuses or breakers will be accessible there.
Sep 17, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
My dishwasher wont turn on,or power on
Verify there is power to the electrical outlet. Make sure that a GFCI breaker has not tripped. Try unplugging it from the electrical outlet for about 5 minutes and plug it back in. Does this computer have a soft touch control panel? With the power disconnected remove the inner panel to reach the control panel board. Inspect the ribbon connector and make sure that the connector is fully inserted and has not slipped out. Check the ribbon connector for any signs of a short. My dishwaher was doing the same thing and it turned out the control panel ribbon connector had shorted across causing it not to work. If the contol panel tests good then lt could be a fuse located somewhere on the dishwasher or the computer board.
Sep 17, 2009 | Dishwashers
I have a Maytag MDB 5600AWW dishwasher. There are
If there are no lights on the control panel then initially check if connections to the panel are fine.If they look fine then you definitely need a new control panel. No need for a new touch panel.Its always that the control panel goes faulty,not the touch panel.
you can also check for competitive rates from local dealers and few sites like--repairclinic.com and applianceparts.com
thanks.
Aug 28, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Bosch dishwasher SHE44CO2UC/22 no power or light, no response to the power on. We have checked fuse box and electrical supply. Is this an electrical panel problem? Is there a "fuse" to the dishwasher?
Hi sir,
first thing to say is that whether it may be an short circuit between circuits,,or due to an over voltage the fuse may be burnt,,please check the control panel..back of dishwasher,,,
if u checked fuse and circuit,,and think no problem with incoming voltage ,,the control panel's capacitors or resistors may be burnt..
if so please go to a tech,,,,,
thank u,,,for using fixya
Jun 26, 2009 | Bosch SHU5315UC Dishwasher
KUDIO1ILBS2 KitchenAid Dishwasher, two years old, not heavy usage: control panel is dead, no other power problems in the apartment, the apartment's electical box shows all breakers ok.
These dishwasher have a thermal fuse near the contol panel protecting the heat sensitive computer. Do you use the Sanitize or Anti-bacteria cycles?? If so then these cycles get very hot and could have made the fuse blow. Kitchenaid also had some loose connection problems at the fuse making the fuse heat up due to the electicity and not actual temperature. The new fuse comes as a kit with connectors already attached to the fuse (dont mess with them) and a junction block to splice the wires.
Jan 18, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Dishwashers Logo
94 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
