Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca d52w20 52" rear pro. comes on, screen black, then turn off
I have an rca d52w20 52" tv i am trying to fix. when you press the power button the light comes on but the screen is blank. you can hear the sound it makes when it powers up but you can also hear a hissing/crackling sound(im guessing capacitor) , then it turns off after about 6 seconds. could someone point me in the right direction, what to check? i have the electronics and soldering skills so thats not a problem.
thanks in advance.
  • 8 Answers
SOURCE: RCA HDTV #D61W20, CHASSIS ITC222, Power button flashing 1, pause, 9. Possible error code 19, anyone know what this means
This is not a friendly chasis, the only easy fix that you might check on the power supply board and the left side (looking from the back) 3 capacitor (220,330,and 2200uf 16V) have the top pop up. Other than that poping, arcing noise, burn smell when first start up is bad york, Flyback Transformer and even the cooling leak for those tubes you will need professional TV repair man. Those TV picture not very nice anyway.
Posted on Jan 06, 2009
Slinteriors
  • 8617 Answers
SOURCE: My 52 inch RCA HD/TV Does not turn on
Replace CP150 on the deflection board and that should take care of the problem since it starts once in a wnile if it didnt start ever then you would need the 259296 flyback and the CP150 Capacitor.
Posted on May 11, 2009
darjr
  • 378 Answers
SOURCE: No picture (black screen); making popping/crackling sound
there is a possibility that the semiconductor in power supply side damaged due to electrical surge. more likely the STR IC of Diodes.
Posted on Jun 01, 2009
ladywinn
  • 5138 Answers
SOURCE: R56WH76 Failed Convergence Fix
OK on same circuit board as fuse up on the front part of board look at capacitor cp150 if it is swollen or puffed up it is bad 2200uf 16v use 25v and replace 2 other capacitors in same area cp114 cp120 220uf 35v.
Posted on Sep 24, 2009
SOURCE: 52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Posted on Jan 30, 2010
I too cannot get the TV to turn on but my model is a R52WH74
the chasis number of your tv is eithor itc222 or itc221 the deflection board causes most of the problems part number 258762 part discontinued but you can contact eithor pts electronics or tristate module to see if they can fix yours
Sep 02, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Im having a problem with my tv to where it will not turn on.Its a RCA d52w20 the screen will not come on.the power button will however come on then turn off three times on a row yet my screen will remain...
You most likely need a Power board, and/or possible a main board replacement. Parts can be ordered on line, and you can either replce them yourself or go to a site like Onforce.com and accept bids to do the replacing.
Aug 31, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Help me please
You have bad capacitors 3 of them.cp150 2200uf 16v cp111 330uf 35v cp114 220uf 35v
Aug 09, 2008 | RCA D52W19 52" Rear Projection Television
52 in rca tv
does the light blink 3 times when you press power? Let me know exactly what happens when you press the power button. Please respond to this same post when replying.
Aug 07, 2008 | RCA D52W19 52" Rear Projection Television
Rca big screen
Does the power led blink, when you press power? Please respond to this post and I will try to assist you with the problem. Please respond to this same post when replying
Jul 31, 2008 | RCA D52W19 52" Rear Projection Television
My 1995 RCA 52
Replace capacitors in power supply,( 4 cap. ) 2.2uf 100V, 39uf 100V, 470uf 25V, Ready!!
Apr 25, 2008 | RCA P52926 52" Rear Projection Television
MacBook Pro Black screen and shining sleep indicator
is the battery fully charged? try plugging it in then press the power button again.
Jan 10, 2008 | Apple MacBook Pro PC Notebook
56 inch RCA rear proj T.V.
Sounds like the capicator on the high voltage is swelled,removing the back cover,make sure to unplug the unit first,there is a u shaped heat sink about middle ways of the board,inside that heat sink is a cap,it will be swelled on top of it,its a 2200 35v cap.
Jan 05, 2008 | RCA D56W20 56" Rear Projection Television
RCA projection televeion problem.
take your tv to a tech for repairs the tv power supply or related circuit is defected.good luck
May 14, 2007 | RCA D61W20 61" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
222 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
