Question about Dell Inspiron 6400 Notebook
The battery light remains on unless the power
The battery light shows red all the time on unless the power source is connected to the mains. The battery no longer shows a full charge. Is the battery damaged and do I need to purchase a new one.
  • 2,229 Answers
If the computer will run on battery alone, and you cannot fully charge the battery, it's probably time for a new battery. The life expectancy is 2-3 years if treated right. Some people get a lot more life than others.
Here's a suggestion: when you run your computer, let the battery run fully down at least once a month. Do not leave it plugged in to line power all the time. Do not keep charging it when it is only a little bit discharged.
Posted on Jul 01, 2009
How to source a 12v Accessory Power for Flip Down DVD Screen
You said "ECU being funny if you connect any power source to any outlet"
You aren't connecting a power "Source" to the vehicle unless the unit has internal batteries.
The ECU is far more sensitive to someone connecting another lead acid battery to the system, as in Jump Starting the Car.
A spike or trancient voltage can damage the vehicles main control cpu or ECU but highly unlikely from a dvd player or mobile phone etc.
I wouldn't be overly concerned....
If the device you attaching draws only 1-2 amps then pinching a bit of power from the reversing light is the way we all do it.
But... you can insert a device like this in between to protect your DVD Screen from transients.
ADPTR MODULE MULTI VOLTAGE REG 1 5A DC DC Converters Power Conversion...
Sep 18, 2015 | 2014 Jeep Patriot
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Evrytime I unplug the charger on my lenovo S10-2 ,it automatically turns off. a little help please! :((
Sounds to me like you may have a problem with your laptop battery! It may be time for a replacement. You can find some on ebay that work fairly well; I have bought and used several different laptop batteries from ebay with success! Or, you can always purchase from Lenovo themselves.
  1. eBay: Here is a link to batteries that will work with your laptop.
  2. Lenovo: Black battery is here. White battery is here.
A little information before you decide to fork out some money:
  • Keep in mind the color of your laptop; don't buy a white battery if you have a black laptop and vice versa, unless you want that kind of look, of course.
Hope this helps!
Jun 07, 2011 | Computers & Internet
Battery showing fully charged- battery charger on but ...
You have a bad connection at main panel, causing voltage drop to system. Check all connections in electrical panel and transfer switch.
Sep 13, 2009 | Electronics - Others
Element tv.. model # ELCHS261 stopped working
My Element ELCHS261 will not turn on at all. The only thing it does is the red light will turn to blue but no sound and no picture. My troubleshooting items have been changed the batteries in the remote then I unpluged the power for for 30 minutes and still nothing.
Jul 10, 2009 | Element Electronics FLX2211B 22 in. LCD TV
Red light wont go off headset wont turn on
SImply connect the headphones to a power source. Then press up and down volume buttons at the same time. It will reset the headphones.
Dec 08, 2008 | Insignia Bluetooth Wireless Headphones...
My Compaq R3000 does not charge up
The problem might be the battery itself. Four years is a long time for rechargeables. Also, check if the error ocurs when the battery is not in the slot.
Oct 27, 2008 | Compaq Presario R3000 Notebook
M670 notebook not charging when plugged in
Charge the Battery fully before first use . The red flashing indicator shows that the battery has been deeply or fully discharged . Please Connect your laptop to AC power source and let it remain for well over 10 hours atleast.If the battery pack is alive it might recover and start working normally.
Apr 27, 2008 | MSI Megabook M670-046US Notebook
Solving a projector problem
if power lamp and status lamps are red change the lamp.
Jan 15, 2008 | Mitsubishi HC3000U Multimedia Projector
Dell Inspiron 6400 Notebook Logo
162 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
