Question about Pentair STARITE PUMP HOUSING / TANK BODY
I need the wiring diamgram for my pump. i think the model number is p48k2eb7h.
  • 83 Answers
I hate to tell you this, but the ONLY place you will get one of those is through the company. And THEN only if you are a certified repair person.
The number you listed is not the model number, it should be at the lefthand top corner of the silver sticker on the motor of the pump. What is the pump doing?
Posted on Jul 01, 2009
Fuel pump diamgram 750 2015 harley
Hi, Kenneth for this scenario you will need your service, parts fiche, and owners manual if you can not find the best tool you ever bought for your Harley, despair not, for a mere $15 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Fuel pump diagram 750 2015 harley Google Search
Recall News Harley Davidson Street 500 750 Recalled For Defective Fuel Pump
Harley Davidson STREET XG500 XG750 Complete Service Manual 2017 $15 includes electrical diagnostic manual cheap
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
2015 Harley Davidson Harley Davidson Street 750 Owner Manual
Instant Tech Relief To speak to me personally absolutely "FREE"
Sep 29, 2017 | Harley Davidson Motorcycles
Looking for a wiring diamgram on a 2014 Heartland Trail Runner 39FQBS?
A wiring diagram would have to be requested directly from Heartland.
May 22, 2017 | Heartland Kitchen Ranges
Pride mobility scooter wiring diamgram
Go to Pride's web site to download the service manual.
Jul 28, 2014 | Pride Health & Beauty
Will replacement motor 266520 fit SGS53E72EU/71 Bosch dishwasher
The motor for that model is 489652, I think you'll find that the two middle tags on the original motor are linked and one of the original wires has a smaller spade connector so can only go on a specific connection. As for the cap can you use the coupling from the old one?? What are the symptoms to need to replace motor?
Mar 13, 2013 | Bosch Dishwashers
Timer not working on 4000 series, think its 4014 single pole single switch for pool pump. pump turns on when manually turn switch on but timer does not move. I feel the normal resistance and can move the...
1) If circuit breaker is not tripped or shorted, then timer clock motor has probably gone bad.
2) Some places still sell paragon timers, depending on model number.
But model number given is for 240Volt timer.
3) The clock motor is not available that I can find.
Paragon is no longer making the 4000 series timers or parts
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
4) Model number given does not match wiring terminals shown in manual.
4014 is DPST 240Volt timer with 4 wiring terminals labeled 1 2 3 4.
http://waterheatertimer.org/pdf/Paragon-4000-series.pdf
5) Paragon 4000 series timer with terminals 1 2 3 is 120Volt timer.
6) Replace 120Volt timer with Intermatic T101 indoor timer or T101R outdoor timer.
Crossover wiring:
Paragon terminal 1 goes to Intermatic terminal 1
Paragon terminal 2 goes to Intermatic terminal 2
Paragon terminals 3 goes to Intermatic terminal A
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 29, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
I have a frigidaire stack washer and dryer model fex831cso Iam not getting voltage to my pump motor but drum is spinning what do i need to look for Iam thinking it might be the timer all help appreciated
In a packet on the back side of the diagonal panel between the washer top and control panel,is the wiring diagram. It will show you where the wires come from to power the pump. I am not absoluty sure but believe its directly from the timer to the pump. So find what wire is the hot one and check continuty on it from the timer to the pump,and the neutral wire check that for continuty as well. The hot wire is exclusive for the pump circuit,the neutral wire ties into all neutral wires so continuty can be checked on it from any neutral wire to the neutral for the pump.If continuty on both wires,Replace the timer. The washer timer part number is 131758600 it could be picked up from your local appliance parts store,or online at;
repairclinic.com
searspartsdirect.com
apwagner.com
apdepot.com
midwestapplianceparts.com
Gene..OldTech2332
Aug 20, 2011 | Frigidaire FEX831CS Top Load Stacked...
Troy bilt lawn mower. Will not engage self propell, front wheels
Hello:
Send me the Model and Type or Spec Numbers Off the Engine and the Mower Model Numbers, Please. With these I can Locate the Proper Manual and Better Assist you. The Engine Model Numbers May be Stamped Into the Blower Housing (metal engine cover) Above the Spark Plug. The Mower Model Numbers are Usually Located Under the Seat on a Sticker on the Body of the Mower.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
Apr 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Pentair STARITE PUMP HOUSING / TANK BODY  Logo
56 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
